Should Internal Audit Checklists be Controlled Documents?
Meggsy
Hi Guys; - As per the subject heading, should I make Audit Checklists Controlled Documents?
Thanks in advance
somashekar
Thanks in advance
NO NO NO ... Its a ready reconer for the auditor and the auditor must be free to make more check points than the checklist contents. You must encourage the auditor to make his own checklist and you will see that as auditing standards mature these checklists will slowly become redundent.
Jeff Frost
Thanks in advance
The basic form should be controlled but the actual checklist for each process is subject to change and should not be controlled.
Meggsy
I agree that checklists shouldn't even be required, but managers are asking for them... so... what's a girl to do? :confused:
Our Internal Audit Procedure is written such that "Checklists may be used, however the auditor can used another method if preferred", plus I also have a spot for "additional requirements" at the bottom of each checklist so the auditor can add their own flavour.
I think I'll just stock them all in a folder and not control them.
Thanks :thanks:
somashekar
Thanks :thanks:
Meggsy .. you can do a lot. First let the checklist and the audit report not be a combined document if they are combined as of now. Make a set of audit questions that typically needs to be asked as a checklist and provide them to the auditors (managers) and encourage them to go beyond it since they are trained to do the internal audits. The best way one can acquire good auditing techniques after the IA training is by quickly conducting audits Try to use this list here and feel free to modify it for your requirement. Hope you will feel better .... :) <<< Good luck >>>
That is interesting. Why are they asking for them?
Anyway, there are many ways to do this, but I'll tell you what I do: I still go by the old school, preparing a unique checklist for each audit (I find them to be too good as tools go to omit them). Thus the form as such is not controlled, but I do add the completed checklist as an appendix to the report, so it is a record in our system. I should also add that our entire audit system (Planning, checklists, reports, improvement actions and follow up) is handled in an Access application we cobbled together many years ago, so we regard the entire database as a record.
Just food for thought.
/Claes
I'm with Claes on this one. Why would a manager ask for one? Are they hoping to get a 'jump' on the internal auditors by looking at the checklist? If so, then I'd look at the way you are planning your audits or something similar.
When people feel the need to 'prepare' for an internal audit, there's something going on which needs to be addressed! If, for example, you are auditing from ISO 9001 (or a similar standard) then the terminology is strange to management, so they need to see the checklist so they can interpret and prepare for the audit.
Tell us more and we can help you improve your process, past this symptom...
ScottK
Not out of the crisis
Managers like audit checklists so they know what to prepare for and have copy of the checklist in their hands as the audit is performed.
Most of the customers I host give me a copy of their checklist up front.
They are pretty vague and leave a lot of room for further exploration.
Even our CE marking body has a standard controlled checklist for the directives. It in no way hinders their effectiveness and I use it for internal directive audits.
I use checklists in internal audits. But they change from audit to audit so they are not controlled as a form.
I control the template, but part of the auditor's job is to create a checklist for each audit based on the standards and past audits.
JaneB
Good question. While I agree to some extent that preparation 'shouldn't' be necessary, an organisation often doesn't reach that level of maturity for some time (some, alas, never do)
I've found managers often ask for checklists or the like in circumstances such as:
  • internal audit only just beginning
  • new managers, inexperienced with/new to the whole idea of internal audit, and thus a bit nervous or apprehensive
  • organisation with a command & control, fear-based culture, where mistakes are punished - what manager would not want to prepare as much as possible in such a culture?
  • someone who's had bad experience with audit in the past; this might be anything from audits always done to a rigid checklist, audit with incompetent auditor, poorly defined scope, no procedure to being punished based on poor results
Often, they're just seeking an idea of what might be covered - not so much to 'cover up' or 'prepare', as to understand what will happen. A good explanation beforehand, opening meeting, etc etc can do much to help. As Andy says, it's a symptom of something. What?
donaokka
Yes,jeff is right, the form should be controlled by doucument center; but this action-internal audit should not controlled;
T Should the Internal audit for ISO 9001 cover all elements of the standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
L Should Internal Audit CAPAs be kept separate from "normal" CAPAs? ISO 13485:2016 - Medical Device Quality Management Systems 6
C How should I present Internal Audit results to Management in Management Review Internal Auditing 18
T Who should provide information I ask for? Internal Audit question Internal Auditing 4
R Should Internal Audit criteria be a Controlled Document? Internal Auditing 5
K Should Internal Audit Plan be Approved by Top Management? Internal Auditing 19
O Should Staff have Access to see Internal and/or CB Audit Results? Internal Auditing 5
G Internal Audit Report Meeting - Who should be present? Internal Auditing 19
J Internal Audit Teams - How big the audit team should be and who should be on it General Auditing Discussions 6
Coury Ferguson Should a Registrar write a NC on something that was found during the Internal Audit Registrars and Notified Bodies 138
P Internal PPAP Audit - What should I ask? Plastic parts (automotive) TS 16949 IATF 16949 - Automotive Quality Systems Standard 7
P The Optimal IA Schedule - How should the Internal Audit Schedule be set up? General Auditing Discussions 26
R ISO19011 Internal Audit Schedule - Should it have to be approved? General Auditing Discussions 12
S Internal Audit Team - The number of internal auditors a company should have Internal Auditing 4
C Should I get an Internal Auditor Certification of Exemplar Global / RABQSA? Internal Auditing 17
R Should internal auditors be compulsorily certified as internal auditors ? Internal Auditing 11
R Full Time Internal Auditor - Where should I be looking for someone? Career and Occupation Discussions 15
R What questions should I ask during Internal Audits? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Z Should we recertify our internal auditors as we transitioned to ISO 9001:2008? Internal Auditing 1
S Internal Auditor Training - How often should an internal auditor be trained? Training - Internal, External, Online and Distance Learning 15
S Who should do the CA's (Corrective Actions) from Internal Audits Internal Auditing 9
S Internal Auditor Qualifications - What qualifications should I include? Internal Auditing 49
I Auditing the CEO - How? What should our Internal Auditor ask? Internal Auditing 6
A Should Customer Complaints trigger Internal Audits? Customer Complaints 6
A Scheduling Internal Audits - What should I be auditing and when Internal Auditing 8
K Should QS/TS certified internal test/calibration labs be required to be ISO17025 ISO 17025 related Discussions 16
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance standard to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
N Master Samples - What should we be keeping? IATF 16949 - Automotive Quality Systems Standard 9
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
John Broomfield Vote - Should ISO9004 Become a Requirements Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J Should Loading and Unloading be Included in Cycle Times? Lean in Manufacturing and Service Industries 14
E Manufacturers should develop a testing device for covid19 Service Industry Specific Topics 0
T 510(k) submission - Which name should I use in the submission? Other US Medical Device Regulations 3
N ISO 19011:2018 - 5.4.2 "...audit program should engage in appropriate continual development..." Training - Internal, External, Online and Distance Learning 4
M Should 510(k) Predicates be Actively Listed Devices? Other US Medical Device Regulations 12
H Who should be listed as the manufacturer/distributor on the box? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
