Setting action completion dates
I'm updating our non-conformance procedure and struggling with the completion date for the corrective action. Should this be the date the action is actually completed, or the date the effectiveness has been verified.
Its easy to plan a date for completing the action, for example updating a procedure, but planning a date for verifying that change has been effective is harder. Is it enough to say that the verifier is happy that the action will be sufficient to prevent reocurrence?
Ninja
Looking for Reality
I set the dates "floating"...
The Corrective action had a target "done by" date that was to be filled in.
Verification/audit/follow up/whatever you call it was to be completed within XX months of that. (I think we did 6mnths, but I'm not sure)
When it was to be "done by"...the question was asked "Is it done?".
Either that, or someone saying "Im done now" started the clock for follow up.
HTH
John C. Abnet
Teacher, sensei, kennari
Good day @iso_is_fun!
Consider the following...
Corrective action is not the same as managing the non-conformance.
A- non-conformance:
At the time of notification/awareness your organization should...
a) have a series of steps to locate (lot/product traceability) any suspect product (in order, if necessary, to contain/recall, etc...)...
and the conditions that may be making MORE suspect product.
b) stop the production of suspect product (cease production and/or take action to prevent the situation.) ...or (not ideal but sometimes necessary) verify/sort product to prevent outflow of nonconformance.
The aforementioned action can take place "immediately" (i.e. production can be stopped until an initial "fix" or verification can be established. Product sold/produced/in WIP can be contained until the required verification/scrap/rework/repair can be done).
B- Corrective action:
Using the appropriate discipline(s)...
a) identify the root cause,
b) correct/remedy the problem,
c) verify the effectiveness
d) ensure the "fix" is established systemically in order to prevent recurrence.
It is impossible to "proceduralize" (i.e. determine ahead of time) a date/time frame for corrective action. Some problems can be easily identified and corrected nearly immediately. Other problems require extensive research (possible re-creation testing, etc..etc..) to identify the root cause and may take even LONGER (order parts, change equipment design, etc..etc..) to correct. While the isolation/containment/verification of product may be needed/possible "immediately" in order to keep good/verified product flowing to the customer, the necessary time for actual root cause analysis and correction is impossible to predict considering the infinite amount of scenarios.
I would highly recommend your procedures do not attempt to predict or require a specific time frame for corrective actions.
Hope this helps.
Be well.
Randy
You can't set a specific date, it might take 1, 3, 5 years for something to happen depending on innumerable factors including funding, but you can set review dates and propose a potential end date.
Now here's the deal, if the NC being actioned is some simple piddly documentation or failure to follow a procedure or something like that, dragging out the completion date could lead to an ineffective CA process being identified.
Don't try to cheat your way through the process.
S Heat Sealers Upper and lower limit setting during OQ for Heat Sealer Qualification and Validation (including 21 CFR Part 11) 0
Ed Panek GDPR in Urgent Healthcare Setting Other ISO and International Standards and European Regulations 1
M Setting deadlines (ex. 45 days) for Document Registration & Review Cycle Document Control Systems, Procedures, Forms and Templates 3
Ashok sunder What are the criteria for setting a target KPI value against a quality objective? Benchmarking 7
K Setting Quality Objectives (for the first time) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 17
R ISO 11137 Gamma sterilization validation, dose setting, dose audit Other Medical Device Related Standards 1
M Best Practice for setting tolerances on a Drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
T Setting up a quality department in an Engineering Firm Quality Management System (QMS) Manuals 11
B Software for setting up New Warehouse Manufacturing and Related Processes 0
S Setting up the process - First piece inspections Statistical Analysis Tools, Techniques and SPC 3
A Add-On software for VMC to calculate setting time, Idle Time, OEE etc.. Manufacturing and Related Processes 2
G Setting Up a Basic Quality Lab for a small manufacturing company General Measurement Device and Calibration Topics 2
A Setting up an LLC as a Consultant Paid Consulting, Training and Services 27
A Setting initial Expiry Date of an IVD per BS EN 23640:2015 Other Medical Device Related Standards 12
Q Setting Quality Objectives with a Timeframe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Proud Liberal Setting up Prolink's QC-Gage to a Keyence IM-6225 Vision System Statistical Analysis Tools, Techniques and SPC 2
P Setting Acceptance Quality Limits (AQL) for New Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 4
K Bioburden 0 cfu for Dose Setting using the VDmax25 Other Medical Device Related Standards 9
A New company, no employees, Setting up a QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
F Setting up a new sterilization unit in a new facility 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
C ISO 14001 Recertification without setting Targets ISO 14001:2015 Specific Discussions 3
T Guidance - Setting up an integrated quality & environmental management system Career and Occupation Discussions 12
M Setting up a M1003 QA Program for the AAR Various Other Specifications, Standards, and related Requirements 2
A Setting up a Medical Device Distributor in Malaysia Other Medical Device Regulations World-Wide 16
R Irradiation Sterilization Dose Setting and Dose Audit Flow Charts ISO 13485:2016 - Medical Device Quality Management Systems 0
J Setting Up New QMS - New US Location ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Setting air gauging outside of a part tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 2
S Target Setting - Internal metric(s) to drive Internal Processes Six Sigma 1
S MSA Help or guidelines - Plastics - Setting up an MSA on a multi cavity fixture Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G Setting up a corporate umbrella QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T Setting Quality Objectives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
W Setting up from scratch - Looking for help (ISO9001 / ISO13485) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
F Setting up a New QMS for Certification when ISO 9001 is about to Change ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
P New to AS9100 Rev. C - Setting KPIs and FAI Reports AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
B Setting Lower Control Limit on Attributes Charts Statistical Analysis Tools, Techniques and SPC 9
J Lean 5S - Setting Min/Max Inventory Levels Lean in Manufacturing and Service Industries 3
V Setting Specification Limits for UOD (Uniformity) for Live Bacteria or Spores Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 4
D How do I make the Corporate QMS work in the manufacturing setting? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J Setting Quality Objectives for Service, Repair and Sales ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q Setting Specification Limits Quality Tools, Improvement and Analysis 11
C Mitutoyo SJ210 Settings - Is there an Industry Standard Surface Measurement Setting? General Measurement Device and Calibration Topics 4
W Setting up a Zmike for Pin Gage Calibration General Measurement Device and Calibration Topics 3
W Zero setting of correlation graph when plotting best fit linear regression Statistical Analysis Tools, Techniques and SPC 7
G Setting up a 3 Factor, 2 Level,2 response DOE in Minitab Using Minitab Software 7
B Quality Goals and Improvements in a Bioanalytical Laboratory Setting Quality Tools, Improvement and Analysis 1
N Setting up MSA system in a machine shop environment. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
N Setting up a new Calibration Room in a Machine Shop Calibration and Metrology Software and Hardware 3
R Document Control Person - Setting KPIs, Development Plan, and Career Path Quality Manager and Management Related Issues 6
J Does a Lower Thermostat Setting really save Energy? Coffee Break and Water Cooler Discussions 11
