xavier.beaule
Dear community,
I would like to start off by saying that I really appreciate everything that is done here. This forum has been an incredible source of information.
I have a battery-powered medical system with a BF-type applied part. According to 8.5.2.1 F-Type Applied parts, a F-type applied part should be separated from all other parts.
I have noticed that in some cases (ref: Separation of F-type applied part and remaining parts, 1 MOPP and 1500V/4mm/2.5mm separation), it was suggested that only separation from other applied parts/accessible parts is necessary:
In other cases (ref: Isolation of secondary grounded circuits), it was suggested to both isolate from the secondary circuit and other applied parts/accessible parts:
I don't seem to understand in which case secondary circuit isolation is needed and in which case it is not necessary. Can anyone help?
F-Type insulation is between ECG circuit and all accessible parts. The accessible parts are more than just the USB/SD card, it is all plastic parts as well, such as displays, on/off switches, metal screw and the like.
The 1MOPP @ 250V (1500V/4/2.5) is related to the Type F classification (BF or CF) and only applies between the applied parts and earth or accessible parts.
But you have to isolate your BF applied part from (cl. 8.5.2.1):
- the secondary circuit by 2 MOPP based upon the working voltage,
- all other parts, including the PE by 1 MOPP based on the maximum mains voltage (usually this is more than the 2 MOPP vs. secondary).
