Selling Clinical Practice Advice
SSchoepel
Either I'm not searching for the right terminology or this isn't an issue, but I'd like to check the Elsmar brain-trust.
I have been asked to review a large document created by our medical device company on how to set up a certain type of screening program within a clinic. From what I've been told we are going to sell this document/advice on how to set up the program. The document contains a few little spots where our product is referenced (like "Product X can help track this") but it's not heavy-handed. It is basically a very long white paper that covers how to set up your administrative staff, to the type of scan (even to say the level of mGy), to pricing/cost for the protocol. It does contain a ton of references and states it was created per some ACR practice guidelines. So that's what it is in a nutshell.
Where I'm concerned is that I've been told it's going to be sold as an offering with/along side our product. Our product is a radiology PACS. It's not off-label use since it's 95% information outside of the use of a PACS within the whole cycle and does not recommend anything outside of the intended use of our product. However, it's still 95% outside of the scope of our product, though we have an expert in the clinical practice as part of our company. Are there regulations or guidance documents on what else you can "sell" or offer as part of your company offering? I just want to be sure I'm not missing some consideration.
Watchcat
What do you mean by "our medical device company"? Is it a company that "we" own? Who is "we"? Your company? Is this the same "we" that is going to sell the document? If your company isn't a medical device company, what kind of company is it?
Please define:
mGy
ACR
PACS
whole cycle
Please clarify:
How can it not recommend anything outside of the intended use of your product and still be 95% outside of the "scope" of your product?Perhaps it would be helpful if you also defined "scope" as you are using it to refer to your product.
SSchoepel
Please define:
mGy
ACR
PACS
whole cycle
Please clarify:
Sorry. Yes, "we" and "our" is the medical device company for which I work.
That device is a PACS - picture archiving and communications system - which is an image review software for radiologists.
mGy is milliGray which is a measure of radiation dose from a CT scanner.
ACR is the American College of Radiology
"whole cycle" is the cycle from patient appointment, determination to do a screening scan, reading the scan (where we would fit in with our device), follow-up, recommendations, and reporting and billing the scan.
The document talks about all those pieces in the "whole cycle" and only has little references to things our product can do. It's not recommending anything outside of standard screening protocols as outlined by professional associations, and it's not recommending clinicians do anything specific with our product. Our product sits in a very small portion of the cycle (reading the scan).
Watchcat
What you describes sounds very similar to sales reps distributing published articles relevant to their product. This sometimes pops up in discussions of off-label use, because sometimes the articles describe an off-label use, and sometimes off-label promotion is the intent of the sales rep, however much they might deny it.
As long as the white paper is not distributed with the product (a customer buying both at the same time is not you distributing them both together), I don't think FDA would consider it labeling. I think any reference to your product is likely to get the white paper tagged as advertising or marketing, given that your company is the one that both wrote it and distributes it.
If you have been searching for regulatory guidance on advertising and marketing, then you have probably been using the right terminology. If you haven't found anything on point, it's probably because this sort of thing isn't usually done (I don't think). I also don't think the fact that your company wants to sell it instead of giving it away has any regulatory impact.
So I would review it like any other marketing or advertising material, to assure that it doesn't make any claims outside of those found in your IFU. (I am assuming you have one).
I might also revise statements like "Product X can help track this" to say something more like "image review software like Product X can help track this," just on regulatory instinct, not because I know of any specific guidance or regulation that says so.
Watchcat
Oh, you might also try something like medical/clinical education/training, since that seems like what this document might be striving for? I don't know if FDA (I assume that's the agency you are worried about) has addressed this type of activity. Might well have, since I'm pretty sure some clever sales reps have tried to pitch their products under this guise as well.
markl368
I have a slight twist to this question. If a company does not make a medical device or pharmaceutical, but attaches links on the company website to research where products have been clinically evaluated in such use (off-label), is the company making implied claims by posting these links, even if the company makes an express statement that it "makes no claims" as such? I think these would still be applied claims. And if you have an example of a case where this is so, that would be helpful.
Mark Meer
... If a company does not make a medical device or pharmaceutical, but attaches links on the company website to research where products have been clinically evaluated in such use (off-label), is the company making implied claims by posting these links...
I believe this is what the FDA would refer to as a "solicited" off-label (see examples in this draft guidance), which is dicey territory.
Regardless of the stance of the FDA, however, on its face this practice seems a bit sketchy. You're posting links to off-label uses, but then claiming you're not making any claims as to the uses linked? ...seems a bit disingenuous to me, but's that's just my opinion. ;)
markl368
Thanks- I totally agree with you but I had not seen the guidance you referenced. This has been VERY helpful!
T MDSAP readiness - Selling clinical product IVDs into Canada Canada Medical Device Regulations 7
T Selling an Unapproved Investigational Device for Clinical Studies ISO 13485:2016 - Medical Device Quality Management Systems 2
A Selling products with OEM certification expired EU Medical Device Regulations 0
dinaroxentool Selling a product in Both UK and EU after Brexit UK Medical Device Regulations 9
V Sister companies selling same medical device under different names ISO 13485:2016 - Medical Device Quality Management Systems 3
D Interesting Discussion Requirements for selling a Food product in USA Food Safety - ISO 22000, HACCP (21 CFR 120) 0
I Selling medical gown and mask in China China Medical Device Regulations 0
M Selling Medical Devices in Puerto Rico US Food and Drug Administration (FDA) 3
N Selling a class II Medical Device in Canada in Pharmacies Elsmar Xenforo Forum Software Instructions and Help 10
K Selling Medical Device Components to US hospitals and doctors US Food and Drug Administration (FDA) 4
C Does the company violates any regulation/standard by selling device without warranty ISO 13485:2016 - Medical Device Quality Management Systems 5
M Informational FDA order – All manufacturers of surgical mesh intended for transvaginal repair of anterior compartment prolapse (cystocele) to stop selling and distr Medical Device and FDA Regulations and Standards News 0
T RISK: Selling Diagnostic Devices on Amazon Manufacturing and Related Processes 0
A Selling CE marked self-test in Malta - any additional requirements? EU Medical Device Regulations 0
R Medical Device (IVD) - Selling RUO to Customers EU Medical Device Regulations 2
K Selling Medical Devices in Canada - Distributor? Private Label? Canada Medical Device Regulations 10
D Selling Medical Device Abroad After the Expiring Date of the EC Certificate EU Medical Device Regulations 5
S Selling Medical Demo Devices - is it allowable? ISO 13485:2016 - Medical Device Quality Management Systems 2
B Selling with a Medical Device App EU Medical Device Regulations 4
T New to WEEE Directive - Selling a medical device directly to a professional end-user RoHS, REACH, ELV, IMDS and Restricted Substances 1
P Selling Medical Devices from the US into Israel Other Medical Device Regulations World-Wide 2
N Registering a Class 1 Sterile Medical Device - Currently selling a Non-Sterile 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
M Selling Medical Device DTC in FL - Need a license? Other US Medical Device Regulations 1
JoCam Buying and selling Class I and II medical devices EU Medical Device Regulations 1
A Selling our own class 1 (EU) devices worldwide - Who is responsible for registration? Other Medical Device Regulations World-Wide 7
W Legality of selling parts by count - Counting Scales Quality Manager and Management Related Issues 6
M Class I Medical Device - Need to notify CA (Competent Authority) if selling in Asia EU Medical Device Regulations 4
B What is the FDA guidance regarding selling replacement parts and traceability? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
B Selling Medical devices to Iran - OFAC doubts Other Medical Device Regulations World-Wide 6
D What are the requirements for selling Alcohol Swabs in USA 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
R Selling of Medical Power Supply in Australia/New Zealand and Japan Other Medical Device Regulations World-Wide 5
Marc LinkedIn Accused Of Secretly Selling Members Professional Data To Potential Employers World News 9
S Manufacturing and Selling Medical Devices with Used Components ISO 13485:2016 - Medical Device Quality Management Systems 3
C Selling of Research products in Europe EU Medical Device Regulations 9
G QMS - Selling the idea to the CEO! Quality Manager and Management Related Issues 8
S Regulations for Selling Convenience Kit vs. Selling Separate Parts Other US Medical Device Regulations 2
E Documentation for selling Prescription Only Medical Devices Other Medical Device and Orthopedic Related Topics 8
B Additional requirements for selling Class I Medical Device in Poland EU Medical Device Regulations 3
S Selling a CE Marked Product to a Hospital in Bulgaria Other Medical Device Regulations World-Wide 4
Ronen E ISO is Selling Draft Standards ISO 13485:2016 - Medical Device Quality Management Systems 7
Marc Boeing caught selling used parts as new to Pentagon (Oct 2013) World News 3
Q Internal Laboratory Services - Selling Services to "Outside" Customers General Measurement Device and Calibration Topics 1
B Selling Class IIa Medical devices in Albania Other Medical Device Regulations World-Wide 1
M "Selling" the idea of using Work Orders ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G Selling a CE mark Class I Medical Device in Sweden - Any other requirements? EU Medical Device Regulations 13
I Selling Over the Counter Medical Devices in France EU Medical Device Regulations 3
Z Foreign Manufacturer selling in the US - Postmarket Surveillance question Other US Medical Device Regulations 2
P Selling Joint Implants without a Validated Process Manufacturing and Related Processes 8
R Selling Directly to Physicians in Turkey EU Medical Device Regulations 4
A Selling Medical Devices and/or Accessories Online US Food and Drug Administration (FDA) 11
