Separating Tangled Parts with a "V" Shaped Metal Clip
Cordon - 2007
#11
That's a possible alternative, but it also presents its own set of problems, the main ones being exposure of base material when parts are stamped, and potential ductility issues in the forming operation. Of course, if the purpose of the plating is corrosion protection, stainless steel is also an option, but stainless might require passivation, which reintroduces the barrel-plating problem.
The OP did mention a hardening process (which I would assume is heat treat) then plating and then relief (hydrogen embrittlement, I assume again) so I don't think plating prior to stamping would be an option.
:2cents:
JHagani
#12
Very good points.
But again, Stainless has its own problems too. If the part has a spring action, the difference in tensile strength, will change the spring rate.
There are too many uncertainities here to really come up with the exact solution.
We are just shooting ideas in the dark, based on our past experiences, trying to help.
Only the customer, and the end user with the manufacturer's advice and assistant can come up with a final decision to improve the part. We just hope our little brainstorming session can shed a little light on the subject.
#14
Great creative discussion, all :agree1: This is the Cove at its best :applause:
Then again, it may not be a problem these days: High tensile stainless is available... I should know, working for a producer of the stuff.
/Claes
Domoreto
Registered Visitor
#15
HI.
Honestly - I didn't expect such creative response. Thank you all.
Some additional explanations
- Clips are made using an Automatic bending machine “Koradi" (quite old, but beautiful peace of Italian equipment :)topic: when I first saw it - I thought of my Granny's Pedal Sawing Machine - (Singer)).
This dictates the requirement for softer material and the existing process flow ( Cordon - you've got it right):applause:
- Plating (MFZn5C) does require tumbling. I'm researching the Wes's idea of quiescent plating (electroless nickel) at the moment. ( Plating is done in-house)
- At the moment - we are sorting the clips manually.
- I'll also try to cross the "spikes" inside the clip, this should make the tangling more difficult (I think, but untangling - impossible....), without great impact on the functionality(???). Need to coordinate this with the customer ( there are certain requirements for extraction effort etc.)
Thank you opne more time.
I Co-Development Process - Separating our development activities from our customer's ISO 13485:2016 - Medical Device Quality Management Systems 13
P Separating "Shall" requirements from "Should" detail ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
D Separating Customers not requiring AS9100 - Sheet metal and machine job shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
A Interesting audit request - Full reaudit when separating R&D from division General Auditing Discussions 6
Raffy PREVENTIVE ACTION - Separating Corrective & Preventive Action. What am I gonna do? Preventive Action and Continuous Improvement 2
S Separating work instructions from SOPs Document Control Systems, Procedures, Forms and Templates 5
D Suggestions for Ishikawa for hyperdetailed customer - plastic molding automotive parts Nonconformance and Corrective Action 9
R Is a FAIR required on parts that we design? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
C Packaging Long Parts Manufacturing and Related Processes 3
D Separation of F-type applied part and remaining parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
John C. Abnet VDA 6.3 - Question 7.3 - "blocking of parts" VDA Standards - Germany's Automotive Standards 6
I When is necessary to have RoHS declaration on non-electrical parts? REACH and RoHS Conversations 1
Z Rapid audit template for plastic parts manufacturing process Manufacturing and Related Processes 12
C Scrapping on production floor - Setup parts 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
G Bad Parts cause Customer line stop IATF 16949 - Automotive Quality Systems Standard 13
G Calibration of "Master Parts" Used as Gauges Calibration Frequency (Interval) 5
P FDA Approved Product Contact Parts ISO 13485:2016 - Medical Device Quality Management Systems 6
M Identifying Applied Parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Nonconforming parts accepted by operator with intention Human Factors and Ergonomics in Engineering 33
J Mechanical inspection techniques of close tolerance parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J Sister-company providing parts is only ISO 9001 registered IATF 16949 - Automotive Quality Systems Standard 7
A AS9100D 8.1.4 Prevention of Counterfeit Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
C Difficulties getting RoHS/REACH for cheap parts RoHS, REACH, ELV, IMDS and Restricted Substances 1
G Same parts but new customer - What will the auditor ask me? IATF 16949 - Automotive Quality Systems Standard 2
G Need to change KPI we called NC parts (maximum 3%.) to FTQ (first time quality) IATF 16949 - Automotive Quality Systems Standard 4
Q Do you classify applied parts? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
R Defib-proof applied parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
S Earthing of moving parts, designing tips IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
C Quantifying risk in choosing the number of parts, operators and replicates in a GR&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Ed Panek Corona Virus impact on Supplier Audits and Received Parts ISO 13485:2016 - Medical Device Quality Management Systems 4
bryan willemot Shipping Aerospace parts without Stress certs Manufacturing and Related Processes 20
H Capability Data for Paint Thickness on Painted Parts Statistical Analysis Tools, Techniques and SPC 10
J SPC - Stamping parts - Small batch size Statistical Analysis Tools, Techniques and SPC 6
D 3 Companies - Medical device parts and substances - Responsibilities EU Medical Device Regulations 4
B Accessible parts per 8.4.2 b) - Touch currents in combination with MOOP or MOPP? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J Traceability of component parts - Bolts, screws and washers ISO 13485:2016 - Medical Device Quality Management Systems 3
R Traceability on Unmarked Parts - AS9100 requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
CPhelan Best metrics for monitoring low volume (<1000) parts per vendors Supply Chain Security Management Systems 1
DuncanGibbons Best practice for identifying "items" of parts for DFMEA analysis AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
L PPM - wrong parts or defective parts? IATF 16949 - Automotive Quality Systems Standard 18
DuncanGibbons Classification of aerospace parts depending on their risk and criticality etc. Federal Aviation Administration (FAA) Standards and Requirements 3
K Counterfeit parts prevention - Audit Nonconformance - AS9100 8.2.2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 25
bryan willemot Looking for a certified test report for aerospace parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
S Managing specification changes on standard parts purchased through trading companies Document Control Systems, Procedures, Forms and Templates 2
L PMA and Non-PMA parts in same finished goods area? Federal Aviation Administration (FAA) Standards and Requirements 1
SKM.Sunil Detachable parts vs Off the Shelf parts EU Medical Device Regulations 8
D Do purchasing controls apply to non-medical parts? ISO 13485:2016 - Medical Device Quality Management Systems 5
B Using non CE parts in a machine CE Marking (Conformité Européene) / CB Scheme 1
C AS9100D -8.5.1j - Accountability For All Products Tiny Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
