Setting up a 3 Factor, 2 Level,2 response DOE in Minitab
G
GaryL
How do i setup a 3 Factor 2 Level.....2 response DOE in Minitab, im using Minitab 15..
Thanks..
Stat > DOE > Factorial > Create Factorial Design > Number of Factors > 3
Beyond that, you will have to provide us more information about your experiment.
G
GaryL
Hi, I had no problem creating the design, it's how I record then analyze the responses that I can't figure out...I have 5 replicates for each of the two responses and for each run..making 40 data points for each response...I've recorded it in rows/ columns but cannot for the life of me figure out how to analyze it...I have been using DOE pro but would like to start using mini tab ..
You have entered the data as REPEATS. If you ran the experimental run a single time and took 5 measurements from that run, then this is correct. You then use Pre-process Responses for Analyze Variability.
On the other hand, if these are true REPLICATES. That is, you ran each experimental condition 5 times and took a single measurement each time, then you specify 5 replicates when you design the experiment and enter the data as shown in the attached picture. I entered the data for all five replicates of a single experimental run for clarity.
G
GaryL
Hey, Miner.
thanks for your help so far, i have tried to run the preprocess but it tells me i have no data in C18...i only had the 5 repeats for each response , each level..
Not sure what im missing.
I also tried to setup the DOE the way you described, but could not find replicate settings...could you walk me through the steps...many thanks..
P Help Setting Up and Analyzing 3 Factor 2 Level Full Factorial Design for DOE Using Minitab Software 3
T Setting up a Standard Experimental Plan for Food where Factor Levels are Different Statistical Analysis Tools, Techniques and SPC 2
P Setting Cleanroom Alert and Action Limits Manufacturing and Related Processes 0
S Setting AQL Levels with Multiple Suppliers Supplier Quality Assurance and other Supplier Issues 3
qualprod Setting a goal in % with few events ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Setting up a service center in the EU ISO 13485:2016 - Medical Device Quality Management Systems 2
Z Setting the Control limits on Minitab Using Minitab Software 4
S HELP in setting-up QMS Quality Tools, Improvement and Analysis 4
Awais Setting up Kitting Cells Manufacturing and Related Processes 0
K ISO 9001 Auditing in a Healthcare setting Process Audits and Layered Process Audits 15
J Setting accuracy limit for a read out General Measurement Device and Calibration Topics 4
B Setting flexible packaging specification limits ISO 14971 - Medical Device Risk Management 4
I Setting action completion dates Nonconformance and Corrective Action 3
S Qualification question - ISO 13485 - Setting up a small lab Reliability Analysis - Predictions, Testing and Standards 2
S Heat Sealers Upper and lower limit setting during OQ for Heat Sealer Qualification and Validation (including 21 CFR Part 11) 0
Ed Panek GDPR in Urgent Healthcare Setting Other ISO and International Standards and European Regulations 1
M Setting deadlines (ex. 45 days) for Document Registration & Review Cycle Document Control Systems, Procedures, Forms and Templates 3
Ashok sunder What are the criteria for setting a target KPI value against a quality objective? Benchmarking 7
K Setting Quality Objectives (for the first time) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 17
R ISO 11137 Gamma sterilization validation, dose setting, dose audit Other Medical Device Related Standards 1
M Best Practice for setting tolerances on a Drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
T Setting up a quality department in an Engineering Firm Quality Management System (QMS) Manuals 11
B Software for setting up New Warehouse Manufacturing and Related Processes 0
S Setting up the process - First piece inspections Statistical Analysis Tools, Techniques and SPC 3
A Add-On software for VMC to calculate setting time, Idle Time, OEE etc.. Manufacturing and Related Processes 2
G Setting Up a Basic Quality Lab for a small manufacturing company General Measurement Device and Calibration Topics 2
A Setting initial Expiry Date of an IVD per BS EN 23640:2015 Other Medical Device Related Standards 12
Q Setting Quality Objectives with a Timeframe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Proud Liberal Setting up Prolink's QC-Gage to a Keyence IM-6225 Vision System Statistical Analysis Tools, Techniques and SPC 2
P Setting Acceptance Quality Limits (AQL) for New Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 4
K Bioburden 0 cfu for Dose Setting using the VDmax25 Other Medical Device Related Standards 9
A New company, no employees, Setting up a QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
F Setting up a new sterilization unit in a new facility 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
C ISO 14001 Recertification without setting Targets ISO 14001:2015 Specific Discussions 3
T Guidance - Setting up an integrated quality & environmental management system Career and Occupation Discussions 12
M Setting up a M1003 QA Program for the AAR Various Other Specifications, Standards, and related Requirements 2
A Setting up a Medical Device Distributor in Malaysia Other Medical Device Regulations World-Wide 17
R Irradiation Sterilization Dose Setting and Dose Audit Flow Charts ISO 13485:2016 - Medical Device Quality Management Systems 0
J Setting Up New QMS - New US Location ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Setting air gauging outside of a part tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 2
S Target Setting - Internal metric(s) to drive Internal Processes Six Sigma 1
S MSA Help or guidelines - Plastics - Setting up an MSA on a multi cavity fixture Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G Setting up a corporate umbrella QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T Setting Quality Objectives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
W Setting up from scratch - Looking for help (ISO9001 / ISO13485) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
F Setting up a New QMS for Certification when ISO 9001 is about to Change ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
P New to AS9100 Rev. C - Setting KPIs and FAI Reports AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
B Setting Lower Control Limit on Attributes Charts Statistical Analysis Tools, Techniques and SPC 9
J Lean 5S - Setting Min/Max Inventory Levels Lean in Manufacturing and Service Industries 3
