Setup Part Management - Preventing Escape
dubrizo
#11
If it happens again have the operator responsible for setting up and running the machine visit the customer to explain what happened.
What about not doing this (as much as I wish we could have operators face the music) hahaha. It's possible the operator is doing exactly what he/she has been told to do... Not only that, but this method does not identify and correct the root cause of the issue in order to prevent the release of further non-conforming product to the customer.
To the OP - I'd say if you haven't done so already, open a Corrective Action and really get to the root of the issue. This is especially valid if you're ISO certified. Section 8.7.1 of the 2015 standard states: "The organization shall ensure that outputs that do not conform to their requirements are identified and controlled to prevent their unintended use or delivery.
Just my :2cents:.
AeroSteve
#12
We have struggled with this in the past too. One simple update to our QMS that has helped us is:
When we find that a part is scrap, (assuming we are holding the part when we find out) we Literally do not set the part down until we mutilate the part.
So for example, the operator is using a micrometer to inspect a diameter and finds it to be undersize, before he sets it down, he walks over to the bench vise and smashes the part, or to the the saw and cuts it in half, etc.
It hasn't solved all our problems in this area, but this has helped.
weakness
#13
You can create an instruction first ... (3,5,7)parts will seperate and will check detailed after production by only one operator.
Keep in quarantine area (until production finished)
This is different from %100 because one operator can controlled sensetively.
And seperation is ideal solution for this kind of parts.
You can choose best operator from MSA .
I
ISOCOP
#14
Yes bar ends can be misconstrued as nonconforming setup parts. We require the operators to bring all nonconforming setup parts to QA along with the first article submission.
Raffy Is my machine setup control plan part of the overall control plan FMEA and Control Plans 2
V Setup for testing against ISO14708 clause 16 (protection of the patient from herms caused by heat) Other Medical Device Related Standards 0
C Scrapping on production floor - Setup parts 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
M What is "setup control chart"? Statistical Analysis Tools, Techniques and SPC 2
S Machine Setup for a CNC Machine Capability Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
M Criteria and when to carry out Setup Approval Manufacturing and Related Processes 5
S IEC 60601-1-2 immunity to proximity fields Test setup - Diagnostic ECG device IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S IEC 60601-1-2 - RF Conducted Immunity Test Setup - Diagnostic ECG device IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
T Operational setup of how FIFO / Process Map on Lithium Batteries is done Manufacturing and Related Processes 1
P Controlled Setup Sheets for a production line Document Control Systems, Procedures, Forms and Templates 2
P Setup Verification in IATF 16949 Clause 8.5.1.3 IATF 16949 - Automotive Quality Systems Standard 6
S New Electronics Manufacturing Setup - Checklist/Gantt chart Manufacturing and Related Processes 4
W How much would it cost to setup a Quality System for a Repackager or Relabeler? Quality Manager and Management Related Issues 1
Q Pin Gauge Setup - Measuring the OD of a Catheter Manufacturing and Related Processes 1
J Setup/structure of IDE in the US Other US Medical Device Regulations 3
A 7.5.1.3: Verification of job setup query, sample WI required. IATF 16949 - Automotive Quality Systems Standard 5
M Setup Time vs. Economic Run Quantity Manufacturing and Related Processes 1
D Template for the kind of naming convention on my test setup Manufacturing and Related Processes 2
C Setup Time Reduction Project - How big should my team be? Six Sigma 2
D What to verify on Test Setup for Environmental Testing General Measurement Device and Calibration Topics 7
K How to setup DDEs in Minitab to link a project to an Excel workbook Quality Tools, Improvement and Analysis 2
S Instrument Calibration Laboratory setup for API Pharmaceutical Company General Measurement Device and Calibration Topics 1
F FMEA Optimization for our Die Setup Process FMEA and Control Plans 2
A Donabedian Model in Healthcare Setup Hospitals, Clinics & other Health Care Providers 2
A Setup Controls in a Process Control Plan FMEA and Control Plans 2
V Should the Line Clearance include Machine Setup for current Operation? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
J GR&R (Gage R&R) Sample Setup for Attribute Inspection Gages Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
N Calibration of Setup Fixtures & Pin Gages General Measurement Device and Calibration Topics 5
O Weighting Problems (Statistics) - Weight distribution for a machine setup Capability, Accuracy and Stability - Processes, Machines, etc. 5
H Implement standardized work in the setup operations of a pharmaceutical packing line? Lean in Manufacturing and Service Industries 2
D Setup Verification Documentation for multiple parts that have same lathe operation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Setup sheet for machine shop Document Control Systems, Procedures, Forms and Templates 3
G Video Example of Quick Setup Lean in Manufacturing and Service Industries 8
M Calibration of Custom 6061 T6 Aluminum or Delrin Plastic Setup Tools?? General Measurement Device and Calibration Topics 5
R Facility setup for Substrate & PCB Visual Inspection Manufacturing and Related Processes 5
P Criteria for operator's readings at setup - Seeking help to explain chosen limits. Statistical Analysis Tools, Techniques and SPC 4
Colin Computer monitor setup - Setting up an LCD monitor on a PC After Work and Weekend Discussion Topics 8
K Work Station Setup - How can we put the 5S rule into play? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M Business Wireless network setup After Work and Weekend Discussion Topics 10
V Retain machine setup forms from each run? Records and Data - Quality, Legal and Other Evidence 16
A Statistical methods for setup verifications - One of the OFIs the auditor suggested IATF 16949 - Automotive Quality Systems Standard 11
N Document Control in Manufacturing - Machine Setup Sheets Document Control Systems, Procedures, Forms and Templates 9
A Setup at Final Testing (electrical test) FMEA and Control Plans 1
Q Setup Verification, need help QS-9000 - American Automotive Manufacturers Standard 4
M Effect of Sampling on Setup Verification Requirements Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Should Tooling Documentation (such as tooling setup instructions) be Controlled? QS-9000 - American Automotive Manufacturers Standard 1
D How to setup a system for Predictive Maintenance QS-9000 - American Automotive Manufacturers Standard 8
A Complaint review as part of the complaint handling process? ISO 13485:2016 - Medical Device Quality Management Systems 2
D FDA Guidance on Computer Software Assurance versus 21 CFR Part 11 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
F Physical Part Measurement General Measurement Device and Calibration Topics 5
