Actually what you are probably looking for is AS9101. I did a web search and found a copy of it at advancedquality.com/as9101b checklist.pdf. (Seeing this is an SAE spec I don't know why it is available at this website. I also didn't check to see if this was the latest revision.)
Just to note, AS9102 is the first-article inspection spec.
