Should the TC 176 Re-word the Requirements for Preventive Action?
Should the TC 176 have re-worded 8.5.3 to clarify the requirements for prev. action?
  • Yes. Most definitely 8.5.3 needs clarification.
    Votes: 13 72.2%
  • No. Preventive action requirements are very clear. No clarification is needed.
    Votes: 5 27.8%
  • Total voters
    18
CarlDaniel
#31
Thanks for clarifying these things and in much simpler perspective too...About monitoring for "several weeks", I don't actually use that instead I use an exact time frame as you pointed out.
Peter Fraser
#32
A few observations:
1 The wording of 8.5.2 ("take action to eliminate") and 8.5.3 ("determine action to eliminate") is slightly different for no reason. 8.5.3 is a waste of paper.
2 The requirements for CA / PA are in fact identical - the only difference is that they are triggered by different events. For CA, something has happened. For PA, you realise that something might happen. In both cases, you work out how to avoid the "something" happening in the future.
3 You might therefore think that they could reasonably be described in a single procedure - but how you "recruit staff" / "provide training" / "accept a customer order" / "plan and monitor production" (even "design a process") should all be done in a way which anticipates problems (ie CA / PA). This is what "process management " is all about, ie you design and implement processes in a way which recognises the factors which may influence how well the processes will work.
Unfortunately, the wording of the standard causes folk to think that they have to do more than what a "good" manager should be doing anyway.
Helmut Jilling
Auditor / Consultant
#33
A few observations:
I would think your point #2 would demonstrate there is a value in PA, rendering point #1 incorrect?
Peter Fraser
#34
Helmut
On the contrary, 8.5.3 repeats almost all the wording of 8.5.2. If the first part of the clause explained the two types of trigger event, the steps required are the same. Words for words sake...
V
vanputten
#35
I would like to offer some systems thinking ideas to the thread. Many might say that I am over thinking this.
I think that true preventive action is when the information, upon which you base your action, comes from outside of the system. Cascading corrective action to similar areas in the system (organization) to me is still corrective action. When someone brings information into the system from sources outside of the system, then you really have preventive action. Re-applying what you have learned from within the system, to me, is corrective action.
I don't think time sequence has anything to do with the definitions. I think the source of the information upon which you base your action is the more valid basis. Is something unwanted happens within your system, and you fix the unwanted thing (elimiante the cause) and then cascade that to other areas within the system, is still corrective aciton to me.
If understanding and knowledge comes from outside the system, and this understanding and knowledge allows you to eliminate the casue of a potential unwanted thing, then I say that is preventive aciton.
For those that say this is over thinking it, I say that your wrong. What would support bringing new understanding into the system if this is overthinking things?
Sidney Vianna
Post Responsibly
#36
Like Hjiling says: crystal clear:biglaugh:.
In my mind there is no question that preventive action should be THE main target for clarification in ISO 9001. The mystery is why doesn't the TC176 realize that? Or, if they do, why don't they do something about it? Another conspiracy?
Helmut Jilling
#37
Helmut
Precisely...and your point #2 correctly points out the subtle but important difference. THAT is what gives it value in my opinion - the fact that Preventives are intended to be a proactive search for potential failure. That is far superior than waiting for issues to arise. Thus, the value of 8.5.3. Now, if only they would emphsize that important distinction so everyone would get it...:cool:
Helmut Jilling
#38
...hey, it's crystal clear to ME, if the rest of you don't get it...that not my fault...:notme:
Now, I took the time to accept your challenge to write 5 examples of PA...Sooo...my friend, I expect you will at least take time to read my white paper and tell me why you don't like my 5 examples...hmmm?
JaneB
#39
... how you "recruit staff" / "provide training" / "accept a customer order" / "plan and monitor production" (even "design a process") should all be done in a way which anticipates problems (ie CA / PA). This is what "process management " is all about, ie you design and implement processes in a way which recognises the factors which may influence how well the processes will work.
Yes indeed. As well as planning. Good planning includes sound 'preventive action' and risk management - ie, anticipating things that *might* not work/go wrong etc. and planning, designing & implementing to prevent or avoid that.
JaneB
#40
Will do.
This thread has certainly stimulated some spirited and interesting debate, for which thanks to all. :applause:
A Should we assign the PRRC before the date of application of MDR (26 May 2021)? EU Medical Device Regulations 0
J UDI-DI how should we interpret Device version or model to determine if a new UDI-DI is needed? EU Medical Device Regulations 0
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance document to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
N Master Samples - What should we be keeping? IATF 16949 - Automotive Quality Systems Standard 9
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
John Broomfield Vote - Should ISO9004 Become a Requirements Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J Should Loading and Unloading be Included in Cycle Times? Lean in Manufacturing and Service Industries 14
E Manufacturers should develop a testing device for covid19 Service Industry Specific Topics 0
T 510(k) submission - Which name should I use in the submission? Other US Medical Device Regulations 3
N ISO 19011:2018 - 5.4.2 "...audit program should engage in appropriate continual development..." Training - Internal, External, Online and Distance Learning 4
M Should 510(k) Predicates be Actively Listed Devices? Other US Medical Device Regulations 12
H Who should be listed as the manufacturer/distributor on the box? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
M MDR, RED and LVD - Should our device comply with them? EU Medical Device Regulations 3
BeaBea How Many Processes should be created for each Department? Process Maps, Process Mapping and Turtle Diagrams 5
M Should volume of sales be factored into risk probability assessments? ISO 14971 - Medical Device Risk Management 33
S Should safety checks be included in the Control Plan? IATF 16949 - Automotive Quality Systems Standard 5
M Which incubation condition should be selected to recover both bacteria and fungus effectively Miscellaneous Environmental Standards and EMS Related Discussions 3
D Is there a specific location for PPE such as safety glass holders and glove dispensers should be mounted Occupational Health & Safety Management Standards 10
M Who should receive the bills from suppliers and vendors, account payable or procurement? Consultants and Consulting 4
A We are ISO 13485:2016 should we be audited to ISO 14971 ISO 13485:2016 - Medical Device Quality Management Systems 16
E Received a Major finding during IATF Surveillance audit for loss of BIQS Level 3 (more than 6 SPPS in 6 months)...how should we address SYSTEMIC CA? IATF 16949 - Automotive Quality Systems Standard 11
J Organization merger. Should we keep two separate ISO 13485 certificates? ISO 13485:2016 - Medical Device Quality Management Systems 6
S Companies that maintain your machine should be in ASL? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Use of "Shall" versus "Should" in Procedures ISO 13485:2016 - Medical Device Quality Management Systems 26
D Class II medical device - When should a complaint be closed? Customer Complaints 6
Sidney Vianna IATF 16949 News Presentations from the latest IATF Stakeholder Event - Expectation that IATF 16949 certification should equate with product quality. Misguided? IATF 16949 - Automotive Quality Systems Standard 7
Ed Panek Part 11 Self Certify Memo - What else should it cover? Qualification and Validation (including 21 CFR Part 11) 5
H Should I mention machine/Equipment password In SOP? Qualification and Validation (including 21 CFR Part 11) 4
D How long should we keep the spare parts available for our medical device, after we have stopped the production? ISO 13485:2016 - Medical Device Quality Management Systems 0
H Statistical Techniques Procedure - What should be included Document Control Systems, Procedures, Forms and Templates 4
Sidney Vianna Interesting Discussion ISO 9001:2024 - What should be changed in the next Edition of ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 114
