Self Proclamation of ISO 9001 Certification and Compliance
#41
As for my car analogy, let me take another stab, and see if you agree with my logic. Let us set aside whether the car is actually safe to drive (as setting aside whether an organization really has a good quality system), you want an inspection sticker to satisfy law enforcement.
This makes more sense to me now. I hadn't stopped to think about states where safety inspections are mandatory.
If you are doing these assessments yourself, you have no objectivity to assert compliance to any standard. So to me, they are worthless.
Here's where we disagree, I think. I think I'm perfectly capable of objective appraisal of any quality system I've ever had a hand in designing. I need to make an objective appraisal before calling in the registrar, no? So why can't I make an objective appraisal and skip the second step?
V
vanputten
#42
Helo All:
I think some of the debate and confusion is becasue terms have not been defined. 4+ pages of postings and only some have begun to define terms. There is a reference to the Wiki for definitions.
I think the OP is asking for rules on self declaration of compliance, not certification or registration.
What do the following mean?
Accrediation
Certification
Compliance
Conformance
Registration
And then put the word "self" in front of them.
I have pasted below the definitions from the Cove Wiki. I am not sure the defintions help.
From the Cove Wiki:
Accreditation - Certification by a duly recognized body of the facilities, capability, objectivity, competence, and integrity of an agency, service or operational group or individual to provide the specific service(s) or operation(s) needed.
Certificate of Compliance - A document signed by an authorised party affirming that the supplier of a product or service has met the requirements of the relevant specifications, contract, or regulation.
Certificate of Conformance (certificate of conformity) - A document signed by an authorized party affirming that a product or service has met the requirements of the relevant specifications, contract, or regulation.
Certification - The procedure and action by a duly authorized body of determining, verifying, and attesting in writing to the qualifications of personnel, processes, procedures, or items in accordance with applicable requirements.
Certification Audits - Audits relating to registration (e.g., ISO 9000 audits).
Compliance and Affirmative - Indication or judgment that the supplier of a product or service has met the requirements of the relevant specifications, contract, or regulation; also the state of meeting the requirements
Conformance - (1) A dimension of quality that refers to the extent to which a product lies within an allowable range of deviation from its specification. (2) An affirmative indication or judgment that a product or service has met the requirements of the relevant specifications, contract, or regulation; also the state of meeting the requirements.
Registration - no definition
Regards,
Dirk
Randy
#43
Actually Registration is the entering of an organization into a "Register" and that's where the term "Registrar" comes from.
V
vanputten
#44
I received the following information from Dennis Arter (the Audit Guy, www.auditguy.net.)
Dennis asked me to remind Covers that the following are his interpretations of the standards and their history. Dennis has a lot of history to offer in this discussion.
From Dennis:
Conformance deals with product characteristics (form, fit, function) and can
be determined through inspection and test. The key word here is PRODUCT.
This was the original idea behind conformity assessment, which grew out of
the need in international trade to find a trusted, neutral party, to
determine if a shipload of grain, for example, should be accepted. It
started under GATT and is now used all over the world under WTO.
Unfortunately, when the concept was applied to systems in the 1980s, they
continued to use the same nomenclature.
Compliance adds the elements of process and system to product. Not only is
the item conforming, as determined through inspection, but it was produced
in accordance with approved process procedures and under an approved system. Nobody (in their right mind) should ever sign a Certificate of Compliance, as it is a best guess at most.
Certification is the act of declaring someone or something CONFORMING. It
involves measurement and test, with actual QC data to back it up.
Registration is the act of declaring an organization in COMPLIANCE with a
set of rules. When it involves actual demonstration of technical competence,
it is called Accreditation. When the Europeans refer to Certification, they
are referring to the piece of paper and actually mean registration.
How one wishes to use these words in their firm is entirely up to them. No
committee has the right or authority to say otherwise, except when it comes
to PRODUCT. You can declare product to be conforming to a technical
specification or standard, providing you have QC data behind the statement.
You cannot declare product in compliance, unless you can back it up with
hard data, which is impossible to do. You can declare your management
systems and processes to be in compliance, if you have good (judgement word) internal reports and audits to back up the statement.
The most common terminology is to say, "We are compliant to [standard xxx]."
That standard may be a requirement or guidance document.
The registrars do this every day, by requiring their audit programs to be
compliant to ISO 19011. As you know, that is a guidance document."
Regards,
Dirk
Paul Simpson
#45
Spot on, Randy. Under one or more of the ISO / IEC guides (I'm sure someone can help me with which) the certification body is required to maintain a register of those organizations it has issued a certificate to. Hence some organizations offer a "certificate of registration" and the organizations become a "registered firm."
BTW I prefer certification body to registrar - anyone else have a preference?
Randy
#46
Thank you Paul...
Here in the states the term certifiy more often than not carries with it the legal overtones of absoluteness thus the preference for the Registration of a system as opposed to the Certification. Sounds dumb but with a million starving lawyers it's another method of risk management.
Paul Simpson
#48
Thank you Paul...
Hey, Randy. Thanks - you made my day. Getting to use "starving" and "lawyers" in the same sentence. :lmao:
#49
Emphasis added to highlight the fact that Mr. Arter is apparently making up his own definitions.
Dennis Arter said:
Conformance deals with product characteristics (form, fit, function) and can be determined through inspection and test. The key word here is PRODUCT...
Compliance adds the elements of process and system to product. Not only is the item conforming, as determined through inspection, but it was produced in accordance with approved process procedures and under an approved system. Nobody (in their right mind) should ever sign a Certificate of Compliance, as it is a best guess at most...
set of rules...
Maybe it's me, but I got lost somewhere in the middle of those definitions and was unable to find my way back out again. Fact: "conformance" and "compliance" are synonymous for all intents and purposes, unless there are codified normative definitions that say otherwise. Is Arter saying that if I say my product is in compliance with the specifications, he might not know what I mean? And what about Arter's definition of "conformance"? Is he saying that it's somehow different from the ISO use of "conformity"?
Unless, as I suggested before, there's some normative requirement that dictates definitions.
Dennis Arter said:
No committee has the right or authority to say otherwise
Of course they do, but only if one agrees to it, as would be the case in an ISO registration (or even compliance) process.
Dennis Arter said:
...except when it comes to PRODUCT. You can declare product to be conforming to a technical specification or standard, providing you have QC data behind the statement.
I don't know what Arter means by "technical specification," but I can certainly certify that my product is in compliance with specifications and that it conforms with customer expectations and not fear that anyone won't know what I'm talking about.
Dennis Arter said:
You cannot declare product in compliance, unless you can back it up with hard data, which is impossible to do.
Sorry, but this makes no sense, even using Arter's definition of "compliance." Maybe he was in a hurry. Putting the statement another way, he seems to be saying, "In order to claim 'compliance' of a product, you need hard data, and it's impossible for hard data to exist." :confused:
One of the things that really irks me is people who want to take reasonably simple ideas, put them through a grinder, and render them incoherent. "Compliance" and "conformance" mean the same thing, and it doesn't help anything to try to assign meanings to them that they don't need. If you want to know what a word means, look in a good dictionary, and never stray from standard definitions without dam good reason for doing so. Making up your own definitions is a recipe for confusion, fear and loathing.
A Self-training or Self-studying ISO 13485:2016 - Medical Device Quality Management Systems 8
K MDR Class 1 Self Certification - Competent Authority or Notified Body? EU Medical Device Regulations 6
M Control-self assessment Internal Auditing 5
Q Self-assessment audit information Quality Management System (QMS) Manuals 6
S User evaluation for self monitoring blood glucose test systems US Food and Drug Administration (FDA) 4
S Supplier Management ISO 13485: 2016- Which supplier needs to fill in a self assessment form? ISO 13485:2016 - Medical Device Quality Management Systems 6
E HONDA HAA QAV-1 Self Assessment General Auditing Discussions 4
T Formal Q Self Assessment - Problem with assigning Product and Process Customer and Company Specific Requirements 1
G Self Assessment Audit from a new potential customer General Auditing Discussions 3
M CE self-certification for Class I device (face mask) EU Medical Device Regulations 9
M Informational US FDA – Ear, Nose, and Throat Devices; Classification of the Self-Fitting Air-Conduction Hearing Aid Medical Device and FDA Regulations and Standards News 0
K Intended Use-Class I Self Certified - Intended Use and Indications for Use statements EU Medical Device Regulations 1
Ed Panek Part 11 Self Certify Memo - What else should it cover? Qualification and Validation (including 21 CFR Part 11) 5
M Informational TGA Consultation: Review of the regulation of certain self-testing IVDs in Australia Medical Device and FDA Regulations and Standards News 0
J Good Documentation Practices Self Test? ISO 13485:2016 - Medical Device Quality Management Systems 6
C CE marking for general IVD (self-certified) & ISO 13485 QMS requirements - auditing EU Medical Device Regulations 6
MichaelDRoach Oganization's Self Declaration of Conformance to ISO 28000 wording example wanted Supply Chain Security Management Systems 1
M Medical Device News TGA – Regulator Performance Framework: Self-assessment Report, July 2017 to June 2018 Medical Device and FDA Regulations and Standards News 0
A Selling CE marked self-test in Malta - any additional requirements? EU Medical Device Regulations 0
M CE self-certify, or needs testing by 3rd party? CE Marking (Conformité Européene) / CB Scheme 12
M Notified Body Involvement with Self Declared Products EU Medical Device Regulations 7
S Help: Need Control Self Assessment Questionnaire for HR Departmental Functions Process Audits and Layered Process Audits 0
T IVD - Self Declaration - Technical File - Template wanted Various Other Specifications, Standards, and related Requirements 9
R Documenting Self-Training and Effectiveness - ISO 13485:2016 Training - Internal, External, Online and Distance Learning 4
K ISO 13485:2016 Self Certification for Class I (annex 9) Stand-Alone Software? ISO 13485:2016 - Medical Device Quality Management Systems 3
S ISO9001:2015 and ISO14001:2015 Readiness/Self Evaluation Checklists wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
N MDD Class I Medical Device Self Declaration Articles/Supplementary Documents EU Medical Device Regulations 1
A Self-study plan to improve fluency in English speaking, writing After Work and Weekend Discussion Topics 3
Crusader Interval for Self-Calibrating Measurement Device? Calibration Frequency (Interval) 15
T Transition Time for Self Declared IVDs EU Medical Device Regulations 3
Z IVD Self Test Pregnancy - Assessment Route? EU Medical Device Regulations 5
S Anyone know the self-selection study for home use medical device Other US Medical Device Regulations 2
D Off-Label Self Promotion - What to do EU Medical Device Regulations 3
B Own Brand Labelling and Distributors - Self Test IVD's EU Medical Device Regulations 3
S Creating goals and objectives with targets and measurables for self-evaluations Management Review Meetings and related Processes 2
C Help with Risk/Benefit Analysis Self-help Device for Diabetics ISO 14971 - Medical Device Risk Management 3
B Self Contained Biological Indicators as internal PCD Other Medical Device Related Standards 2
T Self Declaration for CE Class I, Non-Invasive Medical Device EU Medical Device Regulations 10
R Self-Certification Is Not a Real Thing - an IAF article Registrars and Notified Bodies 13
T Should a supplier self assessment form be a controlled document? Document Control Systems, Procedures, Forms and Templates 9
C Vendor Self-Survey to Qualify Vendors/Suppliers - AVL Question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Annex III self declared IVD to be in use with Annex II List B IVD EU Medical Device Regulations 1
S SAE AS9015 Supplier Self Verification Process - Delegation Programs. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B FDA Product Classification - Self Treatment Software Applications 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
P Changing from contract manufactured to self manufactured 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A R2 Certification vs Self Declaration to ISO 14001 and OHSAS 18001 ISO 14001:2015 Specific Discussions 3
Marc Ford - Self-parking technology called Fully Assisted Parking Aid World News 1
L IVDD 98/79/EEC - Can I self declare? EU Medical Device Regulations 2
P ISO/TS 16949:2009 Compliance - Self Declaration Audit IATF 16949 - Automotive Quality Systems Standard 4
B CCNA (Cisco Certified Network Associate) Self Study Help? Professional Certifications and Degrees 3
