Self (In-House) Calibration of Measuring Tools (vernier, micrometers etc.)
rizy951
Dear,
I am working in a manufacturing organization and where I calibrate the tools (vernier, micrometers etc.) from an outside Lab. Now if I want to start the calibration of these tools in-house so, what will be minimum requiremests for this?
Also it is mentioned here that I have calibrated gauge blocks so please tell me that using these blocks, simply I can calibrate my tools or not. Please guide me in detail
brahmaiah
Dear,
To calibrate your measuring equipment on your own, you need following things:
1)A master gauge or instrument which is calibrated by an acredited laboratory.
2)The least count /precision of the master should ideally be 1/10 of the least count of your instrument.
3)The environement of the measuring room should be controlled as required in calibration standard.
4)You shuld document a procedure of calibration for the instrument in question specifying method of calibration and acceptable variation.
5)The acceptable variation should be capable of achieving the precision required by your product.
If you have the above five things, nobody can stop you from doing your own calibration. Please note the key here is, you can fix your own precision level depending on your product.
The calibration standards are designed for the aerospace industry for which you donot have to waste money.
V.J.Brahmaiah
brahmaiah
What do you mean? :confused:
Stijloor.
When my product tolerance is +/- 0.5 mm should I send my verniers and micrometers to certified laboratory and spend extra money on that instead of calibrating at home? In my earlier post I have listed 5 conditions for self calibration.
v.j.brahmaiah
U
Umang Vidyarthi
Dear,
You are at full liberty to go for in-house calibration. Brahmaiah has adequately briefed you on this. Another important thing is, that your lab people must be trained, preferably from an accreditated laboratory.
Umang :D
Stijloor
v.j.brahmaiah
I understand...I was more interested in your "Aerospace" bit...
Stijloor.
brahmaiah
Stijloor.
Aerospace Industry is like my mother. I was trained and worked there during the first ten years of my service.
I hold it in high regard.
V.J.Brahmaiah
V.J.Brahmaiah
Some of these statements are inaccurate!!
Calibration is a science which has application even at the level of the traffic police, performing speed checks and enforcement. Many people think they are doing calibration 'in-house' but don't posses many competencies (not just training) or the resources to perform calibration and waste money that way. Often they don't ask an outside lab for the correct service and take what they are given, but that's not a good reason to take calibration 'in-house'.
I believe your statement regarding the aerospace industry underlies your basic misunderstanding of the science of calibration;
Comment # 3 - Environmental conditions don't have to be 'controlled', they must however be known. There are many situations where money is wasted on a controlled envronment room, just for a few hand tools!
Comment # 4 - Is any old procedure going to be OK? If you calibrate an outside 0-25mm micrometer, for example, is any position along the scale acceptable, or how many should be used etc? There's a lot more to be considered than simply writing down what someone thinks should be done!
In #5 - What do you mean? How is a person to determine acceptable variation? Should someone calculate the uncertainty of measurement for the device? Peform linearity, bias and stability studies, is this what you mean?
Without clear understanding of the nature of calibration and the requirements for an effective system, the so called savings of doing calibration in-house can soon be lost through incorrect calibrations, wasted time and the negative effects on product and customer satisfaction!
Stijloor
<snip>The calibration standards are designed for the aerospace industry for which you do not have to waste money.
V.J.Brahmaiah
Let me try again. Calibration standards are NOT developed for the aerospace industry ONLY. They are developed and available for all industries that deploy measuring and testing devices. As an auditor, I want to know what sources of information are used to develop a calibration program.
Stijloor.
brahmaiah
Most medium and large companies do their own calibration.In many cases we need a second set of gauges when we depend on outsiders.One more important reason against outside calibration is that we donot have any control on them. When the workload is heavy they may dilute procedures and quickly prepare certificates and return the instruments.
Unfortunately greed has entered into every business.
V.J.Brahmaiah
A Self-training or Self-studying ISO 13485:2016 - Medical Device Quality Management Systems 8
K MDR Class 1 Self Certification - Competent Authority or Notified Body? EU Medical Device Regulations 6
M Control-self assessment Internal Auditing 5
Q Self-assessment audit information Quality Management System (QMS) Manuals 6
S User evaluation for self monitoring blood glucose test systems US Food and Drug Administration (FDA) 4
S Supplier Management ISO 13485: 2016- Which supplier needs to fill in a self assessment form? ISO 13485:2016 - Medical Device Quality Management Systems 6
E HONDA HAA QAV-1 Self Assessment General Auditing Discussions 4
T Formal Q Self Assessment - Problem with assigning Product and Process Customer and Company Specific Requirements 1
G Self Assessment Audit from a new potential customer General Auditing Discussions 3
M CE self-certification for Class I device (face mask) EU Medical Device Regulations 9
M Informational US FDA – Ear, Nose, and Throat Devices; Classification of the Self-Fitting Air-Conduction Hearing Aid Medical Device and FDA Regulations and Standards News 0
K Intended Use-Class I Self Certified - Intended Use and Indications for Use statements EU Medical Device Regulations 1
Ed Panek Part 11 Self Certify Memo - What else should it cover? Qualification and Validation (including 21 CFR Part 11) 5
M Informational TGA Consultation: Review of the regulation of certain self-testing IVDs in Australia Medical Device and FDA Regulations and Standards News 0
J Good Documentation Practices Self Test? ISO 13485:2016 - Medical Device Quality Management Systems 6
C CE marking for general IVD (self-certified) & ISO 13485 QMS requirements - auditing EU Medical Device Regulations 6
MichaelDRoach Oganization's Self Declaration of Conformance to ISO 28000 wording example wanted Supply Chain Security Management Systems 1
M Medical Device News TGA – Regulator Performance Framework: Self-assessment Report, July 2017 to June 2018 Medical Device and FDA Regulations and Standards News 0
A Selling CE marked self-test in Malta - any additional requirements? EU Medical Device Regulations 0
M CE self-certify, or needs testing by 3rd party? CE Marking (Conformité Européene) / CB Scheme 12
M Notified Body Involvement with Self Declared Products EU Medical Device Regulations 7
S Help: Need Control Self Assessment Questionnaire for HR Departmental Functions Process Audits and Layered Process Audits 0
T IVD - Self Declaration - Technical File - Template wanted Various Other Specifications, Standards, and related Requirements 9
R Documenting Self-Training and Effectiveness - ISO 13485:2016 Training - Internal, External, Online and Distance Learning 4
K ISO 13485:2016 Self Certification for Class I (annex 9) Stand-Alone Software? ISO 13485:2016 - Medical Device Quality Management Systems 3
S ISO9001:2015 and ISO14001:2015 Readiness/Self Evaluation Checklists wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
N MDD Class I Medical Device Self Declaration Articles/Supplementary Documents EU Medical Device Regulations 1
A Self-study plan to improve fluency in English speaking, writing After Work and Weekend Discussion Topics 3
Crusader Interval for Self-Calibrating Measurement Device? Calibration Frequency (Interval) 15
T Transition Time for Self Declared IVDs EU Medical Device Regulations 3
Z IVD Self Test Pregnancy - Assessment Route? EU Medical Device Regulations 5
S Anyone know the self-selection study for home use medical device Other US Medical Device Regulations 2
D Off-Label Self Promotion - What to do EU Medical Device Regulations 3
B Own Brand Labelling and Distributors - Self Test IVD's EU Medical Device Regulations 3
S Creating goals and objectives with targets and measurables for self-evaluations Management Review Meetings and related Processes 2
C Help with Risk/Benefit Analysis Self-help Device for Diabetics ISO 14971 - Medical Device Risk Management 3
B Self Contained Biological Indicators as internal PCD Other Medical Device Related Standards 2
T Self Declaration for CE Class I, Non-Invasive Medical Device EU Medical Device Regulations 10
R Self-Certification Is Not a Real Thing - an IAF article Registrars and Notified Bodies 13
T Should a supplier self assessment form be a controlled document? Document Control Systems, Procedures, Forms and Templates 9
C Vendor Self-Survey to Qualify Vendors/Suppliers - AVL Question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Annex III self declared IVD to be in use with Annex II List B IVD EU Medical Device Regulations 1
S SAE AS9015 Supplier Self Verification Process - Delegation Programs. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B FDA Product Classification - Self Treatment Software Applications 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
P Changing from contract manufactured to self manufactured 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A R2 Certification vs Self Declaration to ISO 14001 and OHSAS 18001 ISO 14001:2015 Specific Discussions 3
Marc Ford - Self-parking technology called Fully Assisted Parking Aid World News 1
L IVDD 98/79/EEC - Can I self declare? EU Medical Device Regulations 2
P ISO/TS 16949:2009 Compliance - Self Declaration Audit IATF 16949 - Automotive Quality Systems Standard 4
B CCNA (Cisco Certified Network Associate) Self Study Help? Professional Certifications and Degrees 3
