Setup sheet for machine shop
K
kmyers
We have a setup sheet for our operators to follow when they are preparing a machine to run a job. The team leader fills this blank form in with all appropriate info regarding tool#'s, machine speed, feed speed etc. The blank sheet is controlled. Once the team leader fills in the appropriate info that sheet is saved to a particular part #. When the part number is run again it will then print out with the router, print etc that makes up a job packet. Being a job shop we have numerous part #'s. We currently have hundreds of these that are filled out.
The team leaders do alot of cutting from other spreadsheets and pasting into these setup sheets as a time saver. When the original sheet was made certain cells were not formatted to accept some things that are pasted to it.
So if you're not to confused, here's my question.
Can I change a format in a cell without having to issue a new rev. level?
The change is blind so I am not sure, no text is being changed, nothing added or removed, it's just a format change to a couple of cells.
Please let me know what you think.
Kris
P
Pudge
I believe a rev. level change would be appropriate only if information is being taken away, added, or rearranged. If this is only being changed in the format of the software like excel....then it doesn't constitute a rev. change.
Jeremy Hill
Stijloor
Kris
Kris,
How well does this work for you? Is this effective? No problems with it?
Then it's no problem.
Stijloor.
K
kmyers
That was my opinion also, but I know that there are many on here with alot more knowledge than myself.
V Setup for testing against ISO14708 clause 16 (protection of the patient from herms caused by heat) Other Medical Device Related Standards 0
C Scrapping on production floor - Setup parts 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
M What is "setup control chart"? Statistical Analysis Tools, Techniques and SPC 2
S Machine Setup for a CNC Machine Capability Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
M Criteria and when to carry out Setup Approval Manufacturing and Related Processes 5
S IEC 60601-1-2 immunity to proximity fields Test setup - Diagnostic ECG device IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S IEC 60601-1-2 - RF Conducted Immunity Test Setup - Diagnostic ECG device IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
T Operational setup of how FIFO / Process Map on Lithium Batteries is done Manufacturing and Related Processes 1
P Controlled Setup Sheets for a production line Document Control Systems, Procedures, Forms and Templates 2
P Setup Verification in IATF 16949 Clause 8.5.1.3 IATF 16949 - Automotive Quality Systems Standard 6
G Setup Part Management - Preventing Escape Manufacturing and Related Processes 13
S New Electronics Manufacturing Setup - Checklist/Gantt chart Manufacturing and Related Processes 4
W How much would it cost to setup a Quality System for a Repackager or Relabeler? Quality Manager and Management Related Issues 1
Q Pin Gauge Setup - Measuring the OD of a Catheter Manufacturing and Related Processes 1
J Setup/structure of IDE in the US Other US Medical Device Regulations 3
A 7.5.1.3: Verification of job setup query, sample WI required. IATF 16949 - Automotive Quality Systems Standard 5
M Setup Time vs. Economic Run Quantity Manufacturing and Related Processes 1
D Template for the kind of naming convention on my test setup Manufacturing and Related Processes 2
C Setup Time Reduction Project - How big should my team be? Six Sigma 2
D What to verify on Test Setup for Environmental Testing General Measurement Device and Calibration Topics 7
K How to setup DDEs in Minitab to link a project to an Excel workbook Quality Tools, Improvement and Analysis 2
S Instrument Calibration Laboratory setup for API Pharmaceutical Company General Measurement Device and Calibration Topics 1
F FMEA Optimization for our Die Setup Process FMEA and Control Plans 2
A Donabedian Model in Healthcare Setup Hospitals, Clinics & other Health Care Providers 2
A Setup Controls in a Process Control Plan FMEA and Control Plans 2
V Should the Line Clearance include Machine Setup for current Operation? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
J GR&R (Gage R&R) Sample Setup for Attribute Inspection Gages Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
N Calibration of Setup Fixtures & Pin Gages General Measurement Device and Calibration Topics 5
O Weighting Problems (Statistics) - Weight distribution for a machine setup Capability, Accuracy and Stability - Processes, Machines, etc. 5
H Implement standardized work in the setup operations of a pharmaceutical packing line? Lean in Manufacturing and Service Industries 2
D Setup Verification Documentation for multiple parts that have same lathe operation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
G Video Example of Quick Setup Lean in Manufacturing and Service Industries 8
M Calibration of Custom 6061 T6 Aluminum or Delrin Plastic Setup Tools?? General Measurement Device and Calibration Topics 5
R Facility setup for Substrate & PCB Visual Inspection Manufacturing and Related Processes 5
P Criteria for operator's readings at setup - Seeking help to explain chosen limits. Statistical Analysis Tools, Techniques and SPC 4
Colin Computer monitor setup - Setting up an LCD monitor on a PC After Work and Weekend Discussion Topics 8
K Work Station Setup - How can we put the 5S rule into play? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Raffy Is my machine setup control plan part of the overall control plan FMEA and Control Plans 2
M Business Wireless network setup After Work and Weekend Discussion Topics 10
V Retain machine setup forms from each run? Records and Data - Quality, Legal and Other Evidence 16
A Statistical methods for setup verifications - One of the OFIs the auditor suggested IATF 16949 - Automotive Quality Systems Standard 11
N Document Control in Manufacturing - Machine Setup Sheets Document Control Systems, Procedures, Forms and Templates 9
A Setup at Final Testing (electrical test) FMEA and Control Plans 1
Q Setup Verification, need help QS-9000 - American Automotive Manufacturers Standard 4
M Effect of Sampling on Setup Verification Requirements Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
B Should Tooling Documentation (such as tooling setup instructions) be Controlled? QS-9000 - American Automotive Manufacturers Standard 1
D How to setup a system for Predictive Maintenance QS-9000 - American Automotive Manufacturers Standard 8
B AOS Assembly Operations Sheet Inquiry Manufacturing and Related Processes 0
S Transitional Adolescent A and B - "CDRH PREMARKET REVIEW SUBMISSION COVER SHEET FORM FDA 3514" Medical Device and FDA Regulations and Standards News 1
