Separation of Facilities - Part 145 Repair Station
Al Rosen
Holed-up in a Hotel in South Florida
#11
We had dedicated personnel to do Teardown, Overhaul and Repair of electronic assemblies (accessories) in a dedicated area of our Limited Rating Repair Station. They were free to use any of the manufacturing equipment or facilities, but they were the only ones who performed the R&O work. This limited the personnel listed on the roster and in the Drug & Alcohol Prevention Program. Of course they were available to help out in manufacturing, if needed. Usually the R&O business would help us meet our $$$s at the end of the month.
Blue Tuna
#12
ratings
Hi Cari,
The example I used came from a repair station that has both class and limited ratings. They do not repair or manufacture "non FAA" related parts. I don't believe you will find anything about separation of facilities in the 145 or the AC145-9. This repair station does not manufacture under Part 145, they will manufacture under Part 21 (Certification Procedures for Products and Parts) which is where PMA parts are covered. Manufacturing under this rule is a different ball game. It takes a separate manual actually called a Fabrication Inspection System Manual (for PMA) I just finished up one and it was approved this past week. Manufacturing is MIDOs ball game not the same inspector who survieils your repair facility (even though they may be in the same physical location). Even in that scenario, I think separation of facilities may be up for grabs.
Don Palmer
#13
In the mean time - thoughts anyone?
Hi Cari,
In your thread starter, you asked for thoughts. I was unaware that you were looking for debate. :)
I was quoting Rob Nix:
Rob Nix said:
A few areas required specific identification on our floor plan, i.e. preliminary inspection area, controlled materials inventory, ready for shipment, NC Articles holding.
I said,
Yes, common machine/shop areas with specifically IDENTIFIED repair station areas where determination of 'Continued Airworthiness' is conducted.
I might have better communicated my thoughts regarding what Rob had offered if I had stated something like this:
Yes, what Rob described as being his experience, is what is currently required by our repair station PMI.
While maintaining common machine/shop areas as they are, you might consider identifying specific repair station areas where determination of 'Continued Airworthiness' is conducted.
Just a thought. :)
p.s. You certainly have your hands full Cari. I did not intend to muddy the waters. :eek:
IMO you are getting solid information from Rob, Al and Blue Tuna. :applause:
Cari Spears said:
Not sure why you capatalized that word - identification of certain areas was never my debate. In the other thread you said "clearly defined SEPARATION of facilities". I said "We don't need to SEPARATE our facility". A few people chimed in that they were required to have R&O physically SEPARATED from manufacturing in their facility and clearly identify these areas in their manual. Nothing is separate here. The inspection room is where we will determine "continued airworthiness" of FAA repairs - and will be identified as such, but it's also where we perform final inspection of non-FAA repairs and new/manufactured products.
Cari Spears
#14
Thanks everyone. If this is not a documented regulation, then I'm thinking it is up to the Inspector to decide if there are risks associated with not separating the facility.
Tammy and Rob's repair stations seem to be closer to the type of place we are and amount of FAA work that we will do. The people I called with this question are suppliers of ours that are Part 145 Repair Stations - one is our NDT source and the other is a Ti-coating place - both told me that they did not have to have separate/dedicated areas, they just had to have a layout of the facility in their manual. They both said pretty much what Tammy did - they handle the FAA work just like any other work.
I wish I could invite you all out here for a little tour so you all could see the set up. I'll be sure to let you guys know what my Inspector buddy says. Like I said - he may not be our Inspector, but he works out of the office we will send our application to - so he's as close to the horse's mouth as I can get at the moment.
Cari Spears
#15
LOL - Watch for the next thread I start. I've been composing my thread starter - lots of questions about who should be included on the rosters and the Drug & Alcohol Prevention Program.
Al Rosen
#16
Cari, I'm waiting with bated breath.;)
Cari Spears
#17
I'm not - I meant I'm debating whether or not to go tell my boss we need a separate area specifically designated for FAA repairs.
Cari Spears
#18
Perish the thought - this is the kind of stuff I want to find out about before we bring out an Inspector. If everyone has different situations, then I think I need to investigate further than I did a few months ago. The more I know prior to applying - the smoother our certification process will go.
Cari Spears
#20
This is the most current floor layout we've got. Our Plant Manager has been working on it because we've sold, bought and rearranged so many machines since this was drawn. For example - we have 3 Fadal CNCs now and sold the Haas, we have 3 CNC Lathes now and we have a huge Mazak 5-axis machining center. Now we've started the process of adding on to the building - we are getting proposals right now.
PS - the third doorway from the top in the front office area is my office door.
B F-type applied part - Separation from ALL(?) other parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
Ahang Separation between secondary circuit and accessible parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
O Difference in 60601-1-2 3rd and 4th ed separation RF portable equipment CE Marking (Conformité Européene) / CB Scheme 1
Q Rule 5.2h - Site Separation - Audit Manday Calculation (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 17
S Separation Devices as required in 16.5 of IEC 60601-1:2005 IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
R Separation requirement for Class II equipment with functional earth IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
R Separation of Network Port from other Circuits including Patient Circuit IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M Employee Transfer, Separation and Clearance Procedure and Forms ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B "Gated Conditions" - Separation of automotive and non-automotive product IATF 16949 - Automotive Quality Systems Standard 13
B Separation of Duties and Responsibilities ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
C Security and access in cGMP facilities Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
S How to find technical specification for facilities maintainance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
R IATF 16949 Clause 8.5.1.6 a) maintenance and repair facilities - Production tooling management and personnel IATF 16949 - Automotive Quality Systems Standard 4
M Informational The USFDA Continues to Remind Facilities of the Importance of Following Duodenoscope Reprocessing Instructions: FDA Safety Communication Medical Device and FDA Regulations and Standards News 0
J Facilities - Placing our assembly group into a separate building ISO 13485:2016 - Medical Device Quality Management Systems 8
V Own foreign manufacturing facilities declared as sub-contractors ISO 13485:2016 - Medical Device Quality Management Systems 5
Y TQM Implementation in Facilities Department Misc. Quality Assurance and Business Systems Related Topics 2
C Performing an ISO 9001 based Supplier Audit - Multiple Supplier Facilities Supplier Quality Assurance and other Supplier Issues 4
A Can Design & Dev (7.3) Be An Exclusion For A Facilities-based Service Company? Service Industry Specific Topics 7
T Section 4.3.1 - Limiting an EMS scope to facilities only ISO 14001:2015 Specific Discussions 3
H Facilities Management Certification Service Industry Specific Topics 2
K Combining ISO9001:2008 in Two Facilities ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
F Implementing ISO 11135 - Facilities Conditions - Adding ETO Sterilization Other Medical Device Related Standards 4
A NonConformance Reports for non ISO facilities ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
C Policy for 3rd Party Auditing of Sequencing Facilities IATF 16949 - Automotive Quality Systems Standard 6
S ISO 14001 for Mental Healthcare Facilities ISO 14001:2015 Specific Discussions 3
A Work Transfer Between Facilities AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
V Can identical gages in different facilities be in the same family? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
R Quality System for Multiple Facilities 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
V Auditing Treatment, Storage and Disposal Facilities - Non-Visit Audit ISO 14001:2015 Specific Discussions 20
J List of FDA approved Manufacturing facilities (India) ?? US Food and Drug Administration (FDA) 6
Manix Do Gauges used for Maintenance of the Facilities Require Calibration IATF 16949 - Automotive Quality Systems Standard 5
gard2372 ISO 17025 Certified Calibration Laboratory Has Moved Facilities ISO 17025 related Discussions 6
C Is Renault expecting all suppliers test facilities to be ISO/IEC17025 ISO 17025 related Discussions 4
E Extension of Scope in terms of Laboratory Facilities General Measurement Device and Calibration Topics 2
Y Internal Audits of All Facilities World Wide Before the Certification Audit Internal Auditing 9
A Which Subcontractors or Facilities need to be listed on a Quality System Certificate? ISO 13485:2016 - Medical Device Quality Management Systems 11
J Free Warehouse Layout & Planning Guide and Facilities & Workplace Design guide Design and Development of Products and Processes 10
A Are ISO 9001 certified companies required to use ISO17025 facilities for calibration? ISO 17025 related Discussions 13
M Outsourcing Design Work to Sister Facilities - How to best go about doing this Design and Development of Products and Processes 3
ScottK Organization chart for two manufacturing facilities under one corportate umbrella Misc. Quality Assurance and Business Systems Related Topics 3
T Potential Benefits - ISO 14001 for Waste Water Treatment Facilities and Water Utility ISO 14001:2015 Specific Discussions 2
Marc GM Dying in the US - GM ups job cuts to 30,000 jobs as it shuts plants, facilities World News 124
A EN 9100 7.5.1.4 Control of work transferred outside the organization's facilities AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
M Any requirement that the Quality Policy copies posted in facilities must be signed? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
K Guidance to Guide 66 as it relates to registration for multiple facilities Miscellaneous Environmental Standards and EMS Related Discussions 1
B Solid Waste Landfills and ISO 14001 - May become Permit condition for new facilities ISO 14001:2015 Specific Discussions 1
Q GM's GP-10 - Evaluation and Accreditation of Supplier Test Facilities Customer and Company Specific Requirements 14
Y 4.2.6 Facilities and Tooling Management QS-9000 - American Automotive Manufacturers Standard 0
L Facilities and Tooling Management QS-9000 - American Automotive Manufacturers Standard 3
