Hello, I saw the very old thread related to Separate or Combine CAPA procedures, but I am looking for some more recent guidance/news.
I recently changed jobs from one of the big Medical Device Manufacturers (class II and III devices) to a small company that has mostly unregulated but some class I devices which just had their 1 year ISO 13485 surveillance audit a month before I arrived. The company is very much immature in their transition from 'job shop' to medical device manufacturer.
One of the findings was related to insufficient documentation in the CAPA procedure detailing requirements to determine a PA. As a correction the company apparently told the auditor they were going to split the CAPA procedure up in order to address the finding-based on the auditor telling them it should be split up. I'm having a disagreement stemming from my interpretation of the finding and ultimately the appropriate correction to be making. Per the individuals I am working with, this company was told by the auditor that the term CAPA is not being used in international regulations/standards as they are being revised, and I was further told that IMDRF specifically call this out as two separate processes and that the FDA will move forward to emphasize two separate processes.
Not only is this the first time I've heard this (having a fair share of regulatory involvement and external auditor interaction as front room lead at my previous large company), I have also been trying to find any discussion on the web about it and am coming up empty. Am I being given run-around as the new guy coming in with unwanted ideas, or is this an actual movement within the industry to require CAPA be split into two different procedures? Also I don't want to get into a discussion of what path is correct (probably either depending on the company situation), just curious on requirements.
Thank you.
Thank you.
