Should An ISO 9001 Consultant be Expert in an Industry?
Marc
#11
Originally posted by Neelanshu Varma
If we keep the audit objective as "compliance" then it really doesn't matter whether the auditor is knowledgeable about the industry or not. However if we look at audit an an oppurtunity to identify improvements in the system then an industry expert adds lot more value compared to an outsider.
Cheers
Neelanshu :)
I agree for the most part. The problem is the 'opportunity for improvement' issue. If we're talking process issues an industry expert is a great help. But - where do you cross the line between consulting / auditing and what part does this play in reality? Some registrars play up the 'opportunities for improvement' issue but I personally believe it's more hype than anything. Heck - there are a lot of 'outsiders' who can walk through a plant and offer up 'opportunities for improvement' as they see them (and different auditors will typically see different 'opportunities for improvement').
As an example, I once had a client and an auditor wrote up an 'opportunity for improvement' which involved his belief that a person doing some soldering of through-hole components on a board should have a 'calibrated' iron. We could show through, for example, the nonconformance system that solder joints were a very, very unusual failure mode and almost all were from wave-solder processes - not through-hole soldering. We practically had to beat the guy with a stick to get him to stop telling the client how to run their operations, where work instructions are needed, what should be calibrated and such.
I want a registrar's auditor to come in and verify compliance to the standard - not to tell me (my client, actually) how to do everything 'right'. If I want process and/or systems consulting, I'll hire a consultant specifically for that purpose. :thedeal:
Jim Biz
#12
Food for thought
Whoa !! hold the phone - :confused:
I'm somewhat late in posting this but go back to the title of the thread itself.... Can someone define "EXPERT" ......
lets say.. I've worked in/around/ and with piecwork processes welding & tractor/combine parts machining for 34 plus years - am I an "expert"? (If so maybe I should change my business card :D )
On the other side of the issue.... We have an employee here that believes he is "an expert" in the use of a particular scheduling Theroy application "tool" because he attended a 2 week seminar)
I really believe "comon sense and Practice - in auditing" are much more important than the consideration of being an Expert (however it is defined.) Knowledge of business & industry practices are "helpful" and should fall into the "transferable skills" area.
Paul Simpson
#13
Drips under Pressure
Have you heard the definition of Expert?
The word is made up of two parts: "Ex" as in "Has been" and "Spurt" which everyone knows is a drip under pressure. I would not like to be described as a combination of these two!
But seriously .... I too am a consultant, I too was an auditor and I too have been the first auditor in to a particular field. I agree with Marc, it depends on the individual. I know of some auditors with many years experience and you take them out of their direct area of expertise and the quality of the audit goes out the window. I know of other auditors who I would trust in any situation and who would get to the important aspects of the client's business and tell them a thing or two about how well they manage quality. As might be expected 99% of us fall between these two extremes.
For consultants the key is not to go in with ears closed and mouth open but to do the reverse. It doesn't take long to understand what is important to the client and to then "map" the processes to the requirements of ISO 9001, 14001 etc.
The consultant has expertise in system standards, business environment, people skills and uses these to deliver the services that meet the customer requirements.
G
Greg Mack
#14
I Don't believe that the consultant should be the Expert. That is what the Management is for. After all, they know their business better than most and it is those people who need to make the system work for them and assist the consultant in documenting it.
I have to laugh when I see job ads asking for someone who has specific skills in one area to get a job in documenting a system. That's baloney!!! Helpful but certainly not essential.
Give me a business, any business, and I am sure I could set up a respectful system that they could easily use and benefit from.
:p
Marc
#15
To me, the 'trick' is to be able to see what they have, to understand whether what they have is working and integrate/tailor if/where necessary. Then develop and integrate what they have to have but do not have.
That's why I'm not big on canned procedures and software. As I always say - One size does NOT fit all!
#17
Way to go Carl
I must agree totally.
The ONLY job of an auditor is to verify that the system meets the standards BASIC REQUIREMENTS!!
I am concerned about threads I see here explaining how an auditor wrote a finding, not because an element wasn't there, but because he thought it could be done better. That is none of his business. He is there to audit, not consult.
Is this how the RAB courses are taught? That an auditor can pass judgement on HOW you comply? I thought the job was to determine whether they DO or DO NOT comply period.
My credentials are a lowly little ASQ CQA and I was taught that is essential that you keep your opinions to yourself. One of the main reasons for this is that you often have access to propietary info and if you disclose, even inadvertently, this information to a competitor then you could find yourself liable.
Whew. I don't know what got into me there, but it sure seems that some auditors need to be reined in.
One again thanks for the vent space.:truce:
James
Paul Simpson
#18
Losing the Thread
This thread seems to be getting unravelled!
I thought the line was whether consultants needed to be experts, the last few posts are about keeping the auidtor in a box! That's fine if that's what you want to do so, personally I have had a lot of good input from auditors, tapping into their experience. Also as an auditor I have given clients the benefit of my experience (both as an auditor and in previous work, I won't bore you with the CV) but only when they have asked or I think they might take the comments in the spirit in which they were intended.
One of the reasons I moved out of auditing was to get the freedom to advise a company as a company employee or now as a consultant on how their systems might work for them.
Keep up the good work.
G
Greg B
#20
Hi All,
I think that a consultant and for that matter a registrar (auditor) should be matched to the industry. I'd like to know that they understand the industry, in some way. The purely business functions of the management system should be known by all but I am talking about the processes. Is a person that specialises in abattoirs going to understand the open cut mining industry? No.
We have specialised audits each year from the Australian Pesticides and Veterinary Medicines Authority, because we manufacture some products that are used in the agricultural industry, and all of the auditors are Chemists yet they have to review all of our processes along the same lines as the ISO auditors. Our ISO registrar matches our auditor to our industry and we rarely have trouble but the 'Chemists' cause us all kinds of headaches because they do not understand the industry (IMO) plus they HAVE to be rotated after two audits so we can't train them over time to understand...Very frustrating.
Our internal auditors must have Trade qualifications (mechanical or electrical) and industry experience (at least five years). It is in their job description...so why should we not also require our consultant to have experience. I am not saying they should be an EXPERT only in one field rather they should have experience in many fields. This seems to be a bit of a catch 22. You can't be employed unless you have experience but you can't get experience unless you are employed.
Greg B
Sidney Vianna Interesting Discussion ISO 9001:2024 - What should be changed in the next Edition of ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 113
H Clause 8.5.5 and Clause 8.6: which one should be coming first? (ISO 9001:2015) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D What should be included in Management Review Meeting for ISO 9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
O Should ISO 9001:2008 be treated as a standalone quality standard alongside AS9120A? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
L Should I wait to get certified to ISO 9001:2015 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
C Should we register to ISO 9001:2008 or ISO 9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
T Should the Internal audit for ISO 9001 cover all elements of the standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A ISO 9001 Recertification Process - How should I prepare for it? Document Control Systems, Procedures, Forms and Templates 6
G ISO 9001 Clause 5.1 d - Management Review - Who should participate? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
Z Should we recertify our internal auditors as we transitioned to ISO 9001:2008? Internal Auditing 1
2 ISO 9001 should be implemented before CMMI for maximum effectiveness? Quality Manager and Management Related Issues 2
D Which processes should be monitored to meet ISO 9001 Clause 8.2.3? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Sidney Vianna Can (and should) you do ISO 9001 in a single department/area? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 35
Sidney Vianna What should be changed in the ISO 9001:2015 Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 433
F Should I remove references to AS9120 / ISO 9001 from my Quality Manual and QMS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
J Should product brochures be controlled per ISO 9001:2000? Document Control Systems, Procedures, Forms and Templates 2
C Which provider in India should I take the ISO 9001 Lead Auditor Course From? Training - Internal, External, Online and Distance Learning 5
Z ISO 9001 Clauses which should be known by every one in the organization? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
J How should customer complaints be handled to comply with ISO 9001? Customer Complaints 4
S FDA Part 820 Audit vs. ISO 9001 - Anything I should be aware of as an auditor? Various Other Specifications, Standards, and related Requirements 13
T Should copies of the ISO 9001 registration certificate be controlled ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Crusader When Should I Implement ISO 9001 in a Brand New Facility? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 53
Sidney Vianna Should the billing process be part of ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 99
M ISO 9001:2000 - What should be in my QM and what procedures should I have? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P Implementing ISO 9001 - What are the first things that should be done? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
I Who should be present during certification audits (ISO 9001/14001)? Registrars and Notified Bodies 6
Raffy QS-9000 vs. ISO 9001:2000 - Which Should We Persue? QS-9000 - American Automotive Manufacturers Standard 9
I Should our company be ISO 9001 certified or QS-9000 certified? QS-9000 - American Automotive Manufacturers Standard 6
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance standard to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
N ISO 19011:2018 - 5.4.2 "...audit program should engage in appropriate continual development..." Training - Internal, External, Online and Distance Learning 4
A We are ISO 13485:2016 should we be audited to ISO 14971 ISO 13485:2016 - Medical Device Quality Management Systems 16
J Organization merger. Should we keep two separate ISO 13485 certificates? ISO 13485:2016 - Medical Device Quality Management Systems 6
G ISO 17025:2017 7.1.2 - Should I produce a document for the customer? ISO 17025 related Discussions 8
P ISO 80369-7 standard - Interpreting which Parts should be in scope Other Medical Device Related Standards 7
S Should the primary drug containers be molded in ISO Class 7 clean room? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 6
I Should I get IRCA ISO 13485 certification or RAPS certification? Career and Occupation Discussions 3
D What should an ISO 14644 Clean Room PQ (Performance Qualification) look like? Manufacturing and Related Processes 3
D When Quoting an ISO Standard should I put the quote in italics? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M ISO 14001 - Should we list the standard itself in clause 4.3.2 ISO 14001:2015 Specific Discussions 8
E Should companies that perform calibration services be ISO 17025 accredited? ISO 17025 related Discussions 13
Manix Should a 3rd Party Auditor Audit against IATF rules and not just the ISO standard? General Auditing Discussions 4
A Should Intentional Misuse be covered in the Risk Analysis under ISO 62366? IEC 62366 - Medical Device Usability Engineering 3
G Are there any ISO registrars that should not be selected and why? Registrars and Notified Bodies 9
J ISO 14155:2011 - The meaning of the term "Should" EU Medical Device Regulations 8
B ISO 13485 Management Review - What should be presented by Supply Chain Management Quality Manager and Management Related Issues 1
D Standards (ISO and others) - Which language should I use? EU Medical Device Regulations 5
K When should validation be carried out in the context of ISO 22000? Food Safety - ISO 22000, HACCP (21 CFR 120) 2
