Setting Lower Control Limit on Attributes Charts
Bill McNeese
Wondering what others may think. I never have liked the practice of setting a lower control limit to zero for an attribute chart when that lower control limit is negative. I always simply say there is no lower control limit. There is a lower boundary of course - but not a lower control limit.
For example, you are charting occurrences (such as OSHA recordable injuries per month) using a c control chart. The average is 4. That gives a lower control limit of -2. Can't have negative injuries, so there should be on lower control limit - not setting it to 0.
A control limit is "special" in that it marks the realm of common cause of variation. In this example, there is nothing special about 0. You can easily have a month with no injuries and there is nothing "special" about it - although a lot of managers like people were being more careful that month.
So, I prefer to say there is no lower control limit for an attribute chart when it is less than zero. Not sure how the practice of setting it to zero started.
Steve Prevette
Deming Disciple
Yes I prefer to say there is no lower control limit. However, even if you said the lower control limit was zero, since the rule is "outside the control limits" then you are still okay if a zero comes in.
By the way, there are some charts that can have negative numbers, so keep that in mind.
t.PoN
Yes, you may use No Lower Control Limit.
but be careful, sometimes having too many zeros could be an indicator for something else.
for example: when you are starting to get many months with zero injuries while the previous history shows an average of 4 to 5 reported injuries. then you may want to check the reporting system. People might start hiding injuries reports. or may be your process is getting much much better, you need t set a new average
Steve Prevette
Deming Disciple
In this case, you would still make use of other rules, such as 7 in a row below average, or 4 of 5 at one standard deviation below average to detect this, prior to establishing any new baselines.
DRAMMAN
IMHO, setting the lower limit to zero and calling it the LCL simplifies it for everyone else. I used to try and explain to everyoe that it is not reallya LCL but the conversation just goes over heir head.
RoxaneB
It depends on the audience and who the message from the attributes chart is directed towards. Like Dramman, I prefer to keep it simple - especially if the target audience aren't into stats (i.e., are we within the range, yes or no?).
To start throwing in -2 for occurences instead of 0, will complicate the message, in my opinion. For behind-the-scenes activities, such as determining UCL and LCL in the future, feel free to use the -2 result, but for the message, one really does need to consider the audience and how the attribute and subsequent results are used.
Bill McNeese
To start throwing in -2 for occurences instead of 0, will complicate the message, in my opinion. .
I do not throw in a -2. The chart would not show anything below 0. There would simply be no lower control limit. Key is for folks to understand that a 0 is nothing special - just due to common causes.
DRAMMAN
I will usually leave out details such as having a negative lower limit when a negative qty is impossible. I can think of many times where the audiences gets fixated on the negative number and it throws off an entire meeting. This usually happens when the audience are upper managers who are looking for any detail to complain about and the only thing they understand is a negative defect qty is not possible.
Matt33
When the LCL is negative and a negative value is not possible, my preference is to show on the chart:
LCL = 0 or LCL = N/A
However, "behind" the chart, as a person working with the chart, I like to see what the actual calculated value is, even if it negative. I think I prefer this approach so that I can discuss the math and how the limits are symmetrical about the mean, but in this case, it doesn't make sense to show the LCL. Thus, setting it to 0 or N/A makes sense.
In summary, I like to separate the displayed chart from the mathematics.
The chart that your audience sees shows:
for me the point is that some processes DON'T have symmetrical limits. (certainly the r chart and the s chart don't)
if you have a p chart (categorical defect rates) then as your quality improves you certainly don't have a symmetrical distribution; more and more subgroups will have zero defects. you DO have a truncated distribution and that is not symmetrical.
And of course if the defect rate is small enough the p chart (or the np, c or u charts) isn't appropriate. Not because of any violation of Normality, but because the distributions deviate substantially from symmetrical.
PHYSICS matters...
K SPC for One-sided Specification - Setting the Lower Control Limit Statistical Analysis Tools, Techniques and SPC 4
S Heat Sealers Upper and lower limit setting during OQ for Heat Sealer Qualification and Validation (including 21 CFR Part 11) 0
J Does a Lower Thermostat Setting really save Energy? Coffee Break and Water Cooler Discussions 11
K ISO 9001 Auditing in a Healthcare setting Process Audits and Layered Process Audits 15
J Setting accuracy limit for a read out General Measurement Device and Calibration Topics 4
B Setting flexible packaging specification limits ISO 14971 - Medical Device Risk Management 4
I Setting action completion dates Nonconformance and Corrective Action 3
S Qualification question - ISO 13485 - Setting up a small lab Reliability Analysis - Predictions, Testing and Standards 2
Ed Panek GDPR in Urgent Healthcare Setting Other ISO and International Standards and European Regulations 1
M Setting deadlines (ex. 45 days) for Document Registration & Review Cycle Document Control Systems, Procedures, Forms and Templates 3
Ashok sunder What are the criteria for setting a target KPI value against a quality objective? Benchmarking 7
K Setting Quality Objectives (for the first time) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 17
R ISO 11137 Gamma sterilization validation, dose setting, dose audit Other Medical Device Related Standards 1
M Best Practice for setting tolerances on a Drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
T Setting up a quality department in an Engineering Firm Quality Management System (QMS) Manuals 11
B Software for setting up New Warehouse Manufacturing and Related Processes 0
S Setting up the process - First piece inspections Statistical Analysis Tools, Techniques and SPC 3
A Add-On software for VMC to calculate setting time, Idle Time, OEE etc.. Manufacturing and Related Processes 2
G Setting Up a Basic Quality Lab for a small manufacturing company General Measurement Device and Calibration Topics 2
A Setting up an LLC as a Consultant Paid Consulting, Training and Services 27
A Setting initial Expiry Date of an IVD per BS EN 23640:2015 Other Medical Device Related Standards 12
Q Setting Quality Objectives with a Timeframe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Proud Liberal Setting up Prolink's QC-Gage to a Keyence IM-6225 Vision System Statistical Analysis Tools, Techniques and SPC 2
P Setting Acceptance Quality Limits (AQL) for New Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 4
K Bioburden 0 cfu for Dose Setting using the VDmax25 Other Medical Device Related Standards 9
A New company, no employees, Setting up a QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
F Setting up a new sterilization unit in a new facility 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
C ISO 14001 Recertification without setting Targets ISO 14001:2015 Specific Discussions 3
T Guidance - Setting up an integrated quality & environmental management system Career and Occupation Discussions 12
M Setting up a M1003 QA Program for the AAR Various Other Specifications, Standards, and related Requirements 2
A Setting up a Medical Device Distributor in Malaysia Other Medical Device Regulations World-Wide 16
R Irradiation Sterilization Dose Setting and Dose Audit Flow Charts ISO 13485:2016 - Medical Device Quality Management Systems 0
J Setting Up New QMS - New US Location ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Setting air gauging outside of a part tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 2
S Target Setting - Internal metric(s) to drive Internal Processes Six Sigma 1
S MSA Help or guidelines - Plastics - Setting up an MSA on a multi cavity fixture Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G Setting up a corporate umbrella QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T Setting Quality Objectives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
W Setting up from scratch - Looking for help (ISO9001 / ISO13485) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
F Setting up a New QMS for Certification when ISO 9001 is about to Change ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
P New to AS9100 Rev. C - Setting KPIs and FAI Reports AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
J Lean 5S - Setting Min/Max Inventory Levels Lean in Manufacturing and Service Industries 3
V Setting Specification Limits for UOD (Uniformity) for Live Bacteria or Spores Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 4
D How do I make the Corporate QMS work in the manufacturing setting? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J Setting Quality Objectives for Service, Repair and Sales ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q Setting Specification Limits Quality Tools, Improvement and Analysis 11
C Mitutoyo SJ210 Settings - Is there an Industry Standard Surface Measurement Setting? General Measurement Device and Calibration Topics 4
W Setting up a Zmike for Pin Gage Calibration General Measurement Device and Calibration Topics 3
W Zero setting of correlation graph when plotting best fit linear regression Statistical Analysis Tools, Techniques and SPC 7
