Should Internal Audit CAPAs be kept separate from "normal" CAPAs?
L
Lesley1707
Hi Guys,
not sure if I am posting on the correct forum but I shall continue anyway. We had a Stage 1 audit for ISO13485 recently and the auditor gave us 1 Major NC, the only major :), for internal audit CAPAs not being linked to normal CAPAS. When we perform internal audits our CAPAs are attached to the audit form and are uniquley identified. I am really confused as this is what I have always done in previous lives! Is there something I am missing / not understanding?
Any advice from you good people would be appreciated!
Ronen E
Problem Solver
Moderator
Hi Guys,
Have you asked the auditor to "show you the Shall"...?
In my understanding, if your documented procedure defines that this is how you handle NCs found in internal audits, and the internal-audit-CA(PA) are handled according to ISO 13485:2003 8.2.2, there's no reason to issue a major NC. The wisdom of this specific arrangement can be debated, but by face value it doesn't contradict the standard.
Cheers,
Ronen.
insect warfare
QA=Question Authority
Hi Guys,
Correct me if I'm wrong, but if this is a Stage 1 audit, shouldn't this be an "area of concern" instead of a "Major NC"? I thought the whole purpose of Stage 1 was to assess readiness for a Stage 2, so there would be no point in classifying NC's if Stage 2 was not even allowed to proceed based on the results of Stage 1. They would all equally be "areas of concern" that would require addressing anyway.
:2cents:
Brian :rolleyes:
L
Laura Halper
Lesley,
Without seeing the actual NC wording, it sounds like the issue is that your company has two separate CAPA programs (one for problems identified during internal audits and one for problems identified from all other sources). Without some linkage between them, the existence of the internal audit CAPA's may not be evident.
Sp as Ronen pointed out, it is important that your CAPA Procedure clearly explain how you handle CAPA's from internal audits, and how you handle CAPA's from all other sources. If you keep two separate CAPA logs, then this should also be stated in the Procedure. Your Procedure could provide the linkage between the two systems.
jinggu
I don't think having two CAPA systems is a problem. My company set out using two spreadsheets tracking CAPAs opened through different sources, being internal and external audit. Later on, we merged two into a universal system. Unless you have tons of CAPA opened which let's hope is not the case. As long as they are uniquely identified and tracked, it's really up to your organization. Just my two cents!
Jing
L
lyang
Hi Guys,
If you are a medical device company, it's recommended not to link Internal Audits to CAPA. This is coming from Ex-FDA Investigator. By linking your Internal Audit CAPA to your CAPA program, by law, FDA Investigator can request Internal Audit Report of the said CAPA. This is why many large medical device manufacturer seperate the two system.
To your question, in my opinion, I don't see how that is a major. Maybe if you explain the above, it may help you build credibility that what you are doing is correct. My company do not link Internal Audit CAPA with our general CAPA program for this very reason.
Just remember if the police ask if they can enter your house, you can say no...once you say yes, they can look at anything and everything without a warrant. This same rules applies to Internal Audit.
My two cents.
K
kgott
Hi Guys,
While I agree with the replies above about it not being a requirement of the standard to combine internal and external CAPAs, I don't see that there is a problem in doing as the auditor (should) suggests.
Unless you have a good reason for doing so, of what value is the silo approach to your business by keeping them seperate?
T Should the Internal audit for ISO 9001 cover all elements of the standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
C How should I present Internal Audit results to Management in Management Review Internal Auditing 18
T Who should provide information I ask for? Internal Audit question Internal Auditing 4
R Should Internal Audit criteria be a Controlled Document? Internal Auditing 5
K Should Internal Audit Plan be Approved by Top Management? Internal Auditing 19
O Should Staff have Access to see Internal and/or CB Audit Results? Internal Auditing 5
G Internal Audit Report Meeting - Who should be present? Internal Auditing 19
M Should Internal Audit Checklists be Controlled Documents? Document Control Systems, Procedures, Forms and Templates 9
J Internal Audit Teams - How big the audit team should be and who should be on it General Auditing Discussions 6
Coury Ferguson Should a Registrar write a NC on something that was found during the Internal Audit Registrars and Notified Bodies 138
P Internal PPAP Audit - What should I ask? Plastic parts (automotive) TS 16949 IATF 16949 - Automotive Quality Systems Standard 7
P The Optimal IA Schedule - How should the Internal Audit Schedule be set up? General Auditing Discussions 26
R ISO19011 Internal Audit Schedule - Should it have to be approved? General Auditing Discussions 12
S Internal Audit Team - The number of internal auditors a company should have Internal Auditing 4
C Should I get an Internal Auditor Certification of Exemplar Global / RABQSA? Internal Auditing 17
R Should internal auditors be compulsorily certified as internal auditors ? Internal Auditing 11
R Full Time Internal Auditor - Where should I be looking for someone? Career and Occupation Discussions 15
R What questions should I ask during Internal Audits? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Z Should we recertify our internal auditors as we transitioned to ISO 9001:2008? Internal Auditing 1
S Internal Auditor Training - How often should an internal auditor be trained? Training - Internal, External, Online and Distance Learning 15
S Who should do the CA's (Corrective Actions) from Internal Audits Internal Auditing 9
S Internal Auditor Qualifications - What qualifications should I include? Internal Auditing 49
I Auditing the CEO - How? What should our Internal Auditor ask? Internal Auditing 6
A Should Customer Complaints trigger Internal Audits? Customer Complaints 6
A Scheduling Internal Audits - What should I be auditing and when Internal Auditing 8
K Should QS/TS certified internal test/calibration labs be required to be ISO17025 ISO 17025 related Discussions 16
C Should resolution be included in uncertainty budget for digital caliper or micrometer calibration? Measurement Uncertainty (MU) 4
Ed Panek External Standards List - Should this document include previously revised standards? ISO 13485:2016 - Medical Device Quality Management Systems 4
T How should I approach REACH, CM, etc. as a job shop? RoHS, REACH, ELV, IMDS and Restricted Substances 18
A Should we assign the PRRC before the date of application of MDR (26 May 2021)? EU Medical Device Regulations 0
J UDI-DI how should we interpret Device version or model to determine if a new UDI-DI is needed? EU Medical Device Regulations 0
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance document to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Which Sampling Plan(s) Should I Use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
N Master Samples - What should we be keeping? IATF 16949 - Automotive Quality Systems Standard 9
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
John Broomfield Vote - Should ISO9004 Become a Requirements Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J Should Loading and Unloading be Included in Cycle Times? Lean in Manufacturing and Service Industries 14
E Manufacturers should develop a testing device for covid19 Service Industry Specific Topics 0
T 510(k) submission - Which name should I use in the submission? Other US Medical Device Regulations 3
N ISO 19011:2018 - 5.4.2 "...audit program should engage in appropriate continual development..." Training - Internal, External, Online and Distance Learning 4
