Should the primary drug containers be molded in ISO Class 7 clean room?
SGquality
We are in discussion with a pharmaceutical manufacture for manufacture of plastic primary drug containers.
The customer wants these plastic injection molded primary containers to be molded in ISO Class 7 area as the Class 7 clean rooms have lower particulates while we feel that ISO Class 8 would suffice. The molded plastic containers would be molded, washed, and then sterilized, and the customer would fill drug product aseptically in these containers.
Are there any regulations / standards that would help me in this direction? Also are there are testing criteria for the molded plastic containers to be used exclusively by the drug industry?
Appreciate your help.
chris1price
Hi
To answer your last part first, I don't believe there are any regulations or standards that would give you guidance or any specific testing. I would suggest a great deal depends on your validation of the processes, Washing, packaging and sterilisation.
I was ok with saying Class 8 until you mentioned aseptic filling by the pharma company. The regulatory expectations for aseptic filling are increasing continuously, a complete revision is expected this year. Consequently, I am not surprised they are asking for Class 7, or more likely Grade C.
One final thought, if this is an existing product and the customer wants you to upgrade from Class 8 to 7, that's always an opportunity to pass a cost increase to the customer.
Chris
SGquality
Hi
Chris
Thanks Chris.
This is a new product and the client is a startup company and they want us to mold in Class 7 based on what they heard from someone in their circle. Volume 4, Annex 1 (Manufacture of Sterile Medicinal Products), states that "Components after washing should be handled in at least a grade D environment". I was banking on this statement that the plastic containers can be molded in Grade D and also after washing be handled in the same environment.
When you say, a revision in the aseptic filling document is expected this year, which document are you referring to?
Thank you for your help :thanx:
chris1price
Hi, The revision to Eudralex Vol 4, Annex 1 (GMP Guidelines, Manufacture of Sterile Medicinal Products) was published for comment at the end of Dec 2017.
https://ec.europa.eu/health/sites/health/files/files/gmp/2017_12_pc_annex1_consultation_document.pdf
Revision of Annex 1 "Manufacture of Sterile Medicinal Products" published for Comments - ECA Academy
It still requires substantial editing, but is likely to come into effect in the next 6 months or so. There is a lot of debate about the content, but it is a lot more coherent then than the existing Annex 1. While the final version may be watered down a little, is is likely to be significantly tighter than the 2008 version.
I appreciate this doesn't directly affect US regulations today, but it shows the general ratcheting-up of compliance requirements.
Unfortunately, there is nothing here that directly answers your question. It is just the continuous tightening of regulations that makes me suspect class 7 would be the preferred option in the long term.
Chris
chris1price
Since writing my previous response, I discussed this with colleagues. A consensus was that class 8 would probably be acceptable provided that the processes were fully validated.
Chris
SGquality
Chris
Is final rinse with WFI after plastic drug containers are molded and before wrapping for sterilization, an absolute requirement ?
E Please help! ! I AM FRASTRATED SO MUCH! Should inactive ingredient be included in the unit formula if it is removed during the manufacturing process? US Food and Drug Administration (FDA) 0
I IEC 60812 or ISO 14971 for PFMEA? What should we use? ISO 14971 - Medical Device Risk Management 3
qualprod Do sum of results of quality objectives should met a high level goal? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F Should I perform several Gage R&R for every caliper to cover all specs range of use? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
E Opening meeting for Third-Party Audit--Who should say what? General Auditing Discussions 22
8 MSA--Should I Use Parts or Gage Pins? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B Should I buy IEC 62304:2006, IEC 62304:2006/AMD 1:2015 or both? EU Medical Device Regulations 1
W "Accurate to ±2%" means "64% of measurements should be within 2% of the actual value"? US Medical Device Regulations 4
H Should we stop inspecting a part if its never been rejected? Reliability Analysis - Predictions, Testing and Standards 6
D What distributor requirement should we (manufacturer) require from the Distributor? EU Medical Device Regulations 0
M Should there be another column in the Optimization section (step 6) of AIAG-VDA DFMEA form? FMEA and Control Plans 1
C By when should harmonized standards be complied with? EU Medical Device Regulations 5
W Strategy for determining which components from a system should be "ME EQUIPMENT" -- home healthcare environment IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
B Documented information - Should be controlled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Is engineering a process and should it have its own process turtle? IATF 16949 - Automotive Quality Systems Standard 7
P Which MDCG Document should I use for PMS Plan and PSUR? EU Medical Device Regulations 2
M Who should quality representative report to? ISO 13485:2016 - Medical Device Quality Management Systems 5
H When should the first PSUR be issued? EU Medical Device Regulations 5
I If i do not want to be an initial importer should i register with FDA? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
O Should a Covid vaccine and testing policy be included as part of ISO9001 or AS9100 risk management? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B UKRP to what level should you audit Class I Technical Documentation? UK Medical Device Regulations 0
C When should you quit programming? Job Openings, Consulting and Employment Opportunities 9
C Should resolution be included in uncertainty budget for digital caliper or micrometer calibration? Measurement Uncertainty (MU) 5
Ed Panek External Standards List - Should this document include previously revised standards? ISO 13485:2016 - Medical Device Quality Management Systems 4
T How should I approach REACH, CM, etc. as a job shop? RoHS, REACH, ELV, IMDS and Restricted Substances 18
A Should we assign the PRRC before the date of application of MDR (26 May 2021)? EU Medical Device Regulations 0
J UDI-DI how should we interpret Device version or model to determine if a new UDI-DI is needed? EU Medical Device Regulations 0
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance document to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
S Which Sampling Plan(s) Should I Use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
N Master Samples - What should we be keeping? IATF 16949 - Automotive Quality Systems Standard 9
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 7
John Broomfield Should ISO 9004 Become a Requirements Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 70
J Should Loading and Unloading be Included in Cycle Times? Lean in Manufacturing and Service Industries 14
E Manufacturers should develop a testing device for covid19 Service Industry Specific Topics 0
T 510(k) submission - Which name should I use in the submission? Other US Medical Device Regulations 3
N ISO 19011:2018 - 5.4.2 "...audit program should engage in appropriate continual development..." Training - Internal, External, Online and Distance Learning 4
M Should 510(k) Predicates be Actively Listed Devices? Other US Medical Device Regulations 12
