Carol, i forgot to mention this, and knowing you, I'm sure you'll do it anyway, but still...
When you get serious about a purchase: Make sure you bring well measured and documented samples from your production with you for a test run, and then compare the results with your records. As I pointed out, the software is likley to be the weak link if there is one.
And hey: Good luck
/Claes
