Seeking Internal Audit Plan - Design Responsible Manufacturing company
sridharafep
We are a manufacturing company having design (4 department headed by different sec head) also production and quality, purchase, store, maintenance department is common for all these - i am in need of audit plan. We do have audit plan by department wise and have department procedure separately. One external auditor object this planning method. Please help me to make a good plan. Department :thanx: wise audit covering the ISO element is not acceptable? Your views please.
K
km214
Audit Plan
Lucida Sans
ISO has requested that people use the "process method" to audit internally as well as externally.Departmental audits are a thing of the past although it is much easier to apply the elements by department, by process isn't that bad. You just need to refocus to thinking in terms of processes within your organization. It takes time but it is possible and more effective. Try purchasing a book on how to audit using the process technique. See the ASQ website's bookstore.
Since the latest revision of ISO 9000 came out the certification auditors prefer that ll companies regardless of industry use the process method for auditing.
I hope this helps
Katherine
I
IEGeek - 2006
This is more of a Process Flow but I think it is something you are looking for.
Try it and see if you can apply it to your situation.
RosieA
Hi sridharafep,
One way to do a process audit plan is to define the scope of the audit by using your procedures and use your procedures to develop audit questions.
For example, if the audit is of Engineering, then define the scope of the audit as all of the procedures that relate to Engineering. Then read each procedure and develop questions related to the key points in the procedure.
If the procedure states that you create a design file for each new design, then choose a new design and ask to see the design file. Does it contain everything that the procedures says it should? Does it have evidence of review and approval? Does it have inputs and outputs? Are there results of verification and validation.
This method helps you to avoid having audits that ask the same questions each time, and keeps the audits fresh.
This method may not work well if you are new to ISO 9000 and have not yet established that your quality system has addressed all the elements of the standard.
V Seeking Internal Audit Plan form or template Internal Auditing 5
Q ISO 13485, FDA's QSR, CMDR, MDD: Seeking Internal Audit Correlation Matrix Various Other Specifications, Standards, and related Requirements 3
C Alternative Internal Audit Methods - Seeking Enlightenment General Auditing Discussions 68
A Warehouse Internal Audit - Seeking Tips and Advice Internal Auditing 17
W Internal Audit Schedule - Seeking Examples - Quality Audits Internal Auditing 14
M Internal Quality Audit - Seeking Example Procedure Document Control Systems, Procedures, Forms and Templates 1
J Internal Product Audit - Seeking an example form IATF 16949 - Automotive Quality Systems Standard 18
A Seeking: ISO 9001:2000 Internal Audit Checklist for Newbie Internal Auditing 20
T Developing TS-16949 Internal Audit Schedule - Seeking Example and Advice Internal Auditing 9
F AS9100 Internal Audit Schedule - Seeking Example AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M Seeking template for Internal Audit Training Certificate Document Control Systems, Procedures, Forms and Templates 2
I Seeking: Internal Audit Training Material - Practice Audits? Internal Auditing 14
J Seeking: Internal Audit Checklist Sheet Form Internal Auditing 2
A Seeking: QS-9000 Internal Audit Checklist Internal Auditing 2
Claes Gefvenberg Seeking Opinions: Internal Audit Flowchart Internal Auditing 5
S TS 16949 Internal Audit Scheduling - Seeking Advice Internal Auditing 10
C 8.2.2 Internal Audit - Seeking Opinions Internal Auditing 38
T Seeking ISO 9001:2000 Internal Audit Matrix Examples Internal Auditing 7
P Seeking Training Document - Good Characteristics of an Internal Auditor Training - Internal, External, Online and Distance Learning 8
T Internal Auditor Training Presentation - ISO/TS 16949 - Seeking Information Training - Internal, External, Online and Distance Learning 10
Marc QS-9000 Internal Auditor Training - Seeking Providers Training - Internal, External, Online and Distance Learning 5
A Seeking training courses for EMS internal auditing - OH, PA or IN Training - Internal, External, Online and Distance Learning 1
F Seeking: Examples/Samples - How to document internal auditor qualifications Internal Auditing 9
S Internal Auditor Training - Seeking Format - Will you share? Document Control Systems, Procedures, Forms and Templates 4
W Internal Auditing Software packages - Seeking Recommendations Quality Assurance and Compliance Software Tools and Solutions 4
Howard Atkins New to Internal Process Auditing - Seeking Sample Process Audits Process Audits and Layered Process Audits 31
E Seeking "Games" Suitable for an Internal Problem Solving Course Nonconformance and Corrective Action 10
S Seeking: Case Studies for internal auditor training Internal Auditing 5
normhowe Seeking a De Novo Consultant Paid Consulting, Training and Services 7
H SOP Template for seeking regulatory clearance - MDSAP Document Control Systems, Procedures, Forms and Templates 6
W Seeking Guidance Verification Test Strategy for Class B Medical Devices IEC 62304 - Medical Device Software Life Cycle Processes 1
M Seeking advice regarding use of off-the-shelf (OTS) batteries Other Medical Device and Orthopedic Related Topics 4
A ISMS - Seeking VAPT Consultant Food Safety - ISO 22000, HACCP (21 CFR 120) 1
M Medical Device Directive - Seeking common nonconformance write up scenarios CE Marking (Conformité Européene) / CB Scheme 2
silentmonkey Seeking efficient method to manage install base data Manufacturing and Related Processes 0
K Seeking ISO 13485 Registrar Recommendations Registrars and Notified Bodies 15
R Tapping problems - 3/8" hot roll pickled & oiled steel - seeking expertise Manufacturing and Related Processes 15
S Responsibilities between government owner and private subcontractor of a power plant seeking ISO 9001 certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B Seeking for an example or a template of a Business Plan Service Industry Specific Topics 3
B Health Canada Recall Definition - Seeking Clarification Canada Medical Device Regulations 5
W Seeking Returned Merchandise Procedure Customer Complaints 1
QMMike New Trend of not seeking Official ISO 9001 Registration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 43
R Clinical Evaluation according to MEDDEV 2.7.1 (Rev 4) - seeking template ISO 13485:2016 - Medical Device Quality Management Systems 6
T ISO 9001:2015 Training for Management Team in NM - Seeking Suggestions and Providers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D Seeking Corrective Action Process Examples Nonconformance and Corrective Action 3
M AS9102 Training - Seeking third party agency that provides online AS9102 training AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
F Seeking Internship/Co-op Opportunities in Regulatory Affairs/QA/Clinical Domain (USA) Career and Occupation Discussions 4
L Seeking help in Basic Maintenance Knowledge Manufacturing and Related Processes 4
M Seeking opinion for ISO14001 team activity ISO 14001:2015 Specific Discussions 3
smryan Seeking good 2D barcode add-in for Excel Excel .xls Spreadsheet Templates and Tools 6
