Should a supplier self assessment form be a controlled document?
thekellyg
Searched and don't find an answer so here is the question:
Should a supplier self assessment form be a controlled document? We have a third party company coming to do a gap analysis next week after which they are producing the manual (and they are going to find more of a gulf than a gap across the board. I feel like the little Dutch boy and need thousands of fingers.) so if the answer is "depends on how you write your Manual", I'll work it out with them. As always, thanks for your guidance!! :bigwave:
Reg Morrison
Re: Supplier assessment form
Sorry for not answering your question, but be careful with "third-party" developed manuals. Many times, they will "develop" a manual that is a canned template and your manual ends up being exactly like hundreds of other victims clients.
There are some unaccredited outfits that sell a bundled implementation and certification and, the "implementation" phase is nothing more than a farce in interviewing the staff, disregarding all of the information collected and printing a manual with your company's name in it. Be aware.
P
PaulJSmith
Clause 7.4.1 requires that you keep records of the evaluation of your suppliers. What those records are is determined by you. So, unfortunately, the answers is that it indeed is determined by how you write your manual and/or procedure which will govern that process.
K
kgott
I worked for a company (shipyard) whose procedures where written by a consultant. Their confined space procedure went to 13 pages. They covered every conceivable base they could think of. (think consultant CYA) The document did not reflect the shipyards own confined space issues.
Who is ever going to read that apart from me the HSEQ person? This is what happens when they bring in consultancy services based on package pricing and not on re-searching how work is done and reflecting that in documentation.
Firstly, don't sweat the gap analysis. It's not the certification audit. Secondly, if you are going to use your supplier assessment form to meet the requirement of ISO 9001 to perform supplier evaluation/re-evaluation, then yes, it has to be controlled, because it's part of the management system.
There's nothing wrong, per se, about having someone draft a quality manual - it's HOW they do it you have to be in control of.
harry
I think it has to do with the rigid mindset of many people in the quality area. When you talk about control, what level of control do you have in mind?
I practice, the relevant department such as purchasing which is handling the sending and receiving of the forms whether by fax, email or snail mail would have records which is a good enough control for traceability and retrieving purpose.
Do you need to control the format? Many people do it and make it part of the QMS documents but think about it - if the contents in such a form are fixed, would it be useful year after year and in the face of changing market conditions?
MikeLQSR
There are a few areas that can potentially tie into this answer in regards to ISO 9001 / 13485 as well as 21 CFR 211, 820 (training and supplier qualification specifically). If your company has a Supplier Quality Engineer (or the like) they will be asked (by auditors) about the SQE's training and specifically the qualifications of reviewing the self assessment as well as what actions are taken in regards to poor self assessments - this will then tie into purchasing controls (eg approved supplier list's, disqualification of suppliers, etc).
While this does technically tie into the Quality Manual, it does have a much broader scope which on the surface that usually goes un-noticed - it can be tied into the following clauses is ISO 9001 :
1) 5.6 - management review : Does / How does management review the self assessments? If the supplier is qualified / disqualified is management notified?
2) 6.2.2 - Training (also ties in with ISO 19011 if the SQE is an auditor as well)
3)7.1 Planning of product realization - if the self assessment is used initially to qualify a supplier then it becomes a record and should be retained and controlled
4) 7.4 - Purchasing - fits into many of 7.4's subclauses...
5) 7.5.3 - traceability - along with your self assessment you should strive to obtain full product / material traceability and visibility. Within my organization we have a "cradle to grave" policy. We know where the material starts life all the way to whom the customer is.
These are just some of the major tie in's an auditor can say that a self assessment can potentially fit into. Bottom line - all documents relating to supplier quality should be controlled - period.
Hope this helps!
Mike
John Broomfield
thekellyg,
Is the supplier at liberty to delete the awkward questions?
Of course not!
Yes, you control the form to prevent unauthorized changes.
You can define the degree of control for each system document according to the risk.
But most of us opt for standardized controls to:
  • Indicate the document's status (draft or approved)
  • Uniquely identify the document
  • Be sure of making available only the correct version
John
P
PaulJSmith
One thing not particularly clear here, thekellyg, is what self assessment form are you talking about? Is it the form itself that you send to suppliers? Is it the completed form (now a record) returned from your suppliers? Or is it the forms you complete for your customers?
...Should a supplier self assessment form be a controlled document?
There is no direct requirement to use a form, and no direct requirement that it be controlled, if you do. However, look at 4.2.1d. Part of your required documents include those documents necessary to ensure effective the planning, control or operation of your processes. So, I will bounce the question back to you. Is this form important in your process of supplier management? Only you can answer that, but I would tend to think that this document should be a controlled document.
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
Jane's Should the facility landlord be an approved supplier? Supplier Quality Assurance and other Supplier Issues 12
L Supplier Approval Process – Should the Quality Department be Excluded? Misc. Quality Assurance and Business Systems Related Topics 7
B Should I Request/Submit a PPAP from/to a Supplier/Customer for only Repackaging Parts APQP and PPAP 7
V Is there an approach to define the "must 'or' should" in supplier audits? US Food and Drug Administration (FDA) 2
R Supplier Deviations - Should this be counted in the supplier ppm? Supplier Quality Assurance and other Supplier Issues 3
P Should I send survey questionnaire prior to Supplier EMS Audit? Miscellaneous Environmental Standards and EMS Related Discussions 14
L Approving myself as a Supplier - Should we be on our own ASL AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
N Supplier PPAP - How many parts should they submit? APQP and PPAP 6
D What knowledge should supplier and buyers of computers (public service agency) share? Supplier Quality Assurance and other Supplier Issues 1
Sidney Vianna Should customers influence a supplier's registrar selection? Registrars and Notified Bodies 88
G Auditing a Supplier in another country - What should I do - advice needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Customer is also my supplier - Should I perform an audit to his process? IATF 16949 - Automotive Quality Systems Standard 6
F Who should Sign Supplier PPAP (Production Part Approval Process) documents? APQP and PPAP 13
D Should I Standardize our Supplier?s Box Size? Supplier Quality Assurance and other Supplier Issues 6
J Should the term "Supplier" or "Vendor" be used within procedures? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q Conference Call with Supplier - What points/issues should we keep in mind? Supplier Quality Assurance and other Supplier Issues 4
D Supplier Evaluation Procedure - What documentation should we request from suppliers? Document Control Systems, Procedures, Forms and Templates 4
J Who should conduct Supplier Evaluation Audits? Supplier Quality Assurance and other Supplier Issues 12
D Should low volume supplier PPM comparisons consider level of opportunity for error? Quality Tools, Improvement and Analysis 2
M Should supplier make an invoice for PPAP samples or it should be sent "free"? APQP and PPAP 7
L PPAP from Raw Material Supplier - What should we ask for? APQP and PPAP 8
A Should we assign the PRRC before the date of application of MDR (26 May 2021)? EU Medical Device Regulations 0
J UDI-DI how should we interpret Device version or model to determine if a new UDI-DI is needed? EU Medical Device Regulations 0
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance document to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
N Master Samples - What should we be keeping? IATF 16949 - Automotive Quality Systems Standard 9
John Broomfield Vote - Should ISO9004 Become a Requirements Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J Should Loading and Unloading be Included in Cycle Times? Lean in Manufacturing and Service Industries 14
E Manufacturers should develop a testing device for covid19 Service Industry Specific Topics 0
T 510(k) submission - Which name should I use in the submission? Other US Medical Device Regulations 3
N ISO 19011:2018 - 5.4.2 "...audit program should engage in appropriate continual development..." Training - Internal, External, Online and Distance Learning 4
M Should 510(k) Predicates be Actively Listed Devices? Other US Medical Device Regulations 12
H Who should be listed as the manufacturer/distributor on the box? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
M MDR, RED and LVD - Should our device comply with them? EU Medical Device Regulations 3
BeaBea How Many Processes should be created for each Department? Process Maps, Process Mapping and Turtle Diagrams 5
