Setting Acceptance Quality Limits (AQL) for New Medical Devices
Philip B
Does anyone have any experience of setting Acceptance Quality Limits (AQL) for medical devices? We are about to launch a new device, it is manufactured and packed by a sub-contractor, we receive and then sterilise and sell. Because it is a new device we would like to inspect the first batches received then reduce the inspection provided there are no problems. The sub-contractor performs their own in-process inspection.
Should we apply an AQL to our own inspection or is this something for our sub-contractor to do and we just spot-check the product?
I'm not great with stats so any advice appreciated!
Thanks,
Philip
chris1price
Hi, as you are responsible for the sterilisation, I would definitely perform your own inspection. The AQL level is all about the confidence you have in the supplier and the risk associated with selling a faulty product. There isnt a set level, but there are many threads on here discussing AQLs. The data from your packaging validation (performed after sterilisation and aging) may help you set an appropriate level.
I would suggest starting at either 0.25 or 0.65 and if everything passes across an approriate number of batches, use the switching rules to move to a reduced level of inspection.
Also, remember the manufacturer is your sub-contractor; you should be setting the inspection that they perform.
N
NicoleinFlorida
You may ask your sub-contractor do the inspection for you by following your own inspection requirements, if the sub-contractor is really reliable. In that way, you can have spot check at your own facility. And you don't need to have those inspection and measuring equipment.
But I will recommend inspecting by yourself, especially at the very beginning of production.
Ronen E
Problem Solver
Moderator
Thanks,
Philip
Before going into the nuts and bolts of your system, I recommend getting familiar with the basic concepts and terminology, with the aid of overviews such as this one or that one. There are many others; I found those by Googling "incoming inspection basics" (1st and 2nd results). As noted, there are also some good discussions on those topics at Elsmar, but I'd go after them only once feeling confident with the base concepts.
By the way, the AQL-based sampling system (such as in Z1.4) is not purely statistical and its development included economical considerations (ie trying to avoid very large sample sizes without sacrificing too much statistical rigor).
I agree that the most important (and the first) step is understanding what risks you are trying to mitigate and what characteristics of the product are to be monitored/controlled. Is it just cleanliness / bioburden? Is it dimensions etc? Is it quantities / packaging configurations? Etc. etc. Each characteristic may lead to different AQLs, different sampling plans etc.
As a general advice, I would mistrust any new supplier and let their actual performance build my confidence over time, modifying my QC practices accordingly. While it's good to have their final inspection records at hand (their in-process inspection would be less relevant), I wouldn't heavily rely on it at first. "Spot check" is just an unfancy name for a sampling plan, with the potential disadvantage of being too loosely defined.
V The approach/criteria of setting Acceptance Limits Method Validation Parameters Statistical Analysis Tools, Techniques and SPC 1
I Setting Bioburden Limits for ETO Other Medical Device Related Standards 1
Bev D Development Process: FMEA, Critical Characteristics, Spec Setting and Controls Misc. Quality Assurance and Business Systems Related Topics 0
P Setting Cleanroom Alert and Action Limits Manufacturing and Related Processes 0
S Setting AQL Levels with Multiple Suppliers Supplier Quality Assurance and other Supplier Issues 3
qualprod Setting a goal in % with few events ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Setting up a service center in the EU ISO 13485:2016 - Medical Device Quality Management Systems 2
Z Setting the Control limits on Minitab Using Minitab Software 4
S HELP in setting-up QMS Quality Tools, Improvement and Analysis 4
Awais Setting up Kitting Cells Manufacturing and Related Processes 0
K ISO 9001 Auditing in a Healthcare setting Process Audits and Layered Process Audits 15
J Setting accuracy limit for a read out General Measurement Device and Calibration Topics 4
B Setting flexible packaging specification limits ISO 14971 - Medical Device Risk Management 4
I Setting action completion dates Nonconformance and Corrective Action 3
S Qualification question - ISO 13485 - Setting up a small lab Reliability Analysis - Predictions, Testing and Standards 2
S Heat Sealers Upper and lower limit setting during OQ for Heat Sealer Qualification and Validation (including 21 CFR Part 11) 0
Ed Panek GDPR in Urgent Healthcare Setting Other ISO and International Standards and European Regulations 1
M Setting deadlines (ex. 45 days) for Document Registration & Review Cycle Document Control Systems, Procedures, Forms and Templates 3
Ashok sunder What are the criteria for setting a target KPI value against a quality objective? Benchmarking 7
K Setting Quality Objectives (for the first time) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 17
R ISO 11137 Gamma sterilization validation, dose setting, dose audit Other Medical Device Related Standards 1
M Best Practice for setting tolerances on a Drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
T Setting up a quality department in an Engineering Firm Quality Management System (QMS) Manuals 11
B Software for setting up New Warehouse Manufacturing and Related Processes 0
S Setting up the process - First piece inspections Statistical Analysis Tools, Techniques and SPC 3
A Add-On software for VMC to calculate setting time, Idle Time, OEE etc.. Manufacturing and Related Processes 2
G Setting Up a Basic Quality Lab for a small manufacturing company General Measurement Device and Calibration Topics 2
A Setting initial Expiry Date of an IVD per BS EN 23640:2015 Other Medical Device Related Standards 12
Q Setting Quality Objectives with a Timeframe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Proud Liberal Setting up Prolink's QC-Gage to a Keyence IM-6225 Vision System Statistical Analysis Tools, Techniques and SPC 2
K Bioburden 0 cfu for Dose Setting using the VDmax25 Other Medical Device Related Standards 9
A New company, no employees, Setting up a QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
F Setting up a new sterilization unit in a new facility 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
C ISO 14001 Recertification without setting Targets ISO 14001:2015 Specific Discussions 3
T Guidance - Setting up an integrated quality & environmental management system Career and Occupation Discussions 12
M Setting up a M1003 QA Program for the AAR Various Other Specifications, Standards, and related Requirements 2
A Setting up a Medical Device Distributor in Malaysia Other Medical Device Regulations World-Wide 17
R Irradiation Sterilization Dose Setting and Dose Audit Flow Charts ISO 13485:2016 - Medical Device Quality Management Systems 0
J Setting Up New QMS - New US Location ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Setting air gauging outside of a part tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 2
S Target Setting - Internal metric(s) to drive Internal Processes Six Sigma 1
S MSA Help or guidelines - Plastics - Setting up an MSA on a multi cavity fixture Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G Setting up a corporate umbrella QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T Setting Quality Objectives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
W Setting up from scratch - Looking for help (ISO9001 / ISO13485) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
F Setting up a New QMS for Certification when ISO 9001 is about to Change ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
P New to AS9100 Rev. C - Setting KPIs and FAI Reports AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
B Setting Lower Control Limit on Attributes Charts Statistical Analysis Tools, Techniques and SPC 9
J Lean 5S - Setting Min/Max Inventory Levels Lean in Manufacturing and Service Industries 3
