Definition Servicing circuit boards - Differences between Rework and Repair
jradford
I am sure this is in here someplace, but after a quick search I did not find what I was looking for.
I know the difference between the two, but what are your opinions on servicing circuit boards. It follows the definition of a repair because the end result is to the original drawing/schematic, but there are a lot of things which can go wrong when removing and replacing components. Should there be a rework sheet written up every time a circuit board it touched? How do others handle this?
Re: Rework vs repair
It's not unusual for there to be a "touchup" operation after wave soldering--it's often a normal part of the process, and thus isn't considered rework. Rework happens as a result of nonconformity--a failure to meet requirements. It can involve missing or misplaced components, cold or missing solder joints, etc. Anything that causes an assembly to go backwards in the process should be considered rework.
I'm not sure what you mean by "rework sheet," but if you mean instructions specific to the job at hand, they should be provided when necessary. If a diode has been soldered in backwards and needs to be replaced, it probably doesn't warrant written instructions. On the other hand, if there's a specific procedure to follow that's not common, intuitive or is likely to be messed up without instructions, instruction should be provided.
jradford
We have a rework form which gets filled out including authorization for the rework, adverse effects, work instruction doc #. Things like that.
Would it be required to take adverse effects into account with a simple solder touch up or component in backwards? Or can we get by with just defining operations we consider to be part of the manufacturing process. Still log it as non conforming and repair it. Not consider it a rework.
rafrost
Rework PCBs meet all drawing, BOM and process requirements. Replacing a component with the same original component is rework. Solder touchup, replacing a damaged component are rework , as long as the configuration is met.
Repair PCB's include work that adds or modifies the part from the original configuration. Adding jumper wires, cutting traces, etc.
The determination of rework vs repair documentation is commonly defined by the industry served.
Most of the scope of rework vs repair should be defined in your controlling documents.
jradford
Looking back at our controlling documents and SOP, we have the definitions of repair and rework backwards. The definitions were put in back in 2006. No one, including auditors, have pointed this out until I posted this thread. Ugh. Guess I had better start swapping definitions. I believe it is only in a few places so it should not be that bad. Write up an audit finding on myself (since the person who wrote the SOP is no longer with the company).
rafrost
Make certain you check your industry definition of rework vs repair. I have seen industries where the definitions are not to the common usage.
For example:
Audit and survey
Rework and repair
are two that I have encountered differing interpretations.
jradford
I barely remember back 5 years ago when we had an audit and repair/rework came up. At that time we had them combined as the same process. I believe we got dinged on it, so they were split and defined. We would have sent the changes to the NB for them to accept it. Surprised they didn't point out that we were backward from the rest of the industry.
We are a medical equipment company. Class II medical device.
qusys
Rework is to be intended as subjected to a repeated or new production process, repair as restored to a condition compliant with the intended usage
rafrost
I don't understand this statement. My experience does not relate either rework to the production process, only to full conformance to requirements.
Repair does not nessarily comply fully to requirements, but meets the intended usage.
Repair frequently requires customer approval. Rework typically does not.
Can you clarify?
qusys
Can you clarify?
It could depend upon the context. In semincondutor field it is allowed the so-called rework in the production line. It is an approved loop , for instance, to rework a lot ( to remove photoresist in case of particle on wafer where there is the printing of the mask of a level).
Repair could happen in test just in case some line of chip are not functioning and there is the opportunity to open the redudancy on the wafer ( other chips that can assure the same functionality).
The terms are common similar : rework is done to carry a non conforming product to a conforming status, while repair is usually done for restoring something, expecially on finished status.
You can customize upon the context. In some case you can have, in another not.
This is my intepretation.
According to ISO TS ,clause 8.3.2 says that there need working instruction sto do this, including the requirements for control.:bigwave:
C Validation of process for production and servicing 5.7.1.5 API Spec Q1, 9th Edition Oil and Gas Industry Standards and Regulations 3
Y Software updates considered servicing (7.5.4) ISO 13485:2016 - Medical Device Quality Management Systems 4
lanley liao How to understand the term 3.1.21 'Servicing' and the clause 5.7.1.2 'Servicing' of API Spec Q1? Oil and Gas Industry Standards and Regulations 19
M QMS for a repair/servicing company ISO 13485:2016 - Medical Device Quality Management Systems 2
N Servicing for SaMD ISO 13485:2016 - Medical Device Quality Management Systems 6
S Definition of "servicing activities" - Spinal Implants ISO 13485:2016 - Medical Device Quality Management Systems 4
M Informational US – MITA UPDATES SERVICING AND REMANUFACTURING WHITE PAPER Medical Device and FDA Regulations and Standards News 0
K 820.200 Servicing Procedure - Our system (because there is an API involved) is classified as Class 3 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
S Medical Device Servicing - Forms and Signature ISO 13485:2016 - Medical Device Quality Management Systems 1
S One of our devices requires servicing ISO 13485:2016 - Medical Device Quality Management Systems 3
F Mexico Medical Device Importing and Servicing Other Medical Device Regulations World-Wide 2
B Labeling requirements for Servicing and Repairing Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 2
S Manufacturers Obligations for Medical Device Servicing and/or Repair EU Medical Device Regulations 10
cscalise FDA requirements for Servicing and Refurbishment of Medical Devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 23
L Validation Processes of Production & Servicing - API Q1 clause 5.7.1.5 Oil and Gas Industry Standards and Regulations 2
J Definition Servicing - Definition - ISO 13485 Clause 7.5.1.2.3 - Servicing Activities Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
A Are Medical Device Servicing Instructions Part of Labeling? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
G Control of Monitoring and Measuring Equipment for Servicing Photocopiers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M How to include Gas Measurement Equipment Servicing & Calibration Scope to ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
X Help with ISO 13485 Clause 8.3 "Rework" as applicable to Medical Device Servicing ISO 13485:2016 - Medical Device Quality Management Systems 39
X Help with ISO 13485 Clause 6.4 as it applies to Medical Device Servicing ISO 13485:2016 - Medical Device Quality Management Systems 25
K Third Party On-Site Servicing - Training Records Requirements ISO 13485:2016 - Medical Device Quality Management Systems 6
Q AS9100B Clause 7.5.1.5 - Where did it go in AS9100C? Servicing/Post Delivery Support AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
T Documentation Scheme and Requirements - Medical Equipment Servicing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Medical Device Servicing ? What Terminology? ISO 13485:2016 - Medical Device Quality Management Systems 3
J Medical Device Engineering, Manufacture, and Servicing Document Storage US Food and Drug Administration (FDA) 1
J Used Parts in Medical Devices - Opinions on Servicing and Repair 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
L Repairs vs. ISO 13485:2003 Section 7.5.1.2.3 Servicing ISO 13485:2016 - Medical Device Quality Management Systems 6
T Definition Servicing Activities - Definition - Medical device accessory manufacturer Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 1
E When would a MMD (measuring & monitoring device) not accepted for servicing? Measurement Uncertainty (MU) 5
C AS9100 Clause 7.5.1.5 - Control of Service Operations - We do not do servicing AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
J Quality System Manual - We have a section of our QSM entitled Servicing ISO 13485:2016 - Medical Device Quality Management Systems 1
Q Do we provide servicing according to ISO 13485:2003 ISO 13485:2016 - Medical Device Quality Management Systems 5
M Servicing of Wheelchairs (wheel chairs) ISO 13485:2016 - Medical Device Quality Management Systems 4
J Servicing element - Servicing of the automobile or the production of service parts QS-9000 - American Automotive Manufacturers Standard 3
E 7.5 Service or servicing - What does "service provision" mean? Service Industry Specific Topics 4
F 4.9 Installation & Servicing Processes QS-9000 - American Automotive Manufacturers Standard 1
G Seeking: Generic Servicing Procedure Document Control Systems, Procedures, Forms and Templates 2
B Clause 4.19 Servicing - Mold Makers and do produce some parts off customers molds QS-9000 - American Automotive Manufacturers Standard 2
Marc 4.7 Customer Supplied Product vs 4.19 Servicing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
F Circuit board FAI reports- How do you folks deal with these? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M Do I need separation in my circuit with a medical charger? IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
D SINGLE FAULT CONDITION, short circuit and open circuit of any component (IEC 60601-1 3.1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
W Printed Circuit Board - IMDS declaration RoHS, REACH, ELV, IMDS and Restricted Substances 3
Ahang Separation between secondary circuit and accessible parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
V Printed Circuit Board Assembly and Components FAI Question Document Control Systems, Procedures, Forms and Templates 8
S Serializing Circuit Card Assemblies (CCAs) in EPICOR Misc. Quality Assurance and Business Systems Related Topics 2
S How to determine the Air Clearance for Floated Secondary Circuit IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
W Supply Voltage Condition for Transformer O/L and S/C (open & short circuit) testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
R How to determine the ratings of components in primary circuit IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
