Setting deadlines (ex. 45 days) for Document Registration & Review Cycle
mtespiritu
Mabuhay! I'm Ian. I have been a regular visitor in this forum and it has been very helpful to me as my company's EMR.
I want to improve our Document Control Procedure and would like to confirm the following after reading everything I could find here related to the topic.
(1) We have set a 45-day deadline for our documented information registration and review cycle.
- once the process owner intends to make a new document or review an existing one, they are
required to fill-out the Document Registration and Review Form and the 45-day countdown begins
> I believe this is our consultant's idea of conforming 7.5.2 and 7.5.3 (ISO14001:2015) but I could not
really see it in the standard and it's very restrictive. Am I right?
> It was also intended to control editable copies of the procedures so that process owners are required to
complete the document within the 45-day cycle or else they need to return all the files back to the Document
Controller. For me, this seems to be another source of unnecessary nonconformities.
(2) We already have a footer in place in our documents that indicates that unless it is marked "Controlled" then
it is uncontrolled. Yet, we are always on the lookout for copies of uncontrolled documents that may be left
lying around. As I understood it, we just have to make sure our personnel are aware how to identify controlled
copies from uncontrolled ones to ensure that they always use the correct one.
I have downloaded several examples of Document Control Procedure from here and I am amaze how simple it is and yet
addresses the requirements of the standard.
Watchcat
Document control systems vary a lot from company to company. Your last point under (1) states that they need to return all files back to the Document Controller. However, neither of your previous two points indicate that any files were ever removed from the Document Controller. What kinds of files would someone who is planning to make a new document or review an existing one remove from your Document Controller?
PS As a practical matter, the only way to "ensure" that personnel use the correct document is to make it physically impossible for them to get their hands on an incorrect document. Nothing you put in a footer is likely to achieve that end.
mtespiritu
"...However, neither of your previous two points indicate that any files were ever removed from the Document Controller. What kinds of files would someone who is planning to make a new document or review an existing one remove from your Document Controller?"
Thanks for the inputs.
For new documents (maintained), we just have to register it after we have the final draft and it gets routed for checking and approval. This document should be approved within our set 45-day document registration cycle.
For documents (maintained) to be revised, we need to pull-out from the document controller editable of copies of the controlled documents. Then the revised document should be approved within our set 45-day document registration cycle.
For both cases, this would be a nonconformity against our procedure if the 45-day cycle lapses without the document being approved. Since we made this a requirement which I am thinking now that it is not actually necessary. Our intention was to "control" the editable files which may not actually be necessary since what we should focus more should be the control of our signed and approved documents.
I observe that we may have been having unnecessary nonconformities related to requirements we have set ourselves but not necessarily required by the standard.
Watchcat
I have always maintained that any document that has to be approved before it can go into effect is not actually a document until it has been approved. By this I mean that such documents are not company documents until they have been approved. Ergo, from the company's perspective, they do not exist and they cannot fall within the scope of a company SOP. Not sure if that helps or confuses, but it's always worked for me.
To be less obtuse, I can't think of any rationale for a 45-day deadline under either circumstance (create new or revise old), so I would agree that's just creating an opportunity for a pointless nonconformity.
J Setting accuracy limit for a read out General Measurement Device and Calibration Topics 4
B Setting flexible packaging specification limits ISO 14971 - Medical Device Risk Management 4
I Setting action completion dates Nonconformance and Corrective Action 3
S Qualification question - ISO 13485 - Setting up a small lab Reliability Analysis - Predictions, Testing and Standards 2
S Heat Sealers Upper and lower limit setting during OQ for Heat Sealer Qualification and Validation (including 21 CFR Part 11) 0
Ed Panek GDPR in Urgent Healthcare Setting Other ISO and International Standards and European Regulations 1
Ashok sunder What are the criteria for setting a target KPI value against a quality objective? Benchmarking 7
K Setting Quality Objectives (for the first time) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 17
R ISO 11137 Gamma sterilization validation, dose setting, dose audit Other Medical Device Related Standards 1
M Best Practice for setting tolerances on a Drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
T Setting up a quality department in an Engineering Firm Quality Management System (QMS) Manuals 11
B Software for setting up New Warehouse Manufacturing and Related Processes 0
S Setting up the process - First piece inspections Statistical Analysis Tools, Techniques and SPC 3
A Add-On software for VMC to calculate setting time, Idle Time, OEE etc.. Manufacturing and Related Processes 2
G Setting Up a Basic Quality Lab for a small manufacturing company General Measurement Device and Calibration Topics 2
A Setting up an LLC as a Consultant Paid Consulting, Training and Services 27
A Setting initial Expiry Date of an IVD per BS EN 23640:2015 Other Medical Device Related Standards 12
Q Setting Quality Objectives with a Timeframe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Proud Liberal Setting up Prolink's QC-Gage to a Keyence IM-6225 Vision System Statistical Analysis Tools, Techniques and SPC 2
P Setting Acceptance Quality Limits (AQL) for New Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 4
K Bioburden 0 cfu for Dose Setting using the VDmax25 Other Medical Device Related Standards 9
A New company, no employees, Setting up a QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
F Setting up a new sterilization unit in a new facility 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
C ISO 14001 Recertification without setting Targets ISO 14001:2015 Specific Discussions 3
T Guidance - Setting up an integrated quality & environmental management system Career and Occupation Discussions 12
M Setting up a M1003 QA Program for the AAR Various Other Specifications, Standards, and related Requirements 2
A Setting up a Medical Device Distributor in Malaysia Other Medical Device Regulations World-Wide 16
R Irradiation Sterilization Dose Setting and Dose Audit Flow Charts ISO 13485:2016 - Medical Device Quality Management Systems 0
J Setting Up New QMS - New US Location ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Setting air gauging outside of a part tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 2
S Target Setting - Internal metric(s) to drive Internal Processes Six Sigma 1
S MSA Help or guidelines - Plastics - Setting up an MSA on a multi cavity fixture Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G Setting up a corporate umbrella QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T Setting Quality Objectives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
W Setting up from scratch - Looking for help (ISO9001 / ISO13485) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
F Setting up a New QMS for Certification when ISO 9001 is about to Change ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
P New to AS9100 Rev. C - Setting KPIs and FAI Reports AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
B Setting Lower Control Limit on Attributes Charts Statistical Analysis Tools, Techniques and SPC 9
J Lean 5S - Setting Min/Max Inventory Levels Lean in Manufacturing and Service Industries 3
V Setting Specification Limits for UOD (Uniformity) for Live Bacteria or Spores Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 4
D How do I make the Corporate QMS work in the manufacturing setting? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J Setting Quality Objectives for Service, Repair and Sales ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q Setting Specification Limits Quality Tools, Improvement and Analysis 11
C Mitutoyo SJ210 Settings - Is there an Industry Standard Surface Measurement Setting? General Measurement Device and Calibration Topics 4
W Setting up a Zmike for Pin Gage Calibration General Measurement Device and Calibration Topics 3
W Zero setting of correlation graph when plotting best fit linear regression Statistical Analysis Tools, Techniques and SPC 7
G Setting up a 3 Factor, 2 Level,2 response DOE in Minitab Using Minitab Software 7
B Quality Goals and Improvements in a Bioanalytical Laboratory Setting Quality Tools, Improvement and Analysis 1
N Setting up MSA system in a machine shop environment. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
