Should I perform several Gage R&R for every caliper to cover all specs range of use?
Hello All, hope you can help me with this one,
I'm starting to plan a new gage R&R program for the calipers we use at the company I work for, the company is IATF16949 certified.
The calipers we use are 150mm length.
The different processes and products we have are with a wide variety of specs, starting from 1.5mm length, 2.5mm, 4.5mm, 11.5mm, 20mm, 25mm, 31mm, and goin up to 45mm length.
The question I have is if I should perform a gage R&R for every one of the specs, or if I should choose one of them (lets say 4.5mm) that represent all of the specs for the length characteristic?
thanks
Ronen E
Problem Solver
Moderator
thanks
According to my understanding, a GR&R (or MSA) study should be specific, for a single product/component and measurement combination.
I realise that this might sometimes not be economically viable / practical. You might be able to make a "representative" assumption (that one study's results are representative of a range), but this at least needs to be clearly stated and reasoned in your documentation.
I'm not an MSA expert, though - let's hope that some (@Bev D, @Steve Prevette?) will chip in soon.
Cheers,
Ronen
Enghabashy
thanks
I see you should start from the control plan, as IATF 16949 requirement 7.1.5, the 1st reference is the control plan:
1- all measuring devices stated in control plan shall be complied with MSA ;
2-CSR relevant to DIM. Specs. , special product or process characteristics , FMEA should be referenced in control plan ;
3-the Prioritization of MSA studies should focus on critical or special product or process characteristics
According to my understanding, GR&R (or MSA) study should be specific, for a single product/component and measurement combination.
Cheers,
Ronen
Hello Ronen E
This is my understanding to make a GR&R for single product/specs measurement combination, but it would consume a lot of resources for time and personnel.
It is a good recommendation to state in my documentation to make representative studies, I will try to cover the smaller and the bigger specs to be representative of all the wide range of specs
Steve Prevette
Deming Disciple
Well, I'll take a shot at it. At the pier in Reykjavik Iceland on the second week of a Norway / Iceland cruise. Three sea days back to Southampton and then a long flight home.
I'd suggest doing a linearity check similar to what you would do for a thermometer or a voltmeter - that is a pretty common plan. Then you can check a few commonly used points, and also do a linearity check to see if the calipers are behaving correctly at in between readings.
Internet capability is really poor this far north (at least what Princess uses) or I'd try to look up an existing plan.
Ron Rompen
I'm getting in late on this, but thought I would share my experiences with similar situations.
I have (in the past) treated this as a multi part problem. The first is the accuracy/repeatability of the gauge. To evaluate this, I performed a GRR study on the feature using the TIGHTEST tolerance - that will give you an initial idea of the acceptability of the gauge. If you hae a GRR <10% with a tolerance of ± 0.005", then you are (in general) safe to assume that a similar feature with a tolerance of ± 0.010" can also be accurately measured with the same gauge.
The next (as was already pointed out) is the linearity of the gauge in question. It may be accurate and repeatable at the 1-2" range, but is it as accurate and repeatable at the 6-7" range.
Because I (personally) don't think that it is, I would repeat the study on the largest feature in question.
Lastly, the geometry of the feature being measured is important - observe/attempt the measurements yourself, and see what is the most 'difficult' to accomplish - use that as your 3rd study.
If all 3 of the above give a GRR <10% then you are reasonably safe to assume that the 'intermediate' sizes will be properly evaluated.
Don't forget to check your CSR's, and that you can always talk to your customer - explain your position, what you are considering, and get their input.
B AS9102 FAI & Lower Level Drawings - How should we perform the FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Should companies that perform calibration services be ISO 17025 accredited? ISO 17025 related Discussions 13
V Product Audits - Who should perform Product Audits? IATF 16949 - Automotive Quality Systems Standard 17
B Should we perform Equipment final calibration-Operations closing ISO 13485:2016 - Medical Device Quality Management Systems 8
M Customer is also my supplier - Should I perform an audit to his process? IATF 16949 - Automotive Quality Systems Standard 6
E Please help! ! I AM FRASTRATED SO MUCH! Should inactive ingredient be included in the unit formula if it is removed during the manufacturing process? US Food and Drug Administration (FDA) 0
I IEC 60812 or ISO 14971 for PFMEA? What should we use? ISO 14971 - Medical Device Risk Management 3
qualprod Do sum of results of quality objectives should met a high level goal? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E Opening meeting for Third-Party Audit--Who should say what? General Auditing Discussions 22
8 MSA--Should I Use Parts or Gage Pins? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Should I buy IEC 62304:2006, IEC 62304:2006/AMD 1:2015 or both? EU Medical Device Regulations 1
W "Accurate to ±2%" means "64% of measurements should be within 2% of the actual value"? US Medical Device Regulations 4
H Should we stop inspecting a part if its never been rejected? Reliability Analysis - Predictions, Testing and Standards 6
D What distributor requirement should we (manufacturer) require from the Distributor? EU Medical Device Regulations 0
M Should there be another column in the Optimization section (step 6) of AIAG-VDA DFMEA form? FMEA and Control Plans 1
C By when should harmonized standards be complied with? EU Medical Device Regulations 5
W Strategy for determining which components from a system should be "ME EQUIPMENT" -- home healthcare environment IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
B Documented information - Should be controlled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Is engineering a process and should it have its own process turtle? IATF 16949 - Automotive Quality Systems Standard 7
P Which MDCG Document should I use for PMS Plan and PSUR? EU Medical Device Regulations 2
M Who should quality representative report to? ISO 13485:2016 - Medical Device Quality Management Systems 5
H When should the first PSUR be issued? EU Medical Device Regulations 5
I If i do not want to be an initial importer should i register with FDA? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
O Should a Covid vaccine and testing policy be included as part of ISO9001 or AS9100 risk management? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B UKRP to what level should you audit Class I Technical Documentation? UK Medical Device Regulations 0
C When should you quit programming? Job Openings, Consulting and Employment Opportunities 9
C Should resolution be included in uncertainty budget for digital caliper or micrometer calibration? Measurement Uncertainty (MU) 5
Ed Panek External Standards List - Should this document include previously revised standards? ISO 13485:2016 - Medical Device Quality Management Systems 4
T How should I approach REACH, CM, etc. as a job shop? RoHS, REACH, ELV, IMDS and Restricted Substances 18
A Should we assign the PRRC before the date of application of MDR (26 May 2021)? EU Medical Device Regulations 0
J UDI-DI how should we interpret Device version or model to determine if a new UDI-DI is needed? EU Medical Device Regulations 0
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance document to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
S Which Sampling Plan(s) Should I Use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
N Master Samples - What should we be keeping? IATF 16949 - Automotive Quality Systems Standard 9
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 7
John Broomfield Should ISO 9004 Become a Requirements Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 70
J Should Loading and Unloading be Included in Cycle Times? Lean in Manufacturing and Service Industries 14
E Manufacturers should develop a testing device for covid19 Service Industry Specific Topics 0
T 510(k) submission - Which name should I use in the submission? Other US Medical Device Regulations 3
N ISO 19011:2018 - 5.4.2 "...audit program should engage in appropriate continual development..." Training - Internal, External, Online and Distance Learning 4
