Should Preventative Action follow a Corrective Action
#11
If it's identified as a Preventive Action within the QMS it's not optional what you do with it. If an identified Preventive Action is not addressed as such and according to 8.5.3, then the lack of action becomes a nonconformity itself.
Look at the definition of Preventive Action above....the definition is non-negotiable and when one is recorded within a 9001 based QMS it's not a suggestion
When you find yourself in a hole, stop digging. There's an idea or a suggestion, and then there's action if action is appropriate. It is optional what you do with the idea or suggestion--you can implement the PA or not.
Christopher S
#12
So judging from all your comments and other threads on this subject I have a few more questions as follows:
1. Can I issue a PA without having the need to issue a CA?
2. Do I need to know the Root cause of the problem before issuing the PA?
3. Do I need to know the Root cause before issuing a CA?
4. Can the Root cause potentially be different for a CA and a PA or are we really looking at resolving the same problem but with different time elements (i.e. past and future)?
Regards
Christopher
Stijloor
#13
Regards
Christopher
For clarification:
  • Do you interpret CA as a Corrective Action Request?
  • Do you interpret PA as a Preventive Action Request?
Stijloor.
Christopher S
#14
Yes you are right! A CA is a Corrective Action Request (should be CAR) and a PA is a Preventative Action Request (should be PAR)
Regards
Christopher
somashekar
#15
Regards
Christopher
If you broaden your outlook and view, then one could see the implementing and maintaining a QMS in itself is a big preventive action. Do not be much worried about issuing a PA. If your CA activity has the depth and is applied across the board, this in itself is a good action.
Randy
#16
Regards
Christopher
1. Yes...it's a stand-alone requirement
2. Nope...
3. Nope...
4. There's a big difference between the need for CA and PA...A CA is performed after something breaks and a PA is done when you realize that unless action is taken something will or can break. The difference is one is reactive and the other is proactive (past vs future)
Oh...and at least I'm digging instead of just talking there Jim.;)
Big Jim
#17
Regards
Christopher
I think you suffer from a very common misconception.
If you think that Preventive action (as required by element 8.5.3) is what you do to keep something you have completed a Corrective Action on to prevent it from happening again, you are wrong.
That would be part of the Corrective Action.
Corrective Actions are reactive in nature. They are what you do to overcome something that has happened.
Preventive Actions are proactive in nature. Thay are what you do to keep a POTENTIAL problem from happening.
Think in terms of a train wreck. Once the wreck has happened, everything you do from that point on about that train wreck are part of a Corrective Action because it has already happened.
If you can see a train wreck is imminent, what you do to keep it from happening is part of a Preventive Action.
When you ask if you need to have a Corrective Action before you attempt to do a Preventive Action shows that you do not understand. They are, as Randy pointed out, seperate issues.
Take a look at the standard, and underline the word "recurrance" in 8.5.2 and underline the word "occurance" in 8.5.3. That may help to see the difference.
Christopher S
#18
Thank you to Big Jim, Randy and Somashekar (and the rest) for the very complete explanation. It has been extremely helpful in understanding the process.
Best regards
Christopher
Q
QCAce
#19
Christopher...
One more little tid-bit as you start to implement preventive actions...
CARs instances usually have good data sources and are easy to identify, but PAR opportunities are harder to come by.
A good source for preventitive actions are internal audit observations. The audit nonconformances always generate CARs, and the observations many times lead to good PAR opportunities.
Christopher S
#20
Thanks to Andy Nutt again for his comment. This then makes me wonder whether a Corrective Action should always follow a Non-Conformance or can a Non-Conformance be an end in itself?
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance standard to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
N Master Samples - What should we be keeping? IATF 16949 - Automotive Quality Systems Standard 9
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
John Broomfield Vote - Should ISO9004 Become a Requirements Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J Should Loading and Unloading be Included in Cycle Times? Lean in Manufacturing and Service Industries 14
E Manufacturers should develop a testing device for covid19 Service Industry Specific Topics 0
T 510(k) submission - Which name should I use in the submission? Other US Medical Device Regulations 3
N ISO 19011:2018 - 5.4.2 "...audit program should engage in appropriate continual development..." Training - Internal, External, Online and Distance Learning 4
M Should 510(k) Predicates be Actively Listed Devices? Other US Medical Device Regulations 12
H Who should be listed as the manufacturer/distributor on the box? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
M MDR, RED and LVD - Should our device comply with them? EU Medical Device Regulations 3
BeaBea How Many Processes should be created for each Department? Process Maps, Process Mapping and Turtle Diagrams 5
M Should volume of sales be factored into risk probability assessments? ISO 14971 - Medical Device Risk Management 33
S Should safety checks be included in the Control Plan? IATF 16949 - Automotive Quality Systems Standard 5
M Which incubation condition should be selected to recover both bacteria and fungus effectively Miscellaneous Environmental Standards and EMS Related Discussions 3
D Is there a specific location for PPE such as safety glass holders and glove dispensers should be mounted Occupational Health & Safety Management Standards 10
M Who should receive the bills from suppliers and vendors, account payable or procurement? Consultants and Consulting 4
A We are ISO 13485:2016 should we be audited to ISO 14971 ISO 13485:2016 - Medical Device Quality Management Systems 16
E Received a Major finding during IATF Surveillance audit for loss of BIQS Level 3 (more than 6 SPPS in 6 months)...how should we address SYSTEMIC CA? IATF 16949 - Automotive Quality Systems Standard 11
J Organization merger. Should we keep two separate ISO 13485 certificates? ISO 13485:2016 - Medical Device Quality Management Systems 6
S Companies that maintain your machine should be in ASL? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Use of "Shall" versus "Should" in Procedures ISO 13485:2016 - Medical Device Quality Management Systems 26
D Class II medical device - When should a complaint be closed? Customer Complaints 6
Sidney Vianna IATF 16949 News Presentations from the latest IATF Stakeholder Event - Expectation that IATF 16949 certification should equate with product quality. Misguided? IATF 16949 - Automotive Quality Systems Standard 7
Ed Panek Part 11 Self Certify Memo - What else should it cover? Qualification and Validation (including 21 CFR Part 11) 5
H Should I mention machine/Equipment password In SOP? Qualification and Validation (including 21 CFR Part 11) 4
D How long should we keep the spare parts available for our medical device, after we have stopped the production? ISO 13485:2016 - Medical Device Quality Management Systems 0
H Statistical Techniques Procedure - What should be included Document Control Systems, Procedures, Forms and Templates 4
Sidney Vianna Interesting Discussion ISO 9001:2024 - What should be changed in the next Edition of ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 113
N Should it even be on the hazard analysis (software)? FMEA and Control Plans 2
V Which batches should or could be considered for design validation and design verification? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
