I really wasn't sure where to post this.
I am in need of any information that anyone has regarding automaticed torque testing. We have a new job coming on line where we are going to have to be measuring torque "IN" of a new screw, three times for the same threaded hole. We also have to then torque down to 45Nm and record the break loose torque.
Listed below is the proposed torque testing method:
A. Test pieces
1. sheet metal 1,5 mm with a 10,25 mm hole
2. Bolt M10x12 - 8.8 DC- no. A 140 984 47 29
B. Test process ( repeat 3 times always with new bolts)
1. Bolt in new bolt, trace the torque [Nm]
(only 1. operation)
2. Bolt down to 45 Nm
3. Unbolt, trace the torque [Nm]
4. Dispose the bolt
C. Requirements A / B
1. Bolt in torque ( Pt. 1 ) > = 1,5 Nm
2. Unbolt torque ( Pt. 3 ) > = 25 Nm
D. Maximum torque test (performed after test process B is completed)
1. Bolt in new bolt
2. Torque down until failure
Requirement:
1. Failure torque > 50 Nm
Obviously this will take some time doing this by hand.
All suggestions will be greatly appreciated.
A. Test pieces
(only 1. operation)
4. Dispose the bolt
1. Bolt in new bolt
Requirement:
