Should CMM (Coordinate Measuring Machine) programs be controlled?
KIDDO
:bigwave: Covers
I'm in the middle of a rather "heated" debate :mad: as to whether or not CMM programs should be controlled.
I think they should be due to the fact that if users are not aware when changes are made, bad things could happen. I've suggested implementing user names and passwords to the software so not "everyone" has access to them but the "administrator" still isn't buying in. Can anyone else give me suggestions to solidify my point :agree:
thanks again,
KIDDO:biglaugh:
alspread
Re: Should cmm programs be controlled?
The following is just a portion of a paragraph from UTC's (Pratt & Whitney, Sikorsky, Hamilton Standard, etc) 8 page procedure for control of non-deliverable software covering just the verification and validation of CMM programs.
"Verification and Validation:
 Define the Verification and Validation process.
 Test procedure or test description and results shall be documented,
reviewed and retained.
 Provide objective evidence that the software performs its required
function.
 Trace software to requirements.
 Inspection review and approval of software must be performed by
someone acting in an acknowledged product integrity role. Software used
to verify quantitative values (e.g., CMM, etc.) requires an independent
method of validation (i.e., layout inspection, fixture check or comparison
with another CMM program previously verified by an independent
method) and correlation of the two sets of results.
 Acceptable correlation requires the difference to be within 10% of the
tolerance for each characteristic. Differences greater than 10% but
not exceeding 25% may be acceptable with documented justification.
 Differences greater than 25% are not acceptable.
 Variable data shall be recorded and retained."
Customers of aerospace machined components put heavy controls on non-deliverable software (i.e. CMM programs, NC programs, test stand programs, etc.)
AS9100 also requires:
"7.5.1.3 Control of Production Equipment, Tools and Software Programs
Production equipment, tools and software programs used to automate and control/monitor product realization processes, shall be validated prior to release for production and shall be maintained."
Good luck
H
Hodgepodge
:bigwave: Covers
thanks again,
KIDDO:biglaugh:
ISO 9001:2008
7.6 Control of monitoring and measuring equipment
The organization shall determine the monitoring and measurement to be undertaken and the monitoring and measuring equipment needed to provide evidence of conformity of product to determined requirements. The organization shall establish processes to ensure that monitoring and measurement can be carried out and are carried out in a manner that is consistent with the monitoring and measurement requirements. Where necessary to ensure valid results, measuring equipment shall
a) be calibrated or verified, or both, at specified intervals, or prior to use, against measurement standards traceable to international or national measurement standards; where no such standards exist, the basis used for calibration or verification shall be recorded (see 4.2.4);
b) be adjusted or re-adjusted as necessary;
c) have identification in order to determine its calibration status;
d) be safeguarded from adjustments that would invalidate the measurement result;
…When used in the monitoring and measurement of specified requirements, the ability of computer software to satisfy the intended application shall be confirmed. This shall be undertaken prior to initial use and reconfirmed as necessary.
If you intend to comply with the bolded portions of ISO 9001 there must be some sort of control. From your description of the scenario, it sounds like your administrator feels like he has it under control. Ask how the programs are controlled. If the method of control seems adequate, document it. If the method doesn’t seem adequate, then determine the process results. Are discrepant products being shipped? How do you know? If there has never been a problem then it sounds like the process is sound. Just define the controls in such a way that they can be maintained if and when new employees come along.
When the people responsible are involved in the creation of process controls, they are more likely to buy in. Good luck.
Brunetta
:bigwave: Covers
Ummm...This inquiring mind wants to know....what are CMM programs? :eek:
Thanks,
Brunetta
bobdoering
Stop X-bar/R Madness!!
Some CMMs can be computer controlled - they automatically go through the inspection process, touching or viewing (if vision CMM) the points, sometimes changing probes, etc. and generating a report.
If you run the same program, the idea is you get repeatable results. But, sometimes people change them, either temporarily, to check a similar part (then forget to change it back) or "improve" it (without documenting the change - then suddenly people are getting different data). Or worse, they use it and accidentally delete it, and there is no backup. The debate is likely only heated for people that never had those things happen to them. For those that have, it's a no-brainer.
Does that help?
KIDDO
Thank you all for your responses. I have reference the ISO/TS standard requirements and some advice from here. Referencing the standard (the "Bible") I think has proven my point ;)
Brunetta
Does that help?
Yes and No but that was mostly my fault for not asking specifically what the CMM acronym meant.
Just to be sure (and after doing some google searches on CMM and using the context of the discussion) please confirm we are talking about CMM as a Capability Maturity Model?
I work in an environment where the same acronym can stand for completely different things. For example: FOB can mean freight on board or it could mean forward operating base. Probably not the best example but you get the idea.
:topic:
(recovering from two different bouts of stomach flu over two weeks here so all my synapses may not be firing correctly just yet)
~Brunetta
Stijloor
:topic:
~Brunetta
CMM is a Coordinate Measuring Machine.
An advanced piece of inspection equipment controlled by a computer.
Stijloor.
P How often should CMM attribute gages be 3rd party calibrated General Measurement Device and Calibration Topics 1
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance standard to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
N Master Samples - What should we be keeping? IATF 16949 - Automotive Quality Systems Standard 9
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
John Broomfield Vote - Should ISO9004 Become a Requirements Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J Should Loading and Unloading be Included in Cycle Times? Lean in Manufacturing and Service Industries 14
E Manufacturers should develop a testing device for covid19 Service Industry Specific Topics 0
T 510(k) submission - Which name should I use in the submission? Other US Medical Device Regulations 3
N ISO 19011:2018 - 5.4.2 "...audit program should engage in appropriate continual development..." Training - Internal, External, Online and Distance Learning 4
M Should 510(k) Predicates be Actively Listed Devices? Other US Medical Device Regulations 12
H Who should be listed as the manufacturer/distributor on the box? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
M MDR, RED and LVD - Should our device comply with them? EU Medical Device Regulations 3
BeaBea How Many Processes should be created for each Department? Process Maps, Process Mapping and Turtle Diagrams 5
M Should volume of sales be factored into risk probability assessments? ISO 14971 - Medical Device Risk Management 33
S Should safety checks be included in the Control Plan? IATF 16949 - Automotive Quality Systems Standard 5
M Which incubation condition should be selected to recover both bacteria and fungus effectively Miscellaneous Environmental Standards and EMS Related Discussions 3
D Is there a specific location for PPE such as safety glass holders and glove dispensers should be mounted Occupational Health & Safety Management Standards 10
M Who should receive the bills from suppliers and vendors, account payable or procurement? Consultants and Consulting 4
A We are ISO 13485:2016 should we be audited to ISO 14971 ISO 13485:2016 - Medical Device Quality Management Systems 16
E Received a Major finding during IATF Surveillance audit for loss of BIQS Level 3 (more than 6 SPPS in 6 months)...how should we address SYSTEMIC CA? IATF 16949 - Automotive Quality Systems Standard 11
J Organization merger. Should we keep two separate ISO 13485 certificates? ISO 13485:2016 - Medical Device Quality Management Systems 6
S Companies that maintain your machine should be in ASL? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Use of "Shall" versus "Should" in Procedures ISO 13485:2016 - Medical Device Quality Management Systems 26
D Class II medical device - When should a complaint be closed? Customer Complaints 6
Sidney Vianna IATF 16949 News Presentations from the latest IATF Stakeholder Event - Expectation that IATF 16949 certification should equate with product quality. Misguided? IATF 16949 - Automotive Quality Systems Standard 7
Ed Panek Part 11 Self Certify Memo - What else should it cover? Qualification and Validation (including 21 CFR Part 11) 5
H Should I mention machine/Equipment password In SOP? Qualification and Validation (including 21 CFR Part 11) 4
D How long should we keep the spare parts available for our medical device, after we have stopped the production? ISO 13485:2016 - Medical Device Quality Management Systems 0
H Statistical Techniques Procedure - What should be included Document Control Systems, Procedures, Forms and Templates 4
Sidney Vianna Interesting Discussion ISO 9001:2024 - What should be changed in the next Edition of ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 113
N Should it even be on the hazard analysis (software)? FMEA and Control Plans 2
