Showing Evidence of Review and Approval of Blank Forms and Templates
Sue789
I am working for a small medical device design and manufacturer and we are a paper based company to ISO 13485 and supply the US.
What would you recommend is the best practice on how I could show that the forms and templates have been reviewed and approved?
I do not wish to control the changes via the SOP any ideas and examples welcome.
Thanks in advance.
Sue
Q
Quality_Steve
Re: Review and Approval of Blank forms and Templates
Welcome to the Cove,
To get a feel for your process, may I ask who prints the forms/templates? If printed externally, then what do they use for an original proof? If printed in-house, where is it printed from, a hard drive perhaps? Or maybe one might make copies of copies until the copy becomes unreadable and then what? :confused:
Basically what I'm saying is a proof used by your favorite printer can be controlled and a file on a hard drive can also be write protected to eliminate unauthorized changes. If your company is using the copies of copies then I don't really know what to say.
The review and approval of the forms can be another simple form stating the name of the form/template and what was changed with a signature of someone with the authority to authorize the change.
We put the revision letter and release date along with the control number on our forms but I know there are many different ways to get it right.
You may also want to check out some of the other posts on document control.
Good Luck,
Steve
yodon
Sue,
First off, check your internal SOPs (esp. doc control) to ensure that whatever you do, you'll be compliant.
One of my biggest peeves is the draconian control of forms. Some forms, like MDRs do need to be well controlled since there's so much required information. Others, like training forms, should be malleable to allow you to capture information as needed. That's just my opinion and would likely only work for small shops, as you indicate you are (it's what we do and we're also a small shop and also registered to 13485).
One of the things we've done to allow some flexibility is to snapshot the form in a WI and say that the copy in the snapshot OR SIMILAR can be used. When there is required information, we identify it (so it doesn't get tailored out - don't want too much flexibility!).
We also have a controlled area where forms are kept. If a form goes in there (through the controlled process / via restricted access), by default it has been reviewed and approved. Our procedures describe that process (along with the access restrictions). It's a read-only copy and people can pull a soft copy, fill it in, and print it.
I probably wouldn't recommend this for a larger shop but it works for us and it's been defensible to our registrar. We don't do manufacturing so we haven't been audited by the FDA.
The point is to think about what controls you really need, ensure your procedures are set up to define those controls, and the infrastructure is built to implement those controls.
Simple answer is to use a Document Control Request and have that be the vehicle for all reasons for documents, approvals, changes and subsequent removal from the system. It can be the whole lifecycle and doesn't require that stuff to be kept 'in' the document. Trust me, it works well!
ssz102
i agree with the above said
you can add review requirements on the Documents Control Procedure
Sue789
Thank you very much for your replies.
It has been several years since I have been involved in QMS documentation and my last Company was a large multinational and documents were all reviewed electronically (21 CFR 11 compliant).
I am working with a company of 13 staff whose QMS is approved to ISO 13485 and now updating the QMS for FDA 21 CFR 820 requirements.
Steve, all documents are controlled via visual source safe and are internally generated.
Andy, I had forgotten about the Doc Control Request form thanks for the reminder and this is the way I am going to go.
Sue:D
Robert Stanley I'm @ RISK of not showing my RISKS! ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
D Required Checklist Showing Compliance to IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 11
T NAFTA request for form with no part numbers showing Supply Chain Security Management Systems 0
Sidney Vianna LinkedIn bug - Anyone has any idea of how to fix this? Posts not showing for me in a Group feed. Coffee Break and Water Cooler Discussions 2
C Document Numbering Matrix showing how to number all documents by type Document Control Systems, Procedures, Forms and Templates 2
D Showing the Response Surface Experimental Point in MiniTab Using Minitab Software 5
R In 510k application do we submit documents showing compliance with 21CFRPart820 Other US Medical Device Regulations 12
L Customer Inquiry - Graph showing the expansion of oil (mm) at different temperatures Service Industry Specific Topics 5
1 Template Showing Before and After Improvement Process Quality Tools, Improvement and Analysis 8
S Control of Documents - Showing Document Changes Document Control Systems, Procedures, Forms and Templates 12
C Flow Chart showing Interaction of Core and Support Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
D Workflow showing Sequence and Interaction of Processes in a Recruitment Scenario ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
L Showing compliance to ISO9001 Clause 6.4 Work Environment - IT services company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
D Monitoring Temperature in Medication Refrigerators - What will Cpk showing us? Statistical Analysis Tools, Techniques and SPC 7
M Showing the Effectiveness of the Internal Audit Process System - AS9100B Clause 8.2.2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
RoxaneB Does anyone have a clear way of showing alignment between PDCA and ISO 14001? ISO 14001:2015 Specific Discussions 6
RoxaneB Does anyone have a clear way of showing alignment between ISO 9001 and PDCA ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D ISO 9001 tree - Diagram showing the inter-relation of all the ISO clauses ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
W Responsibility Matrix - Showing managers what their Responsibilities are Misc. Quality Assurance and Business Systems Related Topics 11
G Costs of NonConformity - A Flow Chart Showing Costs Involved Nonconformance and Corrective Action 22
Gman2 Showing competency for new hires? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Raffy Internal Auditing - Showing independence of process being audited Internal Auditing 4
D Showing Interrelationships - How Much Detail? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J TL9000 Release 2.5 and 3.0 - Mapping matrix showing the difference TL 9000 Telecommunications Standard and QuEST 4
D Calibration work instuctions - Micrometers, indicators, etc. showing the uncertainty Measurement Uncertainty (MU) 2
Marc Implementing ISO9000 - Timeline showing major milestones ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
A 8.6 Release of products and services, 8.3 Design and development - evidence required ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
C Where to draw the line for "sufficient evidence" to verify safety/performance of a device? CE Marking (Conformité Européene) / CB Scheme 2
D Device functionality over service life - Objective evidence required? Design and Development of Products and Processes 10
C MDCG 2020-06 Clinical evidence legacy devices EU Medical Device Regulations 3
Mr Roo ISO 9001 - 7.1.3 Infrastructure - questions concerning evidence ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
M Informational Critical Thinking and the Process of Evidence-Based Practice Medical Device and FDA Regulations and Standards News 0
M Informational How to perform a clinical evaluation of medical devices – Part 2 – Level of clinical evidence and what sufficient clinical evidence means Medical Device and FDA Regulations and Standards News 9
M Informational US FDA paper – Epidemiological Evidence on the Adverse Health Effects Reports in Relation to Mercury from Dental Amalgam: Systematic Literature Review Medical Device and FDA Regulations and Standards News 0
S Level of Clinical Evidence - MDR EU Medical Device Regulations 3
qualprod Evidence of a talk or phone call in approvals? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
H Clinical evidence for Class II medical devices in EU and US EU Medical Device Regulations 6
CPhelan Using clinical trial safety data for evidence for CE marking EU Medical Device Regulations 8
N Best practices for capturing audit objective evidence in a practical manner? Internal Auditing 3
M Informational Health Canada – Guidance Document: Supporting Evidence for Implantable Medical Devices Manufactured by 3D Printing Medical Device and FDA Regulations and Standards News 0
R Timeframe for IATF 16949 certification to accumulate evidence of conformance of systems? IATF 16949 - Automotive Quality Systems Standard 2
M Informational TGA – Q&A: Use of market authorisation evidence from comparable overseas regulatory bodies for medical devices Medical Device and FDA Regulations and Standards News 0
E ISO 9001:2015 Clause 10.2.2 - Evidence of all nonconformities and actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
R 8.1.3 Management of change - Evidence of HIRA and related things Occupational Health & Safety Management Standards 3
Q Evidence of precautions (clinical evaluation report, risk management report) EU Medical Device Regulations 6
S Ways to demonstrate objective evidence that employee is trained and competent ISO 13485:2016 - Medical Device Quality Management Systems 28
mikinnear Evidence - Class IIb Disinfectant Sanitiser EU Medical Device Regulations 2
G FAI Objective Evidence AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Interested parties requirements - Evidence of control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Is evidence of second party audits required for every supplier? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
