Short SOPs (Standard Operating Procedures) or Add to Quality Manual?
I
IanFarrell
I'm building our QMS to ISO 9001 and working with a 4 tier document system. Level I is Quality Manual, Process Flowchart, etc. Level II is SOPs. Level III is task-specific work instructions. Level IV is forms.
For most aspects of the system, I have a short policy statement in the Quality Manual and a larger SOP describing the details and how a procedure is carried out. Examples are Calibration, External Audit, etc.
For some aspects, I'm having a difficult time. Specifically Preventive Maintenance and Facilities Maintenance. I just don't have enough material to make a useful SOP. Can the Quality Manual house these subsystems completely? Typically I leave Document Scope and Responsibilities in the SOP, but I'll have to sneak those into the Quality Manual.
Am I just being picky and trying to over-format everything?
somerqc
Re: Short SOPs or Add to Quality Manual?
Ian,
There is no need for the 4 levels.
ISO 9001:2000 (soon to be 2008 with no effective changes) does not require this type of structure.
Save yourself a great deal of time and only document what needs to be documented (this is allowed with ISO 9001:2000 with the exception of the "big 6" required procedures).
The company and you will appreciate a system that is useful and not full of the jargon that older quality systems were full of.
The only exception to this may be when you are a "site" of a larger corporation. Many times larger corporations will have a "required" policy manual that is sent by corporate. If you do not have this situation, just stick to documenting what needs to be documented.
This is my :2cents: but it is hard enough to get people to read the "big honking binder" no need to give them even more reasons for not reading it.
John
Saenz - 2011
ISO 9001 allows the manufacturer to leave out irrelevent activities. If you don't do facilties maintenance or preventive maintenance (which makes me wonder what you do) then you don't need to write an SOP. I would, as an auditor, appreciate a very short paragraph in your quality manual that states you don't don't have need for these procedures because ----. That way you won't get asked the same question over and over again.
If the activity consists of a checklist, you can name it in the QM. If it's instructions, then you should separate them out, some SOPs are only a page long--great! I say this because you can't expect a line worker to read the QM cover to cover, and everybody loves to find their training on an activity is short and sweet.
Raffy
hI IanFarrell,
For the Preventive & Facilities Maintenance, what we did is to based the maintenance procedure on a specific equipment, i.e. Machine PM. and that makes out life more simpler....
Raffy
SteveK
Hi Ian,
I tend to disagree with some of the statements thus far. You do end up with the levels you indicate if you follow ISO 9001, it is just the nature of the beast. In one of the threads I found an audit presentation covering this pointas part of audit training (cannot remember where!) – in fact taking it one step more i.e. forms become records. Although it might be seen as a burden having more than the “big 6” SOPs, there may be other reasons for having a facilities SOP e.g. your insurance company might appreciate that you have some documentation to that effect (might get more full blown request like having a Business Continuity Plan – but I won’t go there!). I have a basic SOP that might help (references other non-attached documents – but I hope it gives the idea).
A1Golfer - 2009
:agree1::caution:
Patricia Ravanello
Hi Ian,
No you're not being too picky, or over-formatting everything. You're right on the money.
Your overall Management System is made up of several Key Processes, which you identified, such as Internal Auditing and Calibration. You are very intuitive to recognize that "Preventive Maintenance and Facilities Maintenance" need to be in there somewhere, but where?
I faced the same dilemma the first time I tried to distinguish between the "superior/key" processes, and the "subordinate" ones.
The solution is to have an SOP called "Infrastructure, Production and Service Support". Obviously, these functions are intrinsic to how your overall system works, and the challenge is to find a way to incorporate all these "loose string" subjects that seem to be orphans, relative to the other Procedures.
These are some of the "Orphan" activities:
  • Health and Safety
  • Environmental Controls
  • Capital purchases
  • Preventive Maintenance
  • Infrastructure Support (heat, hydro, water, etc.)
  • Training on the Job
  • Plant, Facility and Equipment Planning
  • Contingency Plans
  • Work Environment
  • Personnel Safety to achieve Product Quality
  • Cleanliness of Premises
  • Production and Service Provision
Part of the reason why it's not so evident that it exists is because in some companies, it's controlled at higher levels, so the process is not readily visible, or because, some companies don't share the "Capital planning" process with their managers, although most of them contribute to it in some shape or form and with varying degrees of frequency. Also, some companies are re-active rather than pro-active, so these activities are not planned as they should be, but rather re-acted to when the need occurs...hence no defined process.
I've attached a sample Procedural Level Flow Chart which captures the process which would incorporate your troublesome "Preventive Maintenance" and "Facilities Maintenance". You'll see that it actually captures a lot of the "orphan" activities which are not captured in any other Key Process. Many of these are captured in orphan "Work Instructions" which really don't relate or link to any other processes - they truly are "support" processes.
Of course, you'll need to customize it to your facility, but I think you'll see how it fits in the "big picture", and the inputs and outputs will help you to see what's involved.
Let me know if this helps.
Patricia Ravanello
Patricia Ravanello
Hi Ian,
Hi Steve,
I didn't get a chance earlier to look at your attachment, before posting my response, but I think it's right on. It's somewhat of a narrative version of my flow chart, attached above.
If you have Work Instructions that define how some of these sub-processes/activities occur and who is responsible for each step, it's wise to link them to this document (I don't see an "Associated Documents" field, or inputs and outputs in the document you attached, so I imagine that might be captured in your supporting Work Instructions).
I'm sure your attachment will help Ian tremendously.
Thanks for sharing,
Patricia
H
honest03060
Steve,
Your SOP was extremely helpful. Do you have a similar one to cover Employee motivation?
Thx,
John:agree1:
H
honest03060
Hi Steve, Your SOP was extremely helpful. Do you have an SOP for employee motivation you could share?
John
D SINGLE FAULT CONDITION, short circuit and open circuit of any component (IEC 60601-1 3.1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
Ajit Basrur Definitions - Short-term and Brief exposure Occupational Health & Safety Management Standards 2
supadrai My short yet eventful stint as a regulatory affairs lawyer dude is coming to an end! Career and Occupation Discussions 1
G Uncertainty of staging a short line scale standard on longer measuring machine? Measurement Uncertainty (MU) 4
A How to systemically improve product quality in short-term and long-term basis? Preventive Action and Continuous Improvement 1
B Short term vs Long term Capability - We ship millions of parts in a year Capability, Accuracy and Stability - Processes, Machines, etc. 7
R Height gauge to measure short hard to access heights General Measurement Device and Calibration Topics 3
P SPC Short Run Advice of a Stamping Process Statistical Analysis Tools, Techniques and SPC 3
D Balancing between Strategic Objectives & Short Term Priorities Quality Manager and Management Related Issues 2
M Standardized P Chart for Short Run Production Statistical Analysis Tools, Techniques and SPC 13
B How to Demonstrate Stability and Repeatability in very Short Run Process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
E Short Case Studies - Major/Minor Nonconformance, Observation or OK? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
kedarg6500 Sample Size for Short Term & Long Term Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 2
B Quality-related short term course in Perth Australia Coffee Break and Water Cooler Discussions 5
W Supply Voltage Condition for Transformer O/L and S/C (open & short circuit) testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
E Expiration Date on Label for different Countries (Short Shelf Life Product) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D IMR (Individuals and Moving Range) Chart for Short-Run SPC - How much data to include Statistical Analysis Tools, Techniques and SPC 1
R What is a "DNOM Chart" in reference to Short Run SPC? Statistical Analysis Tools, Techniques and SPC 2
Fender1 How to comply with ISO 9001 and provide quick/short lead-time orders? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
P Understanding IEC 60601-1:2005, Clause 8.1 b) - Short Circuiting Double Insulation IEC 60601 - Medical Electrical Equipment Safety Standards Series 13
H Looking for short videos that cover what ISO 9001 is Training - Internal, External, Online and Distance Learning 1
P Analysis of the figures from Dr Wheeler's 'Short Run SPC' Using Minitab Software 3
S Book for SPC Short Run - Recommendations Book, Video, Blog and Web Site Reviews and Recommendations 12
R Are multi-faults needed? Effects of a Short Circuit IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
D Short Run Cpk and Minitab Capability, Accuracy and Stability - Processes, Machines, etc. 7
R Should the fault tests pass if temperature goes high in short time? IEC 60601 - Medical Electrical Equipment Safety Standards Series 15
S Aspect vs. Impact and Hazard vs. Risk - Short/clear explanation & example Miscellaneous Environmental Standards and EMS Related Discussions 11
S Pp/Ppk & Cp/Cpk - Which is appropriate for Long/Short Term Study? Statistical Analysis Tools, Techniques and SPC 20
O Short Run SPC Chart Template needed Document Control Systems, Procedures, Forms and Templates 5
D Short Quality Cases for my Quality Workshop so I can make a Case Study Quality Tools, Improvement and Analysis 10
E Error Proofing to prevent Length Short - CNC Turning Process Manufacturing and Related Processes 4
Sidney Vianna Short notice audits - Have you been through or triggered one? Registrars and Notified Bodies 4
N Which is more appropriate Regular or Short Run control charting? Statistical Analysis Tools, Techniques and SPC 8
R Short-term vs. Long-term Variation Six Sigma 5
J Short Term and Long Term Quality Objectives AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
M Gage R&R Short Study vs. Long Study vs. Other Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 25
A Injection Mold 100% Visual Inspection - Short Shots and Debris not being found Inspection, Prints (Drawings), Testing, Sampling and Related Topics 22
A Normal Deviation - short cut/method to calculate sigma Statistical Analysis Tools, Techniques and SPC 2
Chennaiite Interpretation of Short term vs. Long term Capability Studies Statistical Analysis Tools, Techniques and SPC 3
M Any Bridge Courses or short term courses available which helps the Career Training - Internal, External, Online and Distance Learning 3
K Short Term Corrective Action Methods Customer and Company Specific Requirements 2
P Short Molding Issue - Plastic Injection Molding from a Multi Cavity Mold Quality Manager and Management Related Issues 13
E How to Effectively Apply Short Run SPC Statistical Analysis Tools, Techniques and SPC 33
T ASQ CQE Recertification - I might be a little short on points - What to do? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 4
G Short TQM training - Choosing of most important points Training - Internal, External, Online and Distance Learning 3
P Short Run Charts - Sample size N=1 Statistical Analysis Tools, Techniques and SPC 2
K Documentation Criteria For Spot Buys of "one time" thing or short-term (3 months) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C How do you justify for that short time of experience? Career and Occupation Discussions 11
H Please Review my Quality Manual (short manual) Quality Management System (QMS) Manuals 7
