Shewhart Control Chart for SPC In Excel - Explain the yellow and red marked column
Muhd Firdaus
Dear member,
i have found the attached information while browsing internet today and would like to share it with everybody in this forum. However,i would like to seek your cooperation as to explain the yellow and red marked column in the attachment. i do not understand how the value been obtained. Maybe anyone here can explain. Thank You.
DRAMMAN
Re: Shewhart Control Chart for SPC (using excel)
If you are asking what an "A2" constant is I will attempt to explain it and where it came from. The typical control limit formula is (X double bar)+-3std deviations. If you have ever manually calculated the standard deviation of a large data set you understand it is time consuming and relatively complicated. You have to remember that SPC was invented in the 1920's so the average person did not have any kind of advanced math training and there were no computers or calculators. Recognizing this, some smart people came up with these constant's to simplify the calculation of the control limits. These days, the modern SPC computer application gives you the ability to decide between using the constants or using the actual std deviation. The A2 constant changes depending on your sub-group size. A 5pc sub-group has a different A2 than a 4pc sub-group and so on. If you have only used SPC in the computerized age or never did SPC on paper charts then it would be normal to have no idea what A2 is. So essentially, the document describes how to create SPC charts in Excel replicating the original manual paper based approach. You could also make SPC charts in Excel using the actual STD Dev calculations but it is a little easier to construct the file using constants. Both approaches are acceptable and will usually yield only slightly different CL's. The only way to truly understand this is to gain a solid complete understand of how to construct SPC charts manually on paper. Many of us have created our own SPC Excel files. You could probably find a 100 examples on this forum.
My advice is to study the SPC basics first before trying to create Excel files to make SPC charts.
Steve Prevette
Deming Disciple
Re: Shewhart Control Chart for SPC In Excel - Explain the yellow and red marked colum
Note - tables of the A2 value versus subgroup size may be found in several stats textbooks (including Acheson Duncan's Quality Control and Industrial Statistics) or google "Control Charts Constants". This link http://www.buec.udel.edu/kherh/table_of_control_chart_constants.pdf is the first one that came up for me.
If you generally stick to the same subgroup size, such as 4 or 5, then you don't have to keep searching the table. That is, unless you have some rational need to change subgroup size.
S used excel formula calculated the ARL's with Rule1&Rule2 for Shewhart control chart Statistical Analysis Tools, Techniques and SPC 0
T Shewhart Control Chart - ISO/TS 13530:2009(E), Page 22. General Measurement Device and Calibration Topics 3
I Shewhart Constants vs Central Limit Theorem in calculating Control Limits Statistical Analysis Tools, Techniques and SPC 18
D Are Four Sigma Control Limits based on Shewhart's work Statistical Analysis Tools, Techniques and SPC 3
G Why for a Shewhart chart the minimum feasible value for APL is 2401 units? Statistical Analysis Tools, Techniques and SPC 8
U Shewhart, Deming and Data - a thought provoking article Statistical Analysis Tools, Techniques and SPC 3
Randy Deming and Shewhart information for Power Point slides related to P-D-C-A Philosophy, Gurus, Innovation and Evolution 8
G How to implement H&S and Quality Control Requirements in Contract for Potential Supplier? Contract Review Process 6
D GAMP CAT 5 Change Control Qualification and Validation (including 21 CFR Part 11) 9
D Use Error Risk Controls and Control Verification ISO 14971 - Medical Device Risk Management 6
S Maintenence related action in Control plan FMEA and Control Plans 3
M ISO 13485 and document control for programs ISO 13485:2016 - Medical Device Quality Management Systems 6
R Control Methods in Control Plan FMEA and Control Plans 4
M Design Control - Management of Electronic CAD files Design and Development of Products and Processes 11
S TSCA (Toxic Substances Control Act) PIP 3:1 RoHS, REACH, ELV, IMDS and Restricted Substances 0
S Use of Attributes Control Charts Statistical Analysis Tools, Techniques and SPC 1
U Appraiser Out of Control Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
L Looking for Control Plan and FMEA Stamping process FMEA and Control Plans 2
Z AS9100 Control of Nonconforming Outputs - Rework Dispositions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
K ASME, ANSI, ASTM and similar specifications and their requirements for document control. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
Z Software for design control ISO 13485:2016 - Medical Device Quality Management Systems 5
K Quality Control/Assurance in the Metal Industry Quality Tools, Improvement and Analysis 10
K Defining risk control measures IEC 62304 - Medical Device Software Life Cycle Processes 14
J Warehouse temperature and humidity control EU Medical Device Regulations 7
Jimmy123 IATF16949 Control Plan FMEA and Control Plans 1
D Control Number for Class III and IV devices Canada Medical Device Regulations 1
C UDI Questions on Control Units Other US Medical Device Regulations 6
A Quality Control Datasheets Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M Control-self assessment Internal Auditing 5
GreatNate Master Control QMS software Quality Tools, Improvement and Analysis 1
A Prototype control plan FMEA and Control Plans 2
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 4
W FMEA - Current control and occurrence rating FMEA and Control Plans 3
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 8
N What are the software audit and control steps Reliability Analysis - Predictions, Testing and Standards 2
A Fabric roll inspection - What type of Control Chart to use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
C Monitoring and Control Instruments RoHS, REACH, ELV, IMDS and Restricted Substances 3
M ISO14971:2019 - Verification of implementation and effectiveness of risk control ISO 14971 - Medical Device Risk Management 3
T Risks arising from control measures vs. ineffective control measures ISO 14971 - Medical Device Risk Management 11
J Need Change Control Yes/No Decision Tree Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
P IQ, OQ, PQ protocol, and report templates for Distributed Control Systems in Pharmaceutical Manufacturing Systems. Qualification and Validation (including 21 CFR Part 11) 0
R Risk control measures as per ISO 14971 ISO 14971 - Medical Device Risk Management 6
T Linking Control Plans and PFMEA's FMEA and Control Plans 3
