Sequence of Process Steps not Respected
Cephissus
How would you use FMEA to ensure proper sequence of steps?
At the moment PFMEA studies the failure modes associated with each steps, but we found ourselves confused when somebody did the steps perfectly, just not in the right order. How would you tackle this?
Let's imagine a station in which an operator needs to manually stack 4 parts on to each other: A,B,C,D
We defined for him 4 functions at the Work Element level:
- Place part A on pallet
- Place part B on part A
- Place part C on stack AB
- Place part C on stack ABC
Now we already have clearly identified failures for each step, for ex:
- Doesn't place part B
- Damages part C
- Misplaces part D
but how would you handle the wrong sequence, for example: Placing C before B?
There are so many potential combinations to study. Is there a smarter and faster way to handle this?
mattador78
Surely you have covered Placing c before b by saying they haven't placed b. The principal is the same is not? or am I looking at it too simply
Steve Prevette
Deming Disciple
I have worked in several environments where the sequence of steps performed can literally be the difference between life and death.
I would suggest one needs to consider:
1. Is this really a life or death (or significant damage) situation? What is the real outcome of performing the steps in the wrong order?​
1a - yes that may mean testing what are the POSSIBLE step combinations. If you have to go to a parts bin, get Part A and then add it to the assembly you are building, it is a bit hard to add part A before going to the parts bin.​
2. Why have people been performing them in the "wrong" order? Perhaps it really doesn't matter, or there is a compelling reason to do the work in a different order.​
3. Have you watched the task be performed (or even done it yourself)? Have you talked with the workers about the task?​
Given that you need to ensure steps are performed in the correct order, here are some applicable tools/ methods: (Note this is not an endorsement of the vendor(s), but google searches led me to these and I think they look valid)
Human Performance Tool Spotlight: Procedure Use and Adherence
Which Human Performance Tools aren't Human Performance Tools?
CDC - Hierarchy of Controls - NIOSH Workplace Safety and Health Topic [If you can physically make it impossible to do the steps in the wrong sequence, that is better than relying on memory - such as don't let the parts bin people give out Part B before giving out Part A, or an interlocking feature such as prevents you from putting a USB item into a USB port upside down]
Understanding procedural violations using Safety-I and Safety-II: The case of community pharmacies
Hope that provides some ideas.
GRP
- Damages part C
- Misplaces part D
A fast way:
requirement: stack parts in order as per drawing xyz
failure mode: any or all parts out of order
effects: the highest severity as applicable to downstream processes, plant, customer, end user, govt regulations
control methods: as applicable
Notice I am not providing any substance from a process perspective, but suggesting a way to frame the situation in the pfmea.
A key aspect of pfmea is figuring out the depth of the analysis. Does it bring any value to put several people to investigate ALL possible outcomes of the wrong sequence? Wouldn't the organization be best served if you first try to answer Steve's question #2?
A smart and fast way would be to address why can ANY wrong sequence happen. Remember not to blame it on the operator, but rather work on why the process -designed as it is- fails to meet the requirement. Probably your process is manual and there is no error-proofing or mistake-proofing.
If this first general approach fails to mitigate risk, then you may have to pursue the combinations.
Just for the sake of it, I venture saying if a poka-yoke is not feasible, maybe you can put sensors/barriers before the bins to enforce the correct sequence. (And yes, it is always possible an operator can put the hand in the bin without taking the part, or they could take it, put it down, get the next one and stack it, and get the previous one, and so on...)
What do you think?And did you work it out?
P NDT Process sequence Manufacturing and Related Processes 9
A Sequence and Interaction of the Processes - Please review my Process Map ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
R "Control" as used in 4.1 c) - Process Flow Charts (Process Sequence Chart) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
S Requirements for Sequence Diagrams & Process Flow Chart for each Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q IQ, OQ, PQ and Process Validation Sequence Qualification and Validation (including 21 CFR Part 11) 5
R Process Qualification, Equipment Qualification, Operator Qualification - Sequence? Manufacturing and Related Processes 10
S Process Required - NC for not including HR and Maintenance in our Processes Sequence IATF 16949 - Automotive Quality Systems Standard 2
Marc Run Charts - Plots of process characteristics against time or sequence Statistical Analysis Tools, Techniques and SPC 3
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
R ISO 13485 QMS sequence of implementation ISO 13485:2016 - Medical Device Quality Management Systems 4
V Sequence of performing risk assessment: User_FMEA (User Errors) vs Design Inputs FMEA and Control Plans 1
R Sequence and Interaction - Combined for both ISO 9001:2015 and EMS 14001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B AS9100 Rev D Sequence and Interactions of Processes - How in depth do I need to go? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M Work Instruction Content or Sequence Changes and Operation Numbering Document Control Systems, Procedures, Forms and Templates 3
G Sequence and Frequency of Calibration for Thread Gauges General Measurement Device and Calibration Topics 2
M The Sequence of ISO 14971 Risk Analysis Activities ISO 14971 - Medical Device Risk Management 14
Q ISO 9001:2008 4.1 b Clarification - Sequence and Interaction of Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G What is the right sequence for a Gage R&R study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
E Sequence of Operations - Non-Destructive Testing vs. Trim & Drill Manufacturing and Related Processes 2
V MOST (Maynard Operation Sequence Technique) Technique - Information/Help wanted Manufacturing and Related Processes 2
I Validation of a MOST (Maynard Operation Sequence Technique) Time Study Human Factors and Ergonomics in Engineering 2
S Do insulation layers in double insulation have sequence requirement? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
C MOST (Maynard Operation Sequence Technique) study for assembly of cockpit Lean in Manufacturing and Service Industries 6
A What is the Sequence of PPAP? APQP and PPAP 4
S Sequence and Interaction Figure ISO 13485:2016 - Medical Device Quality Management Systems 3
C GMP question - New pharma/drug manufacturing facility certification timeline/sequence Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 8
P 5S Deployment Sequence Quality Tools, Improvement and Analysis 3
D Workflow showing Sequence and Interaction of Processes in a Recruitment Scenario ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Explanation of Sequence and Interaction of Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
R How does the assessor analyse the sequence and interactions processes? Document Control Systems, Procedures, Forms and Templates 1
S Clarify on sequence & interaction of processes - Manufacturer of wiring harness IATF 16949 - Automotive Quality Systems Standard 10
Y Control chart - Sequence of sampling is not in accordance with production sequence Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
L Quality Plan or Sequence and interaction of the processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Determine the sequence and interaction of processes - ISO9001 Clause 4.1 and 4.1 b ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
apestate How do I satisfy 4.1 - Identify and determine the sequence and interaction processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
W QMS Manual for TS 16949 - Sequence for Writing the QMS Manual Quality Management System (QMS) Manuals 14
Q ISO 9001 2000 Drafts - What is the approval sequence and meeting places? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Has anyone ever heard of an International Standard for date sequence? Other ISO and International Standards and European Regulations 2
A When someone refuses to follow a process.... Misc. Quality Assurance and Business Systems Related Topics 21
R MDEL Process Canada Medical Device Regulations 4
