Selling Joint Implants without a Validated Process
P
phloQS
Hi all,
I have a big problem in our company. We have several machining processes and want to validate them, to fulfill the requirements of ISO13485 (special processes) and 21CFR820.75. The problem is, that the processes development itself is not finished yet, but we already want to sell the products. For this, we do a 100% end control of all products. In our opinion, all critical aspects are covered by tests. The IQ activities for the machining centres are done, but we are not able to do anymore, because there are still many changes in the different processes. Is it ok to sell the products or what else could we do?
Regards
phloQS
qusys
Re: Selling without a validated process
Does the product meet customer requirments? Do you have a contract or P.O with your customer for this supplying? Did you sign off a PPAP ? Did you qualify your product with acceptable results for the customer? Do you have enough capacity and capability to ensure the agreed supplying with linearity?
Do you have some plan to fix eventual still pending issue? What is their criticality? How do you manage the risk for the product?
In brief, which are the criteria that you have set to say that a product is ready to the market?
These are some of the questions, but not limited to, you could think at. :bigwave:
MIREGMGR
If you're selling components to some other company and they're a medical device manufacturer but you're not, per 21CFR 807, I don't see a problem with 21CFR 820. If what you produce meets your customer's specs, and if they choose to control that conformance via verification rather than validation, you're good to go.
If on the other hand you want to sell your products as medical devices, your situation is more complicated. If your products will be USFDA Class I and exempt, you may be OK. It however is likely to be difficult given your circumstances to convince FDA to approve a 510(k) or other pre-market clearance.
G
Gert Sorensen
A bit more detail about the products and your company may help us help you. As listed above, whether you are supplying or manufacturing for distribution matters. The product also matters. So, please provide more detail.
P
phloQS
The products are joint implants and we are selling them as medical devices. We are in the european market since about 20 yeras. We never had a problem with the german NBs. They alwayws accpeted our endcontrols. But now a consultant told us that we definetely have to validate NC-processes as they are special prcoesses according to 21CFR820.75. I am honest, in my opinion we do not need a full validation in regard to safety because of our strict end-controls. Of cource we also have maitenance plans and traings for our staff and so on. But now we collect all this in a validationrecord. We wanna test our nc cutting machines with a standard nc-programm made by NCG (German NC-Association). Would that be ok for OQ? After that, we do a performance check by collecting and analysing data via our CAQ-Software. The basis of all this was a risk analysis based on the key attributes of our implants (surface,dimensinal stability, tolerances of position).
Rgeards
phloQS
somashekar
Hi all,
I have a big problem in our company. We have several machining processes and want to validate them, to fullfill the requirements of ISO13485 (special processes) and 21CFR820.75. The problem is, that the processesdevelopement itself is not finished yet, but we already want to sell the products. For this, we do a 100% endcontrol of all products. In our opinion, all critical aspects are covered by tests. The IQ activities for the machining centres are done, but we are not able to do anymor, because there are stuill many changes in the different processes. Is it ok to sell the products or what else could we do?
Regards
phloQS
I am also wondering if you had been all along making things in some controlled way and meeting the requirement, and that you now are looking at validation of your processes in retrospect to fulfill the requirements with the ISO13485 .. ?
Can you comment please ?
Ahhhh something wrong here. Please help us by listing your processes that makes your devices. You may not have a validation of processes requirement....
G
Gert Sorensen
OK, so you have been on the european market for 20 years. How long have you been on the american market?
Special processes should usually be validated, however for NC cutting it is not per definition required (GHTF/SG3/N99-10:2004 (Edition 2), section 3.2)
I think you should be able to demonstrate that inspection is enough, depending on the output and the inspection.
You should validate the NC-software, and qualify the equipment, all based on your risk asessment.
:bigwave:
MIREGMGR
Sec. 820.75 Process validation.
(a) Where the results of a process cannot be fully verified by subsequent inspection and test, the process shall be validated with a high degree of assurance and approved according to established procedures.
When a product can be and is verified as to conformance to specifications, and particularly if you have a significant body of historical evidence supporting your risk analysis and clinical safety/effectiveness stance to the effect that those specifications are sufficient to assure safety/effectiveness, I don't understand why it would be stated by your consultant that validation is required.
Of course, if you were arguing that verification were possible but you weren't actually verifying every unit, that'd be a different kettle of fish.
But if each unit of product is verified, I think you're good to go.
21 CFR 820.75 does not include the word "special". Per my reading, there is no text in this section that defines some processes that must be validated and cannot be verified, other than that which is quoted above.
Many joint implants are FDA Class II devices. If you're already marketing in the US, there must be a 510(k), filed either by you or if you've been a 21 CFR 807.65 component maker for someone else, probably by them. What does it say about validation and verification?
cuteprettyone
Hi all,
Regards
phloQS
Validating "special process" is focused on the changes in manufacturing that can affect product characteristics and ensuring the PROCESS that is used to produce the product does not adversely affect the finished goods.
It depends on the process and the output of the process. For example, EDM process can cause heat affected zones, recast, and microcracking. If you can inspect/verify that each product manufactured on the EDM is free of heat affected zones, recast, and microcracking (defects that can be caused by the EDM process) then validation is not required. However, if you cannot the process must be validated even if the process manufactures each feature within specification. Validation is focused on the PROCESS and the impact the process can have on the product.
A Selling products with OEM certification expired EU Medical Device Regulations 0
dinaroxentool Selling a product in Both UK and EU after Brexit UK Medical Device Regulations 9
V Sister companies selling same medical device under different names ISO 13485:2016 - Medical Device Quality Management Systems 3
D Interesting Discussion Requirements for selling a Food product in USA Food Safety - ISO 22000, HACCP (21 CFR 120) 0
S Selling Clinical Practice Advice Other US Medical Device Regulations 7
I Selling medical gown and mask in China China Medical Device Regulations 0
M Selling Medical Devices in Puerto Rico US Food and Drug Administration (FDA) 3
N Selling a class II Medical Device in Canada in Pharmacies Elsmar Xenforo Forum Software Instructions and Help 10
K Selling Medical Device Components to US hospitals and doctors US Food and Drug Administration (FDA) 4
C Does the company violates any regulation/standard by selling device without warranty ISO 13485:2016 - Medical Device Quality Management Systems 5
M Informational FDA order – All manufacturers of surgical mesh intended for transvaginal repair of anterior compartment prolapse (cystocele) to stop selling and distr Medical Device and FDA Regulations and Standards News 0
T RISK: Selling Diagnostic Devices on Amazon Manufacturing and Related Processes 0
A Selling CE marked self-test in Malta - any additional requirements? EU Medical Device Regulations 0
R Medical Device (IVD) - Selling RUO to Customers EU Medical Device Regulations 2
K Selling Medical Devices in Canada - Distributor? Private Label? Canada Medical Device Regulations 10
D Selling Medical Device Abroad After the Expiring Date of the EC Certificate EU Medical Device Regulations 5
S Selling Medical Demo Devices - is it allowable? ISO 13485:2016 - Medical Device Quality Management Systems 2
B Selling with a Medical Device App EU Medical Device Regulations 4
T MDSAP readiness - Selling clinical product IVDs into Canada Canada Medical Device Regulations 7
T New to WEEE Directive - Selling a medical device directly to a professional end-user RoHS, REACH, ELV, IMDS and Restricted Substances 1
P Selling Medical Devices from the US into Israel Other Medical Device Regulations World-Wide 2
N Registering a Class 1 Sterile Medical Device - Currently selling a Non-Sterile 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
M Selling Medical Device DTC in FL - Need a license? Other US Medical Device Regulations 1
JoCam Buying and selling Class I and II medical devices EU Medical Device Regulations 1
A Selling our own class 1 (EU) devices worldwide - Who is responsible for registration? Other Medical Device Regulations World-Wide 7
W Legality of selling parts by count - Counting Scales Quality Manager and Management Related Issues 6
M Class I Medical Device - Need to notify CA (Competent Authority) if selling in Asia EU Medical Device Regulations 4
B What is the FDA guidance regarding selling replacement parts and traceability? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
B Selling Medical devices to Iran - OFAC doubts Other Medical Device Regulations World-Wide 6
D What are the requirements for selling Alcohol Swabs in USA 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
R Selling of Medical Power Supply in Australia/New Zealand and Japan Other Medical Device Regulations World-Wide 5
Marc LinkedIn Accused Of Secretly Selling Members Professional Data To Potential Employers World News 9
S Manufacturing and Selling Medical Devices with Used Components ISO 13485:2016 - Medical Device Quality Management Systems 3
C Selling of Research products in Europe EU Medical Device Regulations 9
G QMS - Selling the idea to the CEO! Quality Manager and Management Related Issues 8
S Regulations for Selling Convenience Kit vs. Selling Separate Parts Other US Medical Device Regulations 2
E Documentation for selling Prescription Only Medical Devices Other Medical Device and Orthopedic Related Topics 8
B Additional requirements for selling Class I Medical Device in Poland EU Medical Device Regulations 3
S Selling a CE Marked Product to a Hospital in Bulgaria Other Medical Device Regulations World-Wide 4
Ronen E ISO is Selling Draft Standards ISO 13485:2016 - Medical Device Quality Management Systems 7
Marc Boeing caught selling used parts as new to Pentagon (Oct 2013) World News 3
Q Internal Laboratory Services - Selling Services to "Outside" Customers General Measurement Device and Calibration Topics 1
B Selling Class IIa Medical devices in Albania Other Medical Device Regulations World-Wide 1
M "Selling" the idea of using Work Orders ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G Selling a CE mark Class I Medical Device in Sweden - Any other requirements? EU Medical Device Regulations 13
I Selling Over the Counter Medical Devices in France EU Medical Device Regulations 3
Z Foreign Manufacturer selling in the US - Postmarket Surveillance question Other US Medical Device Regulations 2
R Selling Directly to Physicians in Turkey EU Medical Device Regulations 4
T Selling an Unapproved Investigational Device for Clinical Studies ISO 13485:2016 - Medical Device Quality Management Systems 2
A Selling Medical Devices and/or Accessories Online US Food and Drug Administration (FDA) 11
