Separate Medical Device 12V Power Source - What inspection and testing is required?
SteveK
Planning to run a Class IIa device on a 12V external power adaptor (which drives an internal 12V pump/motor) i.e. which itself plugs into the mains. Accordingly the whole thing then becomes a ME System as per IEC 60601-1 and clause 8.2.1 specifically (Connection to a separate power source). Now this clause then indicates that “Compliance is checked by inspection and by testing as specified in 5.5f.”
Fine so far; then you go to 5.5f – “If the instructions for use specify that ME EQUIPMENT is intended to receive its power from a separate power supply, it is connected to such a power supply.”
Well the instructions supplied will say this – so where is the inspection and testing indicated?
I have separately been told (this relates to a NB but cannot say anything else) that an approved 60601-1 Power Supply does not in itself guarantee that the “ME System as a whole” will meet requirements you need to provide evidence. The specification of the CE market adaptor indicates:
Conforms to Energy-related Product Directive 2009/125/EC
Approvals: UL recognised, TUV, CCC, CB
Standards: EN 60950-1, UL 60950-1, CSA C22.2
This device provides suction, so other than showing that the amount of suction indicated on the device is a true reading (via calibrated gauges) through bench testing when connected to this adaptor etc – what other evidence am I supposed to be looking for?
Sometimes trying to get your head around standards (especially 60601-1) causes mine to hurt!
Any advice/guidance would be appreciated.
Steve
Peter Selvey
Re: Separate Medical Device 12V Power Source - What inspection and testing is require
From a regulatory point of view, when using an "off the shelf" power supply (OTSPS), you will need to consider the following areas separately:
- electrical safety
- EMC
- performance (voltage regulation, ripple, noise, surge handling etc)
For: electrical safety, compliance with IEC 60950-1 is most likely OK for your case, assuming you have some intentional separation of the fluid path (patient circuit) and the secondary circuits, rather than have special isolation in the power supply.
For EMC: as long as you test the whole system with the designated OTSPS then it's OK. If you want to use a generic power supply it may need some more detailed argument to justify compliance.
For performance, it is simply a matter of checking compatibility of the power supply specs against your equipment needs. E.g. if the power supply regulation is +/-5%, and your equipment needs +/-10% then no problems. This is no different to using any other part or component. Again if you have a specific OTSPS in mind this is easy, but if you want to use a generic power supply you probably have to build some robustness in your device so it can handle poor quality regulation, noise etc.
For IEC 60601-1:2005, the performance side is not covered except through risk management (e.g. 7.2.5). Electrical safety is covered under Clause 16, which in effect says that IEC 60950-1 is OK. EMC is covered under Clause 17.
D Separate Classifications for Medical Device Accessories EU Medical Device Regulations 2
N CE Marking Medical Device with Software - together or separate? EU Medical Device Regulations 4
L Separate Corrective Action and Preventive Action Procedures ISO 13485:2016 - Medical Device Quality Management Systems 13
C Warehousing two separate components to a finished device while meeting regulations Other US Medical Device Regulations 7
D ISO 13485 - 7.3.6 Design and development verification - Do most folks create a separate SOP? ISO 13485:2016 - Medical Device Quality Management Systems 6
H ISO 13485 - Separate Microbiology Audits ISO 13485:2016 - Medical Device Quality Management Systems 8
M UDI Database and EUDAMED - Will there be two separate databases? EU Medical Device Regulations 4
I Can a document (form) approval record be separate? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Organization merger. Should we keep two separate ISO 13485 certificates? ISO 13485:2016 - Medical Device Quality Management Systems 6
CPhelan Internal audit - Combine similar nonconformities in one or keep separate? Internal Auditing 6
S "X-MR charts do not separate piece-to-piece repeatability of the process" Statistical Analysis Tools, Techniques and SPC 2
R How far apart can you schedule separate areas or departments in your internal audit? Internal Auditing 4
S Do we need separate stand alone procedure for Suspect Unapproved Parts? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
J Facilities - Placing our assembly group into a separate building ISO 13485:2016 - Medical Device Quality Management Systems 8
W Product Audit - It must be a separate and distinct activity (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 9
C ISO 14001 vs Existing Quality System - How to keep them separate? ISO 14001:2015 Specific Discussions 3
T Should Testing be a separate operation in the Control Plan? FMEA and Control Plans 5
P Two separate 510k submissions for one device from the same company Other US Medical Device Regulations 10
B ISO 9001:2015 8.4 External Providers - If work is transferred to a separate facility ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Is a separate ISO/TS16949 certificate required for an extension site? IATF 16949 - Automotive Quality Systems Standard 4
T Two Separate Businesses - Only Part of Company Certified ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
R One-Time parts separate from QMS? Quality Manager and Management Related Issues 9
D Is a separate spreadsheet required for the ASL (Approved Supplier List)? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
R Connection to a generic separate power supply IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
S Regulations for Selling Convenience Kit vs. Selling Separate Parts Other US Medical Device Regulations 2
cscalise Separate Forms or Procedure Attachments - What's more common? Document Control Systems, Procedures, Forms and Templates 2
C Do separate sites need separate documents? Document Control Systems, Procedures, Forms and Templates 7
A Newly Incorporated Business - Separate Scope and/or Separate Cert? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
L Should Internal Audit CAPAs be kept separate from "normal" CAPAs? ISO 13485:2016 - Medical Device Quality Management Systems 6
P Separate procedures? ISO 14k System combined with OHSAS 18001 Occupational Health & Safety Management Standards 3
J Device Registration and Listing - Separate for Device and corresponding Instruments? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
C How to handle Outsourcing with Same Site - Separate Cert ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B Two Separate Legal Entities - Manufacturer Vs. Contract Manufacturer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 20
Q Separate Quality System? Product line of a parent company spins off 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
P How to separate Product Design Review, Verification, and Validation Activities ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
C What can you do if Quality is treated as a separate function in an organization? Quality Manager and Management Related Issues 24
C Separate Certification - Can I combine documents for ISO14001, OHSAS18001 & AS4801? Miscellaneous Environmental Standards and EMS Related Discussions 3
S IEC 62366 - Embedded Software in separate Usability Engineering File? IEC 62366 - Medical Device Usability Engineering 1
K How do ISO 9001 Requirements apply to 2 sets of specifications to 2 separate vendors? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Include as an attachment or make a separate document? Advise on Document Numbering Document Control Systems, Procedures, Forms and Templates 1
F Multiple Business Lines (Separate Corporations) in one Facility AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
B Separate Clinical Trials in the US and the EU - When one fails - question US Food and Drug Administration (FDA) 3
M Can I be a legal manufacturer without being a separate legal entity? CE Marking (Conformité Européene) / CB Scheme 6
B Hospital Operating Room Regulations - Separate Entrances for Clean and Dirty Supplies Hospitals, Clinics & other Health Care Providers 4
M Does ISO/IEC 17025:2005 require the Laboratory to have separate ISO 9001 Procedures ISO 17025 related Discussions 4
R HVAC Contaminant Test for Two Separate Areas Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 6
R CNC OTS Software Validation Separate from full IQ/OQ/PQ for 21CFR Part 820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
S Accessing data from separate worksheets in Minitab Using Minitab Software 3
Q Corrective Action as a Separate Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Separate Quality Manuals for Different Sites Quality Management System (QMS) Manuals 3
