Should we store Master Samples pending final approval by Customers?
O
Onk1809
Hello All
It concerns new parts. Should we create and store the master sample if the part is not finally approved and there is only a temporary approval/release?
Jen Kirley
Quality and Auditing Expert
Re: Master sample
Welcome to the Cove! :bigwave:
Yes, I would certainly identify and store the master sample pending customer approval.
TamTom
Hello All
for your own legal safety I would store this master, how will you ohterwise prove that you have produceded according to this master.
In the sense of ISo TS you have a problem if you deliver parts without the approval (but this is the normal business).
Regards,
TamTom
N
noboxwine
Yes !!!!!! :agree1:
And, perhaps for an extended amount of time, if you have the storage. I have had customers try to burn us years into a platform (usually due to new faces on the Customer end). If you can, keep these safety nets, and accompanying data, as long as possible. Have a Day ! :cool:
trainerbob
It is always a good idea to store master samples and the documentation pertaining to the same. The one thing that is constant in all of our businesses is change. Whether it be in personnel, material, machinery, customers, etc. The master samples give everybody common ground to go from if there any questions or problems later on.
P
--poy
TamTom
Common case here, too:D...but not good and may cause a big loss if qualification process is unsuccessful:confused:...
U
Umang Vidyarthi
Hello All
I find it essential to store the 'Master sample' and copy of submitted sample too, during the period of temporary approval. On getting the final approval, the 'Master Sample', as well as your counter samples must be sealed and stored much beyond the time you transact business with the perticular customer.
Not only this, I prefer to keep samples of those items also, where the customer has altered the dimensions/design after sometime. Because I have found customers to revert to the old design, there these samples come in handy. Secondly and very importantly, this helps at a time of dispute. I have won a few.
Hope it helps
Umang :D
I don't know what you mean by "copy of submitted sample" (isn't that what a "master" sample is?) and "counter samples," but here's what the 4th Edition PPAP manual says:
The organization shall retain a master sample for the same period as the [PPAP] records or a) until a new master sample is produced for the same customer part number for customer approval, or b) where a master sample is required by the design record Control Plan or inspection criteria, as a reference or standard.
The period of time required for keeping PPAP records is generally the production life of the part plus one calendar year. Thus if production of the part ceases in May of 2009, the master sample and PPAP records must be retained until the end of 2010. Individual customers may have different requirements, however. Under certain conditions the PPAP requirements allow for modifications or waivers of master sample retention.
Whether or not samples are retained beyond the mandatory time limit should be based on the potential risks of not having them. When space is limited and there are a lot of samples, there should be a process in place to periodically review them and discard ones that are no longer needed.
U
Umang Vidyarthi
'Copy of submitted samples' means some pieces from the submitted/counter samples. I retain atleast two from the lot.
PPAP gives the minmal retention period which is no bar for the maximum. One has to use his own judgement in this regard.
You have echoed my reasons for longer retention. It helps winning at the time of dispute. I wish to site one such case. One perticular filter component, for a filter for a ship engine; was discontinued after our last supply. After a couple of years we received mail from the customer slapping a penalty of 50000 Euro since one of their filter failed on the ship, resulting in engine seizure. (They in turn were slapped a penalty of one lac Euro by their customer). I asked for a piece of the failed component, which I found was not exactly matching with my (preserved & sealed) counter samples. It is a stamped part, though matching dimensionally, but having difference in contours. After a lot of hassles, I was finally able to prove that this 'failed component' was not a produce of my dies. Thanks to our policy of longer retention, we were saved from a heavy and unaffordable penalty.
At the end of the day, every one has to decide within his own limits, for what should be the max. period of retention. There is no holy-writ on this.
Umang :D
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance standard to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
N Master Samples - What should we be keeping? IATF 16949 - Automotive Quality Systems Standard 9
G Supplier delivered recent PPAP, should he deliver yearly layout inspection? IATF 16949 - Automotive Quality Systems Standard 4
John Broomfield Vote - Should ISO9004 Become a Requirements Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J Should Loading and Unloading be Included in Cycle Times? Lean in Manufacturing and Service Industries 14
E Manufacturers should develop a testing device for covid19 Service Industry Specific Topics 0
T 510(k) submission - Which name should I use in the submission? Other US Medical Device Regulations 3
N ISO 19011:2018 - 5.4.2 "...audit program should engage in appropriate continual development..." Training - Internal, External, Online and Distance Learning 4
M Should 510(k) Predicates be Actively Listed Devices? Other US Medical Device Regulations 12
H Who should be listed as the manufacturer/distributor on the box? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
M MDR, RED and LVD - Should our device comply with them? EU Medical Device Regulations 3
BeaBea How Many Processes should be created for each Department? Process Maps, Process Mapping and Turtle Diagrams 5
M Should volume of sales be factored into risk probability assessments? ISO 14971 - Medical Device Risk Management 33
S Should safety checks be included in the Control Plan? IATF 16949 - Automotive Quality Systems Standard 5
M Which incubation condition should be selected to recover both bacteria and fungus effectively Miscellaneous Environmental Standards and EMS Related Discussions 3
D Is there a specific location for PPE such as safety glass holders and glove dispensers should be mounted Occupational Health & Safety Management Standards 10
M Who should receive the bills from suppliers and vendors, account payable or procurement? Consultants and Consulting 4
A We are ISO 13485:2016 should we be audited to ISO 14971 ISO 13485:2016 - Medical Device Quality Management Systems 16
E Received a Major finding during IATF Surveillance audit for loss of BIQS Level 3 (more than 6 SPPS in 6 months)...how should we address SYSTEMIC CA? IATF 16949 - Automotive Quality Systems Standard 11
J Organization merger. Should we keep two separate ISO 13485 certificates? ISO 13485:2016 - Medical Device Quality Management Systems 6
S Companies that maintain your machine should be in ASL? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Use of "Shall" versus "Should" in Procedures ISO 13485:2016 - Medical Device Quality Management Systems 26
D Class II medical device - When should a complaint be closed? Customer Complaints 6
Sidney Vianna IATF 16949 News Presentations from the latest IATF Stakeholder Event - Expectation that IATF 16949 certification should equate with product quality. Misguided? IATF 16949 - Automotive Quality Systems Standard 7
Ed Panek Part 11 Self Certify Memo - What else should it cover? Qualification and Validation (including 21 CFR Part 11) 5
H Should I mention machine/Equipment password In SOP? Qualification and Validation (including 21 CFR Part 11) 4
D How long should we keep the spare parts available for our medical device, after we have stopped the production? ISO 13485:2016 - Medical Device Quality Management Systems 0
H Statistical Techniques Procedure - What should be included Document Control Systems, Procedures, Forms and Templates 4
Sidney Vianna Interesting Discussion ISO 9001:2024 - What should be changed in the next Edition of ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 113
N Should it even be on the hazard analysis (software)? FMEA and Control Plans 2
V Which batches should or could be considered for design validation and design verification? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
