Should Corrective Action be segregated from Preventive Action?
sagai
Do we have to have a segregated record for corrective action and preventive action?
Is there any problem recording CAPA in general without saying This is CA, That is PA?
(I know the difference, I am wondering if we should distinguish them when recording.)
I tend to believe there is no such requirement in the standard, but curious about others opinion, Many thanks.
G
Geoff Withnell
I can't think of any requirement to do so. Some flag on the PAs, to make it easier to pull them out as examples during audits, may be worthwhile, but required, no.
RA Guy
13485 has separate clauses for CA and PA, so I tend to think there is a requirement to identify actions as CA or PA. Otherwise how do you demonstrate complying with both clauses in an audit situation? At a minimum, the CAPA determination step would need to identify if a CA or PA.
sagai
What if the PAs are those CAPAs having no registered NonConformities against to, while CAs are the ones having registered NonConformities to?
Many thanks.
G
Geoff Withnell
The OP said he knew the difference. The question is "Do we have to have a segregated record for corrective action and preventive action?" No, the records do not need to be segregated. In an audit situation, if the auditor says "show me some corrective actions", show him some. The MR should be familar with the actions being taken, and can likewise ID PAs. If you want to flag them for your convenience, it is perfectly fine to do so, and I would even recommend it. But being the easiest, most convenient way to do it, in my opinion, your opinion, the OP's opinion or ewven the auditor's opinion does NOT make it "required".
Sidney Vianna
Post Responsibly
When ISO 9001:2000 came about, 11[sup]1[/sup]/[sub]2[/sub] years ago, a well known CB set a policy that registrants certified by them were mandated to have SEPARATE procedures for corrective and preventive actions. They got a lot of backlash and have rescinded the policy. Actually one of the clarifications in the ISO 9001:2008 standard had to do with that aspect.
As for your question concerning segregating corrective action records from preventive action records, you should be able to distinguish which is which, even though there is a lot of non-sense, when it comes to preventive actions. We have some of the longest threads on that subject, here at The Cove. Also, don't forget the wisdom contained in the ISO TC 176 APG paper titled Auditing Preventive Action.
RA Guy
Hi Geoff:
Perhaps we are not reading "segregated" in the same way. I understand it as indicating (or distinguishing as SV states above) that a CA is a CA and a PA is a PA. As far as I am concerned one can use the same process, templates, logs, etc. for both CAs and PAs.
If there is no flag or other mechanism to "segregate" the CAs from the PAs, how is the "if its not documented, its not done" rule of thumb satisfied? It can't be by the memory or instiutional knowledge of the MR or anyone else. What if they leave the company?
In an audit, anything that comes out verbally, must be backed up by the record or other objective evidence. If the auditee is the only source verbally telling the auditor what's what, I'd suggest that the auditor is injecting his/her opinion by accepting that with no documented evidence.
sagai
I know not I was the one was called, but sorry Sir, "objective evidence" is not necessary a document, a record or anything tangible. As far as I concern in the ISO world. Cheers!
3.8.1
objective evidence
data supporting the existence or verity
of something
NOTE Objective evidence may be ob-
tained through observation
, measure-
ment, test (3.8.3), or other means.
RA Guy
Sagai, I agree and that's why I said "by the record or other objective evidence."
I am not sure in your CAPA example what other type of evidence could be presented besides a document or record.
My original post stated 13485 has 2 separate requirements. Both requirements need to be demonstrated by objective evidence. The record is the best way in MHO.
I am open to other suggesteions on how this could be done without documentary evidence "segregating" the 2 types of action.
R When should a Corrective action be created? (Procedures not being followed) Nonconformance and Corrective Action 23
A Whom should I send the FSCA (Field Safety Corrective Action) to? EU Medical Device Regulations 2
C Should Preventative Action follow a Corrective Action Nonconformance and Corrective Action 27
J What should generate a CAPA (corrective action - preventive action) US Food and Drug Administration (FDA) 16
Q How many records should I keep when implementing Corrective Actions Records and Data - Quality, Legal and Other Evidence 3
Q CAPA - What criteria should be used to initiate Corrective and Preventive Actions ISO 13485:2016 - Medical Device Quality Management Systems 8
T Who should take the lead for 8D Corrective Actions Preventive Action and Continuous Improvement 13
S Who should do the CA's (Corrective Actions) from Internal Audits Internal Auditing 9
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance standard to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
N Master Samples - What should we be keeping? IATF 16949 - Automotive Quality Systems Standard 9
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
John Broomfield Vote - Should ISO9004 Become a Requirements Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J Should Loading and Unloading be Included in Cycle Times? Lean in Manufacturing and Service Industries 14
E Manufacturers should develop a testing device for covid19 Service Industry Specific Topics 0
T 510(k) submission - Which name should I use in the submission? Other US Medical Device Regulations 3
N ISO 19011:2018 - 5.4.2 "...audit program should engage in appropriate continual development..." Training - Internal, External, Online and Distance Learning 4
M Should 510(k) Predicates be Actively Listed Devices? Other US Medical Device Regulations 12
H Who should be listed as the manufacturer/distributor on the box? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
M MDR, RED and LVD - Should our device comply with them? EU Medical Device Regulations 3
BeaBea How Many Processes should be created for each Department? Process Maps, Process Mapping and Turtle Diagrams 5
M Should volume of sales be factored into risk probability assessments? ISO 14971 - Medical Device Risk Management 33
S Should safety checks be included in the Control Plan? IATF 16949 - Automotive Quality Systems Standard 5
M Which incubation condition should be selected to recover both bacteria and fungus effectively Miscellaneous Environmental Standards and EMS Related Discussions 3
D Is there a specific location for PPE such as safety glass holders and glove dispensers should be mounted Occupational Health & Safety Management Standards 10
M Who should receive the bills from suppliers and vendors, account payable or procurement? Consultants and Consulting 4
A We are ISO 13485:2016 should we be audited to ISO 14971 ISO 13485:2016 - Medical Device Quality Management Systems 16
E Received a Major finding during IATF Surveillance audit for loss of BIQS Level 3 (more than 6 SPPS in 6 months)...how should we address SYSTEMIC CA? IATF 16949 - Automotive Quality Systems Standard 11
J Organization merger. Should we keep two separate ISO 13485 certificates? ISO 13485:2016 - Medical Device Quality Management Systems 6
S Companies that maintain your machine should be in ASL? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Use of "Shall" versus "Should" in Procedures ISO 13485:2016 - Medical Device Quality Management Systems 26
D Class II medical device - When should a complaint be closed? Customer Complaints 6
Sidney Vianna IATF 16949 News Presentations from the latest IATF Stakeholder Event - Expectation that IATF 16949 certification should equate with product quality. Misguided? IATF 16949 - Automotive Quality Systems Standard 7
