Should we do Incoming Inspection (Receiving Inspection)?
E
emmasj
I a bit of a dilema & would appriciate some advice.
We are in the process of implementing TS16949 at our site. We are coming under our 'group' certification as a 'remote location'.
The problem I have is - should we carry out incoming inspection & if we should how to go about it.
As a remote location we receive parts (fasteners) from our manufacturing units as finished goods & semi-finished goods.
We also buy product from outside the group.
We then send semi-finished product out to plating suppliers outside of the group.
We probably receive somewhere in the region of 20million pcs of product a week covering approximately 200 - 300 different products.
What would satisfy TS in this area?
Thanks.
Emma
Dean Frederickson
Re: Incoming Inspection dilema - Should we carry out incoming inspection?
Thanks.
Emma
Hello Emma. What is your current procedure for incoming (receiving) insp.? If you have one follow it, if not write one. You can tailor this procedure to meet your needs. If this is a good vendor(s) you can inspect so many shipments and if there are no rejects, put them on your approved suppliers list. Once on your approved suppliers list you won't have to inspect every shipment, if the need arises you can do a dock audit on the shipment in question. Just MHO.
E
emmasj
Hi Dean,
Thanks for your response.
We don't currently have any procedures, our side of the group has never been accredited to any quality system!
All our suppliers are on an Approved Suppliers List as this is controlled by Global Purchasing within the group. The list is open to all our sites & these are the suppliers that must be used. Most of the suppliers have supplied to the group for many years.
Can we get away with just doing an incoming check on the product label against the delivery notes?
Then write a procedure for incoming inspection of product from new suppliers & new product from existing suppliers??
Emma
martin elliott
See clause 7.4.3.2 Note 4 shall's apply.
You can't avoid all incoming inspection because you will need to justify the effectiveness of your suppliers in some way.
You could try tailoring your inwards inspection levels on the basis of customer complaints etc. No problems then little infrequent inspection. Lots of problems higher frequency.
Dean Frederickson
Emma, as long as your suppliers are on a approved suppliers list there is no need for receiving insp., for new suppliers or product change yes write a procedure, remember there should be a history record of acceptable product received with no rejects( a lot of this will depend on how often, how many, and criticalness of parts received) before you can place them on your own approved suppliers list. In response to Martin, this is where you can perform a occasional Dock Audit as stated in my first response to you.
( I am not sure if "criticalness" is actually a word but it sounded good and I think you know what it means, I speak fluent Italian, a lot of German, some Spanish so I forget if all the words I use are real or something I made up.)
E
emmasj
Thanks Martin.
My gut feeling was that we'd have to carry out some form of incoming inspection.
The problem I'm running into is we have no human resource to be able to do this & our MD is extremely reluctant to employ someone to do this!
Could we inspect by supplier rather than by part unless there was a repeated problem with a specific part?
Randomly sample deliveries from each supplier each week using a common incoming audit sheet?
Emma
CarolX
Thanks Martin.
Emma
Emma -
How are your parts received right now? Does someone do a "count and condition" upon receipt? If you have no issues with parts, set-up a "dock-to-stock" program.
I work for a sheet metal fab shop (non-automotive, so I can't help you on the TS issues). Our sheet stock and our threaded inserts are inspected by the receiving person for "count and condition" only, ditto on the parts received from our platers.
Hope this helps a bit.
E
emmasj
Hi CarolX,
At the moment product documentation (box / pallet labels) is checked to ensure it corresponds with the delivery notes - part no', qty, condition.
Basically we rely on the warehouse guy's experience of knowing the parts!!
What is a 'dock to stock' system?
Emma
martin elliott
Dean
I understand the word (I mainly speak "Yorkshire") and agree with the sentiment but the point I was trying to make was there there are "shalls" here.
EMMA said she had no history (although customer complaints could be a basis) and to to justify your decision on existing suppliers, you need something.
New suppliers total agreement with your suggestion.
martin elliott
Thanks Martin.
Emma
Emma
I personnaly have no problem in just inspecting on a supplier basis rather than part basis (we do here) and set the frequency and inspection sample level on the basis of history and problems. The point I was probably making poorly is that you need to justify the levels you set.
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance standard to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
N Master Samples - What should we be keeping? IATF 16949 - Automotive Quality Systems Standard 9
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
John Broomfield Vote - Should ISO9004 Become a Requirements Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J Should Loading and Unloading be Included in Cycle Times? Lean in Manufacturing and Service Industries 14
E Manufacturers should develop a testing device for covid19 Service Industry Specific Topics 0
T 510(k) submission - Which name should I use in the submission? Other US Medical Device Regulations 3
N ISO 19011:2018 - 5.4.2 "...audit program should engage in appropriate continual development..." Training - Internal, External, Online and Distance Learning 4
M Should 510(k) Predicates be Actively Listed Devices? Other US Medical Device Regulations 12
H Who should be listed as the manufacturer/distributor on the box? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
M MDR, RED and LVD - Should our device comply with them? EU Medical Device Regulations 3
BeaBea How Many Processes should be created for each Department? Process Maps, Process Mapping and Turtle Diagrams 5
M Should volume of sales be factored into risk probability assessments? ISO 14971 - Medical Device Risk Management 33
S Should safety checks be included in the Control Plan? IATF 16949 - Automotive Quality Systems Standard 5
M Which incubation condition should be selected to recover both bacteria and fungus effectively Miscellaneous Environmental Standards and EMS Related Discussions 3
D Is there a specific location for PPE such as safety glass holders and glove dispensers should be mounted Occupational Health & Safety Management Standards 10
M Who should receive the bills from suppliers and vendors, account payable or procurement? Consultants and Consulting 4
A We are ISO 13485:2016 should we be audited to ISO 14971 ISO 13485:2016 - Medical Device Quality Management Systems 16
E Received a Major finding during IATF Surveillance audit for loss of BIQS Level 3 (more than 6 SPPS in 6 months)...how should we address SYSTEMIC CA? IATF 16949 - Automotive Quality Systems Standard 11
J Organization merger. Should we keep two separate ISO 13485 certificates? ISO 13485:2016 - Medical Device Quality Management Systems 6
S Companies that maintain your machine should be in ASL? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Use of "Shall" versus "Should" in Procedures ISO 13485:2016 - Medical Device Quality Management Systems 26
D Class II medical device - When should a complaint be closed? Customer Complaints 6
Sidney Vianna IATF 16949 News Presentations from the latest IATF Stakeholder Event - Expectation that IATF 16949 certification should equate with product quality. Misguided? IATF 16949 - Automotive Quality Systems Standard 7
Ed Panek Part 11 Self Certify Memo - What else should it cover? Qualification and Validation (including 21 CFR Part 11) 5
H Should I mention machine/Equipment password In SOP? Qualification and Validation (including 21 CFR Part 11) 4
D How long should we keep the spare parts available for our medical device, after we have stopped the production? ISO 13485:2016 - Medical Device Quality Management Systems 0
H Statistical Techniques Procedure - What should be included Document Control Systems, Procedures, Forms and Templates 4
Sidney Vianna Interesting Discussion ISO 9001:2024 - What should be changed in the next Edition of ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 113
N Should it even be on the hazard analysis (software)? FMEA and Control Plans 2
V Which batches should or could be considered for design validation and design verification? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
