Short and Long term effects of humidity on tooling and gages
  • Thread starter DE_Perry - 2006
  • Start date
DE_Perry - 2006
Good day. My company has just set up a Calibration Lab and I am one of the people responsible for the calibration of the equipment, which consists mainly of calipers, micrometers, height gauges and other hand tools for a machine shop.
The humidity readings in the lab have hovered around 65 to 75% over the past few days so I haven't done any calibration. Our procedures state that the humidity must be a fixed rate between 35 and 55% RH, with a +- tolerance of 5% (taken from ISO 17025).
Although I know that the humidity is too high I would like to know the short term and long term effects of humidity on tooling, so I can explain to my manager why I can't do any calibration (and possibility get better climate control in the lab).
Any help would be much appreciated.
Wesley Richardson
Wes R
Although I know that the humidity is too high I would like to know the short term and long term effects of humidity on tooling.
With ferrous based materials, such as steel micrometers, unless they are made of stainless steel, the high humidity is likely to cause corrosion or oxidation. This also applies in the shop areas where they are used, not just in the calibration laboratory.
Preventative measures are to lower the humidity or to apply a rust preventative oil or mist. One problem with this is the oil film can affect the reading and may also leave a residue on the measured part.
For dimensional measurement devices made of metal, the temperature has a greater effect on the calibration than does the humidity. For electrical devices, a high humidity can lead to arcing in high voltage circuits, while too low a humidity can lead to static charge buildup on people in contact with the device. The use of electrostatic discharge grounding straps will drain off the static charge.
Wes R.
jmp4429
Also, if you're calibrating any good part or bad part masters, depending on what they're made of they could absorb moisture from the air, causing swelling and warpage.
Hershal
Metrologist-Auditor
Wes is correct, for long term, primarily the high RH accelerates oxidation (read: rust).....the best environment is one you mentioned that you have in your own internal standard, except I would drop it to an upper limit of 50%, based on recommendations from NCSLI contained in the RPs.
The short term effects are not as obvious. Temp has a more dramatic direct effect, but temp and RH do have a relationship.....sufficient RH can drive temp a degree or two, creating the reverse of a chill factor.
You might consider having your internal lab accredited, and in Canada the first folks to talk to is SCC/CLAS. That will also cement the requirement for control, which could help you.
Hope this helps.
Hershal
DE_Perry - 2006
Thank you. We've only just started calibration so I doubt my work will want to get the lab accredited, but I can certainly bring it to their attention (We're just a small place with about 180 tools in total). Temp isn't a problem as I have a sufficent air conditioner, but I'm hoping to bring in the equipment to keep the RH at about 35%, +-5%.
The air conditioner should be doing a good enough job of controlling humidity; it seems that if you have an air conditioner running and the RH is still in 65-75% range, there's something wrong with the air conditioner.
DE_Perry - 2006
I don't know much about how to condition a room but I'm starting to think that the insulation they just installed on top of the room (it butts out from a wall) might be trapping the humidity inside.
They bought a 12,000 BTU air conditioner for an 8 X 8 ft room, so it's a little over-powered. Hopefully I can convince them to change that.
I've actually not done calibration before but I was apparantely the best choice since I'm the Incoming Inspector (I have no idea how top management got from point a to point b) but I don't think they realized the amount of work that would actually go into in-house Calibration. I kept repeating the Starrett phrase, 'When in doubt, send it out', but I guess no one heard me. :)
A How to systemically improve product quality in short-term and long-term basis? Preventive Action and Continuous Improvement 1
B Short term vs Long term Capability - We ship millions of parts in a year Capability, Accuracy and Stability - Processes, Machines, etc. 7
kedarg6500 Sample Size for Short Term & Long Term Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 2
S Pp/Ppk & Cp/Cpk - Which is appropriate for Long/Short Term Study? Statistical Analysis Tools, Techniques and SPC 20
R Short-term vs. Long-term Variation Six Sigma 5
J Short Term and Long Term Quality Objectives AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
Chennaiite Interpretation of Short term vs. Long term Capability Studies Statistical Analysis Tools, Techniques and SPC 3
D Cpk vs. Ppk - Long Term vs. Short Term - Capability vs. Stability Capability, Accuracy and Stability - Processes, Machines, etc. 29
A Capability: Short Term or Long Term? Cpk= Long term and Ppk= Short term? Capability, Accuracy and Stability - Processes, Machines, etc. 18
T Process Capability - Long-term vs. Short-term Statistical Analysis Tools, Techniques and SPC 9
M Gage R&R Short Study vs. Long Study vs. Other Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 25
P Long and Short (Variable Data) Gage Studies - Urgent Help needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
CalRich Short Form vs. Long Form Calibration Certificate General Measurement Device and Calibration Topics 13
D SINGLE FAULT CONDITION, short circuit and open circuit of any component (IEC 60601-1 3.1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
Ajit Basrur Definitions - Short-term and Brief exposure Occupational Health & Safety Management Standards 2
supadrai My short yet eventful stint as a regulatory affairs lawyer dude is coming to an end! Career and Occupation Discussions 1
G Uncertainty of staging a short line scale standard on longer measuring machine? Measurement Uncertainty (MU) 4
R Height gauge to measure short hard to access heights General Measurement Device and Calibration Topics 3
P SPC Short Run Advice of a Stamping Process Statistical Analysis Tools, Techniques and SPC 3
D Balancing between Strategic Objectives & Short Term Priorities Quality Manager and Management Related Issues 2
M Standardized P Chart for Short Run Production Statistical Analysis Tools, Techniques and SPC 13
B How to Demonstrate Stability and Repeatability in very Short Run Process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
E Short Case Studies - Major/Minor Nonconformance, Observation or OK? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B Quality-related short term course in Perth Australia Coffee Break and Water Cooler Discussions 5
W Supply Voltage Condition for Transformer O/L and S/C (open & short circuit) testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
E Expiration Date on Label for different Countries (Short Shelf Life Product) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D IMR (Individuals and Moving Range) Chart for Short-Run SPC - How much data to include Statistical Analysis Tools, Techniques and SPC 1
R What is a "DNOM Chart" in reference to Short Run SPC? Statistical Analysis Tools, Techniques and SPC 2
Fender1 How to comply with ISO 9001 and provide quick/short lead-time orders? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
P Understanding IEC 60601-1:2005, Clause 8.1 b) - Short Circuiting Double Insulation IEC 60601 - Medical Electrical Equipment Safety Standards Series 13
H Looking for short videos that cover what ISO 9001 is Training - Internal, External, Online and Distance Learning 1
P Analysis of the figures from Dr Wheeler's 'Short Run SPC' Using Minitab Software 3
S Book for SPC Short Run - Recommendations Book, Video, Blog and Web Site Reviews and Recommendations 12
R Are multi-faults needed? Effects of a Short Circuit IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
D Short Run Cpk and Minitab Capability, Accuracy and Stability - Processes, Machines, etc. 7
R Should the fault tests pass if temperature goes high in short time? IEC 60601 - Medical Electrical Equipment Safety Standards Series 15
S Aspect vs. Impact and Hazard vs. Risk - Short/clear explanation & example Miscellaneous Environmental Standards and EMS Related Discussions 11
O Short Run SPC Chart Template needed Document Control Systems, Procedures, Forms and Templates 5
D Short Quality Cases for my Quality Workshop so I can make a Case Study Quality Tools, Improvement and Analysis 10
E Error Proofing to prevent Length Short - CNC Turning Process Manufacturing and Related Processes 4
Sidney Vianna Short notice audits - Have you been through or triggered one? Registrars and Notified Bodies 4
N Which is more appropriate Regular or Short Run control charting? Statistical Analysis Tools, Techniques and SPC 8
A Injection Mold 100% Visual Inspection - Short Shots and Debris not being found Inspection, Prints (Drawings), Testing, Sampling and Related Topics 22
A Normal Deviation - short cut/method to calculate sigma Statistical Analysis Tools, Techniques and SPC 2
M Any Bridge Courses or short term courses available which helps the Career Training - Internal, External, Online and Distance Learning 3
K Short Term Corrective Action Methods Customer and Company Specific Requirements 2
P Short Molding Issue - Plastic Injection Molding from a Multi Cavity Mold Quality Manager and Management Related Issues 13
E How to Effectively Apply Short Run SPC Statistical Analysis Tools, Techniques and SPC 33
T ASQ CQE Recertification - I might be a little short on points - What to do? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 4
