Separate attribute MSA study required for each Go/No Go gauge?
sadhusong
everybody
i met a supplier that first she told me the attribute date (such as Go/ No Go gauge) can not do the MSA study, after i show the AIAG to her, then she said to me for all attribute Gauges one MSA study is enough!:biglaugh:
she means all Go/ No Go gauge is similar, so they need do a MSA study!
anybody can tell me do we need do separate attribute MSA study for maybe each Go/No Go gauge?
thanks very much!:applause:
Jen Kirley
Quality and Auditing Expert
I can't imagine doing one MSA study to cover a group of gages. One gage can be within specs while another is not. I do not understand the idea of group GR&R. :confused:
Y
Yew Jin
The main purpose we do the MSA is to segregate the measurement variation and the actual process variation from the observed variation in the line.
We can study what ever we want in the MSA like stability, linearity, bias or GR&R on the go no go gage but it is depended to its intend use or application in the line.
We might need to understand on how the design team set the gap allowance to control or detect our non conformance product. Are they using the worst case analysis? What is the gage limitation? Do we have any alpha or beta risk when we use the gage?
After we understand and have the clear cut on its limitation then only we can evaluate its efficiency of the gage by using the attribute GR&R. Beside that any cosmetic reject can be caused by the application of the gage? Any problem on the ergonomic issue when doing over time by an operator?
I believed if we have above outcomes in the validation study then we can qualify the gage and release to the line and keeping monitoring on its worn out time or stability.
Bill Ryan - 2007
When I have a dozen or better pin/plug gages for a part, I pick the tightest toleranced feature and perform a Gage R&R on that pin/plug gage. That covers all the others in my thinking. 'In or Out of specs" is taken care of through the calibration process. This is strictly an economic choice of my company.
Functional type gages (MMC pins) are a different matter. They are typically dedicated and Gage R&Rs are routinely done on those.
:2cents:
L
lee.moffatt
A very good question, and I don’t thing there is a definitive answer, it all depends on the gauge, part, process and company.
It has been my insistence that all these ‘monitoring’/ ‘understanding the process’ control methods must not take over the business to such a degree it affects the bottom line, or that it takes over from what the business is about. . . making money!
With regards to the question, you shouldn’t be doing, in my opinion, a Gauge R&R on every single measuring device within a device type its counter productive, and frankly stupid. For instance, the company I’m currently work for has over 300 0 - 25mm micrometers that are all used to measure various parts, you think I’m going to instruct them to do a Gauge R&R for each micrometer, I don’t think so, it would not benefit them in the slightest. I would however, instruct them to do a Gauge R&R for each part.
At the end of the day, providing the gauge is fit for purpose then you have be able to group them, there is no other feasible alternative. Having said that this instruction is based on micrometer type devices, I wouldn’t group CMM’s laser trackers and the like.
Another thing, yes it is true your trying to separate measurement variation from the process, but what your really doing is making sure the final result is not influenced by the gauge itself, albeit accuracy/ repeatability, the operator influence, the environment (is the guy stretching over to take a measurement and only takes a quick rough measurement) and so on. It’s the full measurement process not just the gauge.
Rergards
Atul Khandekar
Generally:
1. A critical measurement step in the process (for monitoring, SPC...)
2. Final inspection prior to shipping to the customer
3. Where customer demand MSA.
even if they are gages of the same type / similar. (my 2c)
L Separate Corrective Action and Preventive Action Procedures ISO 13485:2016 - Medical Device Quality Management Systems 13
C Warehousing two separate components to a finished device while meeting regulations Other US Medical Device Regulations 7
D ISO 13485 - 7.3.6 Design and development verification - Do most folks create a separate SOP? ISO 13485:2016 - Medical Device Quality Management Systems 6
H ISO 13485 - Separate Microbiology Audits ISO 13485:2016 - Medical Device Quality Management Systems 8
M UDI Database and EUDAMED - Will there be two separate databases? EU Medical Device Regulations 4
I Can a document (form) approval record be separate? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Organization merger. Should we keep two separate ISO 13485 certificates? ISO 13485:2016 - Medical Device Quality Management Systems 6
CPhelan Internal audit - Combine similar nonconformities in one or keep separate? Internal Auditing 6
S "X-MR charts do not separate piece-to-piece repeatability of the process" Statistical Analysis Tools, Techniques and SPC 2
R How far apart can you schedule separate areas or departments in your internal audit? Internal Auditing 4
S Do we need separate stand alone procedure for Suspect Unapproved Parts? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
J Facilities - Placing our assembly group into a separate building ISO 13485:2016 - Medical Device Quality Management Systems 8
W Product Audit - It must be a separate and distinct activity (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 4
C ISO 14001 vs Existing Quality System - How to keep them separate? ISO 14001:2015 Specific Discussions 3
T Should Testing be a separate operation in the Control Plan? FMEA and Control Plans 5
P Two separate 510k submissions for one device from the same company Other US Medical Device Regulations 10
B ISO 9001:2015 8.4 External Providers - If work is transferred to a separate facility ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Is a separate ISO/TS16949 certificate required for an extension site? IATF 16949 - Automotive Quality Systems Standard 4
T Two Separate Businesses - Only Part of Company Certified ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D Separate Classifications for Medical Device Accessories EU Medical Device Regulations 2
R One-Time parts separate from QMS? Quality Manager and Management Related Issues 9
D Is a separate spreadsheet required for the ASL (Approved Supplier List)? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
R Connection to a generic separate power supply IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
S Regulations for Selling Convenience Kit vs. Selling Separate Parts Other US Medical Device Regulations 2
cscalise Separate Forms or Procedure Attachments - What's more common? Document Control Systems, Procedures, Forms and Templates 2
C Do separate sites need separate documents? Document Control Systems, Procedures, Forms and Templates 7
A Newly Incorporated Business - Separate Scope and/or Separate Cert? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
L Should Internal Audit CAPAs be kept separate from "normal" CAPAs? ISO 13485:2016 - Medical Device Quality Management Systems 6
P Separate procedures? ISO 14k System combined with OHSAS 18001 Occupational Health & Safety Management Standards 3
J Device Registration and Listing - Separate for Device and corresponding Instruments? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
C How to handle Outsourcing with Same Site - Separate Cert ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B Two Separate Legal Entities - Manufacturer Vs. Contract Manufacturer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 20
Q Separate Quality System? Product line of a parent company spins off 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
P How to separate Product Design Review, Verification, and Validation Activities ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
C What can you do if Quality is treated as a separate function in an organization? Quality Manager and Management Related Issues 24
C Separate Certification - Can I combine documents for ISO14001, OHSAS18001 & AS4801? Miscellaneous Environmental Standards and EMS Related Discussions 3
S IEC 62366 - Embedded Software in separate Usability Engineering File? IEC 62366 - Medical Device Usability Engineering 1
K How do ISO 9001 Requirements apply to 2 sets of specifications to 2 separate vendors? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Include as an attachment or make a separate document? Advise on Document Numbering Document Control Systems, Procedures, Forms and Templates 1
F Multiple Business Lines (Separate Corporations) in one Facility AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
B Separate Clinical Trials in the US and the EU - When one fails - question US Food and Drug Administration (FDA) 3
M Can I be a legal manufacturer without being a separate legal entity? CE Marking (Conformité Européene) / CB Scheme 6
B Hospital Operating Room Regulations - Separate Entrances for Clean and Dirty Supplies Hospitals, Clinics & other Health Care Providers 4
S Separate Medical Device 12V Power Source - What inspection and testing is required? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M Does ISO/IEC 17025:2005 require the Laboratory to have separate ISO 9001 Procedures ISO 17025 related Discussions 4
R HVAC Contaminant Test for Two Separate Areas Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 6
R CNC OTS Software Validation Separate from full IQ/OQ/PQ for 21CFR Part 820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
S Accessing data from separate worksheets in Minitab Using Minitab Software 3
Q Corrective Action as a Separate Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Separate Quality Manuals for Different Sites Quality Management System (QMS) Manuals 3
