Should Air Screwdrivers be Calibrated?
lmamao
Hello all, hope you can help me with this. We are an ISO/TS 16949 certified company, in our process we use a lot of pneumatic torque guns, Air Screwdrivers, etc.
Some of this tools we say we calibrate them because they are adjusted to a certain torque range, here's where the question is, Do you think 7.6 applies to this type of tools?
I don't think so because is not a monitoring or a measuring equipment.
Do you agree?
Thanks,
Luis
hogheavenfarm
Re: Air Screwdrivers Calibrated??
We have had to calibrate the gages (air pressure) supplying these devices. This was due to air rivet guns needing a specific range of pressure to operate with the proper torque. For normal air ratchets and wrenches, if torque is not a specified requirement then no, no calibration, or you may also provide a final check later in production using calibrated equipment.
somashekar
If you use a Air screwdriver and you are supposed to be operating at xx torque for the application, your screwdriver is understood to be monitoring and driving the screw at xx torque, to which it is set. Here you need to have some sort of acceptable verification, where you can check periodically or before use.
BoardGuy
As noted earlier if you are using these air drivers to apply a specific torque to a screw then calibration is required under 7.6. If you use then as an assembly aid and then torque then to the requirement with a calibrated torque wrench, then no.
Calibrating air drivers requires a little deferent calibration setup then just using a torque calibrator. The system used must allow running torque (similar to screwing the screw in) to set torque that matches the specified requirement.
lmamao
Well is not an specific torque, it's a range (since we are a remanufacturing company, there are a lot of variables in the process) for example for a process of a pulley assembly we have a range of 65-85 ft/lbs, and we do daily process inspection with a calibrated torque and verify that torque range.
Sidney Vianna
Post Responsibly
...snip... We are an ISO/TS 16949 certified company, snip... Do you think 7.6 applies to this type of tools?
Do you agree?
Yes, I agree with you. These tools are NOT covered under 7.6. The torque-meter used to verify the torque, on the other hand, is.
snip (since we are a remanufacturing company, there are a lot of variables in the process)
I thought the eligibility requirements for ISO/TS-16949 certification did not allow remanufacturing plants to be certified, but I may be wrong.
BoardGuy
[FONT=&quot]So your nominal is 65 +/- 10 ft/lb more or less. Rule of thumb would be to calibrate them at appropriate points between 60 to 90 ft/lb. [/FONT]
[FONT=&quot]Even if process is overhaul fasteners require specific torques to prevent failure.[/FONT]
gpainter
Most definitely. I would look at your air system for issues, as they are about 5% efficient at best. Leaks, leaks, leaks. Consider using rechargeable tools as compared to air. Total cost will be less
Q
qpappa31
I am running into the same issue at my plant now. We are an ISO/TS 16949 manufacturing company. During our last TS Audit, the auditor asked about our pneumatic torque tool calibration. We have about 60 air tools in house and we send them out for repair when needed but never actually perform a calibration on them. We do verify the torque at the start of the shift using a Norbar Torque Meter & Transducer. All of our process have a torque range (ex: 6-9 Nm). We verify the torque tool by running it down on our transducer at the start of every shift as I said and if its out we adjust the tool or replace it.
Our auditor told us that this is not sufficient and that the tools need to be actually calibrated. I've had this position for 10 years and this is first time any auditor told me this so now I am stuck trying to figure out what to do. I thought the audit at each shift would be sufficient but apparently not.
I am not sure what calibrating the torque tools will actually accomplish. If the tool has a range of 5-12 Nm but my target range in my process is 6-9 Nm what added benefit am I getting out of the torque tool being calibrated when I am verifying the gun at the start of each shift. I guess what I'm asking is what are they actually doing during a calibration of the torque tool.
gpainter
That is strange. I would think as long as you are verifying the torque with a traceable instrument that it would be good. Has someone else ran into this? Talk to your auditor.
kedarg6500 Should soft annealing of Copper be done using regular air or in an inert atmosphere ? Manufacturing and Related Processes 2
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance standard to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
N Master Samples - What should we be keeping? IATF 16949 - Automotive Quality Systems Standard 9
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
John Broomfield Vote - Should ISO9004 Become a Requirements Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J Should Loading and Unloading be Included in Cycle Times? Lean in Manufacturing and Service Industries 14
E Manufacturers should develop a testing device for covid19 Service Industry Specific Topics 0
T 510(k) submission - Which name should I use in the submission? Other US Medical Device Regulations 3
N ISO 19011:2018 - 5.4.2 "...audit program should engage in appropriate continual development..." Training - Internal, External, Online and Distance Learning 4
M Should 510(k) Predicates be Actively Listed Devices? Other US Medical Device Regulations 12
H Who should be listed as the manufacturer/distributor on the box? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
M MDR, RED and LVD - Should our device comply with them? EU Medical Device Regulations 3
BeaBea How Many Processes should be created for each Department? Process Maps, Process Mapping and Turtle Diagrams 5
M Should volume of sales be factored into risk probability assessments? ISO 14971 - Medical Device Risk Management 33
S Should safety checks be included in the Control Plan? IATF 16949 - Automotive Quality Systems Standard 5
M Which incubation condition should be selected to recover both bacteria and fungus effectively Miscellaneous Environmental Standards and EMS Related Discussions 3
D Is there a specific location for PPE such as safety glass holders and glove dispensers should be mounted Occupational Health & Safety Management Standards 10
M Who should receive the bills from suppliers and vendors, account payable or procurement? Consultants and Consulting 4
A We are ISO 13485:2016 should we be audited to ISO 14971 ISO 13485:2016 - Medical Device Quality Management Systems 16
E Received a Major finding during IATF Surveillance audit for loss of BIQS Level 3 (more than 6 SPPS in 6 months)...how should we address SYSTEMIC CA? IATF 16949 - Automotive Quality Systems Standard 11
J Organization merger. Should we keep two separate ISO 13485 certificates? ISO 13485:2016 - Medical Device Quality Management Systems 6
S Companies that maintain your machine should be in ASL? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Use of "Shall" versus "Should" in Procedures ISO 13485:2016 - Medical Device Quality Management Systems 26
D Class II medical device - When should a complaint be closed? Customer Complaints 6
Sidney Vianna IATF 16949 News Presentations from the latest IATF Stakeholder Event - Expectation that IATF 16949 certification should equate with product quality. Misguided? IATF 16949 - Automotive Quality Systems Standard 7
Ed Panek Part 11 Self Certify Memo - What else should it cover? Qualification and Validation (including 21 CFR Part 11) 5
H Should I mention machine/Equipment password In SOP? Qualification and Validation (including 21 CFR Part 11) 4
D How long should we keep the spare parts available for our medical device, after we have stopped the production? ISO 13485:2016 - Medical Device Quality Management Systems 0
H Statistical Techniques Procedure - What should be included Document Control Systems, Procedures, Forms and Templates 4
Sidney Vianna Interesting Discussion ISO 9001:2024 - What should be changed in the next Edition of ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 113
N Should it even be on the hazard analysis (software)? FMEA and Control Plans 2
