Seeking Help: Design of Experiments - DOE
carvind
How do I apply the concepts of designof experiments for cycle time reduction whether it is new product development or an existing manufacturing process. I would appreciate any inout on the topic. Thanks
Jon O
carvind,
Your DOE results are a starting point. Now that you have a "optimal" window you can run your process in at a lower cycle time, you need to test your results. Your DOE has showed that you can produce product within specification at your new settings however it has not proven whether you can produce capable product at the new settings. You need to go ahead and conduct a capability assessment on the new settings. If your capability study shows that the new process settings are capable, and you are confident in the new settings, present this to your team and move forward with the required quality system changes.
Regards,
Jon
carvind
Design of Experiments - Help
Please help me in creating a plan for implementing a DOE for the following situation.
The position of the leads on an electronic component is important to get a satisfactory mount of the component to an electronic printed circuit board. There is concern that with manufacturing an electronic tester of the component function is bending the component leads. To monitor physical changes from tester handling, the leads from a sample of components are noted before and after the tester.
(a) Create a plan for implementing a DOE that assesses what should be done differently to reduce the amount of bending on each component. Consider the selection of measurement response, selection of factors, and results of validation.
(b) Create a plan that could be used in the future for a similar machine setup.
As I am not familiar with the process, I would appreciate if someone can define the key process input and response variables for this situation.
Marc Richardson
DOE
Let's start at the beginning. First of all, have you proved that the mountings are being bent during testing? I would conduct a T-Test on the before and after measurements to be sure that that is where the damage is ocurring. If there is a statistically significant difference, the T-Test will quantify the amount of change and then perform a correlation study to determine if the testing was making a preexisting condition worse or not. After that, we can identify the variables that effect the bending of the mounts.
Marc Richardson
Sr. Q.A. Eng.
carvind
Hi Marc,
Thanks for your response. Could you please suggest the possible input and output variables assuming that whatever you have suggested has been verified.
A Seeking Checklist for Auditing 7.3 Design Development for TS 16949 - pls help! Design and Development of Products and Processes 2
D Seeking help in validating a cleaning process. Manufacturing and Related Processes 5
L Seeking help in Basic Maintenance Knowledge Manufacturing and Related Processes 4
B Seeking help in answering Australia Tax Withholding Declaration Coffee Break and Water Cooler Discussions 1
B Seeking help in writing marketing message Career and Occupation Discussions 12
B Seeking help in writing an audit report that can stand on the court Internal Auditing 6
K Seeking help in making a decision - Project behind schedule Quality Manager and Management Related Issues 11
D Seeking Help: Nondisclosure vs. generic QMS documents Misc. Quality Assurance and Business Systems Related Topics 10
K How to Write a User's Manual for Peachtree - Seeking help Document Control Systems, Procedures, Forms and Templates 4
S Seeking Help with FDA GMP Device Training Training - Internal, External, Online and Distance Learning 8
P Criteria for operator's readings at setup - Seeking help to explain chosen limits. Statistical Analysis Tools, Techniques and SPC 4
P Calibrating Density Cups & Viscosity Cups In-House - Seeking Procedure / Help General Measurement Device and Calibration Topics 2
Ron Rompen Need help with MSA/Gage R&R - Seeking Minitab template file/sample GR&R study Using Minitab Software 7
A Help regarding FMEA - Seeking Review FMEA and Control Plans 1
E Contract manufacturer seeking help understanding ISO 13485 Validation requirements ISO 13485:2016 - Medical Device Quality Management Systems 9
P Making reports and follow-up on KPI's - Seeking help on how to track and report Quality Tools, Improvement and Analysis 2
J Seeking Excel Spreadsheet to help with cycle test for Weibull failure rates Excel .xls Spreadsheet Templates and Tools 2
R Seeking ISO 17025 tools to help keep my employees in the mind frame of ISO 17025 ISO 17025 related Discussions 1
S Gage R&R study Equipment Variation (EV) is high - Seeking Help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Y Seeking help with Corrective Action Preventive Action procedure Document Control Systems, Procedures, Forms and Templates 2
Y Seeking help with control of non-conforming product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
B Seeking help with ISO13485 quality manual Quality Management System (QMS) Manuals 24
K Transition from ISO9001-2000 to TS16494 - Small Business Seeking Advice and Help IATF 16949 - Automotive Quality Systems Standard 4
M ISO Standard Examination - Seeking help formulating an exam Training - Internal, External, Online and Distance Learning 1
N Confused by calibration concepts - Seeking help with the basics General Measurement Device and Calibration Topics 9
Q Seeking: Process Change Control Sample Procedure / Help IATF 16949 - Automotive Quality Systems Standard 6
B Seeking TS 16949 Help - Human Resources Department IATF 16949 - Automotive Quality Systems Standard 5
R Seeking Help: TS16949:2002 Manual Revision IATF 16949 - Automotive Quality Systems Standard 10
M MTBF (Mean Time Between Failures) - Seeking help Statistical Analysis Tools, Techniques and SPC 1
W Developing ISO 14001 Aspects and Impacts List - Seeking Help ISO 14001:2015 Specific Discussions 4
M Seeking Management Review Help - Procedure examples or ideas? Management Review Meetings and related Processes 8
Randy Department of Labor Job Description - Seeking Help Career and Occupation Discussions 22
G Seeking reference guides/ documentation /tips on verification best practices Other Medical Device Related Standards 6
J New QMS Auditor - seeking opportunities to gain audit experience Career and Occupation Discussions 3
M Seeking mentor/consultant for orthopaedic soft goods regulations Job Openings, Consulting and Employment Opportunities 0
M Seeking Consultant for Orthopedic Start Up company Other Medical Device and Orthopedic Related Topics 1
H SOP Template for seeking regulatory clearance - MDSAP Document Control Systems, Procedures, Forms and Templates 7
W Seeking Guidance Verification Test Strategy for Class B Medical Devices IEC 62304 - Medical Device Software Life Cycle Processes 1
M Seeking advice regarding use of off-the-shelf (OTS) batteries Other Medical Device and Orthopedic Related Topics 4
A ISMS - Seeking VAPT Consultant Food Safety - ISO 22000, HACCP (21 CFR 120) 1
M Medical Device Directive - Seeking common nonconformance write up scenarios CE Marking (Conformité Européene) / CB Scheme 2
silentmonkey Seeking efficient method to manage install base data Manufacturing and Related Processes 0
K Seeking ISO 13485 Registrar Recommendations Registrars and Notified Bodies 15
R Tapping problems - 3/8" hot roll pickled & oiled steel - seeking expertise Manufacturing and Related Processes 15
S Responsibilities between government owner and private subcontractor of a power plant seeking ISO 9001 certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B Seeking for an example or a template of a Business Plan Service Industry Specific Topics 3
B Health Canada Recall Definition - Seeking Clarification Canada Medical Device Regulations 5
W Seeking Returned Merchandise Procedure Customer Complaints 1
QMMike New Trend of not seeking Official ISO 9001 Registration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 43
R Clinical Evaluation according to MEDDEV 2.7.1 (Rev 4) - seeking template ISO 13485:2016 - Medical Device Quality Management Systems 6
