Severity, Occurance and Detection ratings seem qualitative
P
Pazuzu - 2009
#11
Ok, obviously something as been taken the wrong way.
Never did I mention that the RPN# is the bible and that there should be a hard and fast point at which something should or should not be evaluated. Yes it is relative, yes there are other parameters to review before making a decision (as there always should be). What I did mention is that both the RPN and the individual numbers (S/O/D) should be reviewed. If the RPN is higher than acceptable look at the individuals to see where the culprit is. If the RPN is low, review the individuals as well just in case there is one errantly high number. The question is...what number is acceptable in terms of both RPN and individual? That is something that should be decided from the get go.
#12
Well, you said,
The important thing to remember is to set a standard for re-evaluation of the process. Not being from the auto industry I'm not 100% positive but I think the generally accepted RPN number is 100.
Sorry, Pazuzu, but what you're saying is that the S-O-D numbers should be evaluated regardless of their RPN product, which is absolutely correct, but also absolutely contradicts your threshold premise.
No, it's not. The purpose of performing the analysis is to discover and evaluate potential sources of risk, so the purpose is at least partially defeated if you make up your mind "from the get go" that any RPN with a value greater than x requires special action.
P
Pazuzu - 2009
#13
I never said that 100 is THE threshold. I never said that any number in paricular is THE threshold. In fact, I never even said there should be a "threshold" until you mentioned it. What I did say is that I have been told by a few people from inside the auto industry that 100 is generally used. Whether or not this is the same parameter for other industries I have no idea. I also stated that the SOD numbers are equally assessed and that 7 is generally used by those same individuals.
Use whatever numbers you want...dont use whatever numbers you want...just do whatever works best for your application.
Sorry if my initial choice of words were interpreted wrong...that's the difficulty with forums.
#14
Just to pass along another twist on the FMEA philosophy, I was trained in an earlier life to a "FEMCA" philosophy (the Shanin Risk ReduXtion philosophy) and "D-FEMCA" for design projects. When you approach an FMEA with this different spin, you are looking first at the "Effects" then the "Modes" and potential "Causes" as opposed to the "Modes" then "Effects". In other words, you look at the "Y" (effect) before you look for the "X" (root cause).
Using this approach, you still use the Severity, Occurrence and Detection numbers; however, setting "Bogeys" (as they were called to us) by setting an arbitrary RPN threshold was frowned upon. Instead, the approach was to rank the failures and systematically analyze them from worst to least.
The other "key" to not setting bogeys was so you didn't "stop" analyzing the data when you reached that magic threshold. The plan was to set a reasonable length of time within the project framework and then knock down the potential failure effects one by one until you run out of time. Of course, a lot of thought needs to go into this approach as well since you don't want to give yourself a month to fix a year's worth of problems - but it's merely a different perspective on a time honored risk analysis tool.
Just my :2cents: ... :bigwave:
-Steve
tac123
#15
Agreed that it should be taken as reference because of the possible situations you mentioned...but is there not typically a limit as which point it should be evaluated? The threshold I'm referring to is a generic number...not an absolute. Understood that sometimes things cannot be done...and understood that sometimes you can improve it when it "seems" there is no need to...but if there is no threshold then what's the point of putting a numbering system against it?
Stay away from Thresholds or else all of a sudden you will find all the RPNs will magically come out below this threshold. Instead work on top 5, 10 or 20 items until you feel all risk is at an acceptable level or keep doing the continuous improvment thing.
Engineers are great at selecting three numbers that will come in below your threshold. Whoever first came up with the idea of a threshold on a subjective ranking scheme should be locked away.
J DFMEA SOD Rating Scale - Severity, Occurance, and Detection FMEA and Control Plans 1
R DFMEA/PFMEA mitigation of high severity (9-10) in low volume products IATF 16949 - Automotive Quality Systems Standard 1
silentmonkey How to measure severity if my product is designed for emergency use and failure would result in death? ISO 14971 - Medical Device Risk Management 9
S The Severity of a Medical Device Hazard - Risk Analysis Clarification ISO 14971 - Medical Device Risk Management 6
MrTetris Informational Risk Register - Same hazardous situation, different severity of harms ISO 14971 - Medical Device Risk Management 7
A PFMEA severity score different applications FMEA and Control Plans 11
X Customer Service FMEA - Specifically Customer Care / Severity Rankings Service Industry Specific Topics 3
D How to fill a Process FMEA - Three columns - Severity, occurrence and Detection FMEA and Control Plans 16
R DFMEA Severity 9-10 with Occurrence 3 and Detection 3 - Actions FMEA and Control Plans 3
S What should the FMEA Severity for SC & CC Characteristics be? FMEA and Control Plans 4
N AIAG 4th ed. FMEA Manual "Fit" Changed to "Appearance" - Fit severity? FMEA and Control Plans 2
G Severity in Process FMEA for Rework Process FMEA and Control Plans 1
O PFMEA - Reducing Severity (S) Ranking - Manufacturing Process Design Changes FMEA and Control Plans 4
S FMEA's - Severity and Classification of Print Characteristics FMEA and Control Plans 1
N Risk Severity Estimation for Medical Devices as per ISO 14971 ISO 14971 - Medical Device Risk Management 12
C Determining PFMEA Severity for Armored Parts FMEA and Control Plans 5
C FMEA DOGMA about Severity - Am I right or Wrong? FMEA and Control Plans 2
K 4th Edition AIAG FMEA Occurrence, Severity and Detection Criteria for Plastics FMEA and Control Plans 1
F Risk = Likelihood * Severity - Can we mitigate the Severity? Occupational Health & Safety Management Standards 44
M Severity Reduction in a Design FMEA (DFMEA) FMEA and Control Plans 25
E Risk Management selection Probability of Occurrence and Severity ISO 14971 - Medical Device Risk Management 24
S Severity of 9 or 10 should be identified as Special characteristic? FMEA and Control Plans 10
G Internal vs. External PFMEA Severity Rankings FMEA and Control Plans 12
R Risks which must be Distinctly Identified - Harm, Hazard, Severity ISO 14971 - Medical Device Risk Management 7
C Severity of Effect on Process (Manufacturing/Assembly Effect) Scrap or Reworking FMEA and Control Plans 3
W Severity Rating CORRECTIVE ACTIONS - Opinions Wanted Please Nonconformance and Corrective Action 15
H DFMEA Severity Ranking of Non-Compliance to EMC Standards FMEA and Control Plans 2
P Chemical Purity Testing - FMEA Severity Scale FMEA and Control Plans 2
T FMEA Severity 9 &10 - Example of "with warning?" FMEA and Control Plans 6
E Harms Severity Scoring - Combination of Hazards ISO 14971 - Medical Device Risk Management 4
B The Distribution that represents the Severity of Nonconformances Nonconformance and Corrective Action 2
A AIAG Design FMEA Severity Rankings - Noncompliance Government Regulation? FMEA and Control Plans 9
D Severity or Occurrence? Performing an FMEA on Motorcycle Operation FMEA and Control Plans 9
L FMEA Occurrence, Severity and Detection Criteria FMEA and Control Plans 3
I Ford FMEA requirements for Severity and Occurrence Rankings Customer and Company Specific Requirements 1
G FMEA Severity Ranking for an Automotive Audio System FMEA and Control Plans 9
Chennaiite FMEA Severity Rating for Potential Manufacturing Effect mentioned in the FMEA manual FMEA and Control Plans 9
kedarg6500 FMEA Severity Scale - Higher for Failure at Customer's or End-Customer's place? FMEA and Control Plans 19
M FMEA Severity Ratings for Health Care Information System FMEA and Control Plans 10
C Does the PFMEA Severity have to match the DFMEA Severity? FMEA and Control Plans 3
P Measuring Severity of Construction Nonconformance Report Nonconformance and Corrective Action 3
L Standard for process control level depending on gravity (severity)? FMEA and Control Plans 7
I Defining a Severity Level of a non-conformance Nonconformance and Corrective Action 13
Y Severity, Occurrence and Detection FMEA Ranking Tables - Guidelines? FMEA and Control Plans 8
L FMEA - Should a severity of 9 or 10 be always followed by recommended actions? FMEA and Control Plans 2
J Severity of Finding for "Past Due Gage" found on the shop floor General Measurement Device and Calibration Topics 40
S FMEA Severity of 9 or 10 - Shower does not operate FMEA and Control Plans 13
J Ranking Severity of Non-Conforming Material Defects Nonconformance and Corrective Action 5
V Emphasizing Severity more than Occurrence and Detection vs. Overall RPN FMEA and Control Plans 20
