Should I remove references to AS9120 / ISO 9001 from my Quality Manual and QMS?
F
fletch
My company is currently ISO9001:2000 registered and I am now changing the QMS to AS9120. In my current QMS I reference ISO9001:2000 in several procedures as well in the Quality Manual.
So my question is in my QMS documentation do I reference both ISO9001:2000 and AS9120 together in procedures? or do I drop the ISO reference?
If I reference both should I print it as such? ISO9001:2000 / AS9120
some of the easiest things are not so easy? maybe I need more coffee to get my brain started?
Coury Ferguson
Moderator here to help
Re: question on AS9120/ISO9001 reference
Just my opinion here: That would be the Organization's choice. If you are Registered to ISO9001:2000 and are going to add AS9120 to your scope, there is no reason to remove the ISO9001:2000 reference. Your scope will change, and you will have some more procedures that you will need to add to meet the AS9120.
But, to remove the reference, no I don't think so. You may want to add the AS9120 references.
BTW: I added to your thread title.
Get more coffee - espresso! You're making it too complicated - to tie your procedures to ISO 9001 or AS 9100 is a level of complication you don't need. Sure, go ahead with some 'look up table' for your manual (if you have one which mirrors the standards anyway, why bother with a reference?)
F
fletch
Re: Should I remove-Question on AS9120/ISO9001 reference
Thanks Coury,
It can't get any easier for us as we are a wire and cable distributor and all we do is spool wire.
DannyK
Within the Quality Manual, you should list the applicable quality management standards that you conform to. Management usually sign offs a statement indicating their commitment to these standards. Listing the AS9120 or ISO 9001 anywhere else is up to you, unless there is a specific requirement in AS9120 that does not apply to all customers.
julsbear
A simple cross reference is not required but will be useful during audits if an auditor asks how do you cover 7.3......... and for any corrective actions that may arise.
It is also useful when a standard changes.
You can also use it to trace the interrelations between processes.
The registrar I work with would prefer to see both AS and ISO referenced. For example for an AS9100 company they would prefer the documentation to show "AS9100B:2004 and ISO 9001:2000"
Stijloor
In an integrated Quality Management System it is not required/necessary. Including references to both Standards makes the job easier for the Auditor.;)
Stijloor.
I IEC 60812 or ISO 14971 for PFMEA? What should we use? ISO 14971 - Medical Device Risk Management 3
qualprod Do sum of results of quality objectives should met a high level goal? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F Should I perform several Gage R&R for every caliper to cover all specs range of use? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
E Opening meeting for Third-Party Audit--Who should say what? General Auditing Discussions 22
8 MSA--Should I Use Parts or Gage Pins? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Should I buy IEC 62304:2006, IEC 62304:2006/AMD 1:2015 or both? EU Medical Device Regulations 1
W "Accurate to ±2%" means "64% of measurements should be within 2% of the actual value"? US Medical Device Regulations 4
H Should we stop inspecting a part if its never been rejected? Reliability Analysis - Predictions, Testing and Standards 6
D What distributor requirement should we (manufacturer) require from the Distributor? EU Medical Device Regulations 0
M Should there be another column in the Optimization section (step 6) of AIAG-VDA DFMEA form? FMEA and Control Plans 1
C By when should harmonized standards be complied with? EU Medical Device Regulations 5
W Strategy for determining which components from a system should be "ME EQUIPMENT" -- home healthcare environment IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
B Documented information - Should be controlled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Is engineering a process and should it have its own process turtle? IATF 16949 - Automotive Quality Systems Standard 7
P Which MDCG Document should I use for PMS Plan and PSUR? EU Medical Device Regulations 2
M Who should quality representative report to? ISO 13485:2016 - Medical Device Quality Management Systems 5
H When should the first PSUR be issued? EU Medical Device Regulations 5
I If i do not want to be an initial importer should i register with FDA? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
O Should a Covid vaccine and testing policy be included as part of ISO9001 or AS9100 risk management? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B UKRP to what level should you audit Class I Technical Documentation? UK Medical Device Regulations 0
C When should you quit programming? Job Openings, Consulting and Employment Opportunities 9
C Should resolution be included in uncertainty budget for digital caliper or micrometer calibration? Measurement Uncertainty (MU) 5
Ed Panek External Standards List - Should this document include previously revised standards? ISO 13485:2016 - Medical Device Quality Management Systems 4
T How should I approach REACH, CM, etc. as a job shop? RoHS, REACH, ELV, IMDS and Restricted Substances 18
A Should we assign the PRRC before the date of application of MDR (26 May 2021)? EU Medical Device Regulations 0
J UDI-DI how should we interpret Device version or model to determine if a new UDI-DI is needed? EU Medical Device Regulations 0
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance document to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
S Which Sampling Plan(s) Should I Use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
N Master Samples - What should we be keeping? IATF 16949 - Automotive Quality Systems Standard 9
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 7
John Broomfield Should ISO 9004 Become a Requirements Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 69
J Should Loading and Unloading be Included in Cycle Times? Lean in Manufacturing and Service Industries 14
E Manufacturers should develop a testing device for covid19 Service Industry Specific Topics 0
T 510(k) submission - Which name should I use in the submission? Other US Medical Device Regulations 3
N ISO 19011:2018 - 5.4.2 "...audit program should engage in appropriate continual development..." Training - Internal, External, Online and Distance Learning 4
M Should 510(k) Predicates be Actively Listed Devices? Other US Medical Device Regulations 12
H Who should be listed as the manufacturer/distributor on the box? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
