SI 5 06 - ISO/TS 169494:2002 7.4.1.2 Supplier quality management system development
Sidney Vianna
Post Responsibly
(New, adopted December 2006)
The organization shall perform supplier quality management system development with the goal of supplier conformity with this Technical Specification. Conformity with ISO 9001:2000 demonstrated by a certification by an accredited third party certification/registration body or through a second party audit process is the first step in achieving this goal.
The organization’s second party audit process shall be consistent with the automotive process approach, including evidence of planning, supplier readiness and supplier performance. (See also ISO 17021:2006), Section 9. In addition, the second party process shall be defined according to the principles detailed in the sections 5, 6, 7 of the ISO 19011:2002 regarding the management of the audit program, the audit activities and the competence of the auditors. Records of the audits reports shall be maintained.
After the initial audit, the second party surveillance audits shall be conducted at least annually.
The prioritization of suppliers for development depends upon, for example, the supplier’s quality performance and the importance of the product supplied.
The organization shall have decision criteria for determining “specially designated small suppliers” wherein certain specified elements of ISO 9001:2000 or ISO/TS 16949: 2002 may be waived. Records of the established criteria and decision taken accordingly shall be maintained. “Small” here above may refer to the volume supplied to the automotive industry or to the organization .
Refer to OEM Vehicle Manufacturer customer specifics for 2nd Party audit requirements for the organization who is a direct supplier to the OEM.
Howard Atkins
Forum Administrator
Re: Supplier Development
I have started a new thread by copying this post from Sidney Vianna.
A big thanks to Sidney who is constantly keeping us updated with the hottest news:applause: :applause:
This interpretation as I understand it changes completely the standard by adding words
SI
7.4.1.2
The organization shall perform supplier quality management system development with the goal of supplier conformity with this Technical Specification. Conformity with ISO 9001:2000 is the first step in achieving this goal.
NOTE The prioritization of suppliers for development depends upon, for example, the supplier’s quality performance and the importance of the product supplied.
Unless otherwise specified by the customer, suppliers to the organization shall be third party registered to ISO 9001:2000 by an accredited third-party certification body.
Is this because there was so many problems in companies becoming certification?
Re: SI 5 06 - ISO/TS 169494:2002 7.4.1.2 Supplier quality management system developme
Before my head explodes:
If my customer has already waived the requirement for third-party ISO9001 registration, do I need to go back and get them to waive 2nd party audits as well?
I have a dozen suppliers of custom components that I consider small. They ship me less than 1,000 parts per year that end up in an automotive application. The burden of 2nd party auditing them and generating enough records to satisfy my DNV auditor is not justified based on the quality & quantity delivered.
On the up side - lacking a customer waiver - this allows a way for people to use suppliers that will never ISO9001 register, without running afoul of 7.4.1.2.
Many of us have high quality suppliers that are small, employee-owned outfits. They deliver quality product that would shame some large ISO registered companies. They have absolutely nothing to gain by registering to ISO9001. They view the whole 3rd party registration system as so much bureaucratic silliness. In my system, moving product from them to an ISO registered supplier would cause a decrease in end product quality.
Douglas E. Purdy
Sidney or Anyone who wants to respond,
So they have done away with the Guideline in FAQs and the associated four steps. Now all we have is the "first step" as stated in this Sanctioned Interpretation. It appears to me that I do not have any direction in complying with the requirement, "The organization shall perform supplier quality management system development with the goal of supplier conformity with this Technical Specification," if my suppliers are already 3rd party registered to ISO 9001. Am I reading this correctly?
What kind of a sentence is this? So if we now have to perform 2nd party audits to comply with 7.4.1.2 we have to buy another standard in order to be compliant with TS?
Impressive!
Doug
P
ppalm
Hi
I just saw the SI 5 06 ISO/TS news on the www.iaob.org hompage and went to this wonderful forum for help.
Is this item to be considered as an update of the 7.4.1.2 requierement (valid ASAP) or is this a sugestion for the next issue of iso/ts16949?
Patrik
V
vanputten
Hello Ppalm:
An "SI" is a Sanctioned Interpretation. It is sanctioned. The IOAB would not publish it if it weren't *official.*
You may start implementing SI 5 if you would like.
Regards,
Dirk
mgoward
Have I got the understanding of this correctly
:bonk:
We can now have a criteria for determining "special designated small suppliers" which will waive the requirement for them to be ISO 9000:2000 certified as a minimum.
If this is the case do we still need to obtain a customer approval / wavier to use these suppliers, and do we need to anually audit them.
:confused: :confused: :confused:
Douglas E. Purdy
:bonk:
This is my take on the matter.
If the supplier is not 3rd party registered to ISO 9001, then you have to perform the 2nd party audits. The 'special designated small suppliers' who are not 3rd party registered will be 2nd party audited to the TS Standard but not to those criteria for which you have given them exclusions to. I presume that the exclusions can only be in Product realization.
The organization shall have decision criteria for determining “specially designated small suppliers” wherein certain specified elements of ISO 9001:2000 or ISO/TS 16949: 2002 may be waived. Records of the established criteria and decision taken accordingly shall be maintained. “Small” here above may refer to the volume supplied to the automotive industry or to the organization.
At least that is my take on the matter.
Doug
Andrews
It is clear from the SI that second party audits can be done on suppliers who have not got certified to ISO9001-2000. But there are some questions
a) Should the second party audits be done against ISO9001 or TS standard?
b) What happens to the non-conformities? Can we use same procedure as been followed for internal audits?
c) What is the time frame for closing these NC's?
d) Is prioritisation applicable for second party audits also?
e) For specialy designated small suppliers, what are the clauses or elements where waiver can be given?
f) Does this SI supercede or cancel the requirement of 7.4.1.2 where it says "unless otherwise specified by customer, suppliers of the organisation shall be third party registered to ISO9001-2000 by an accredited third party certification body".
Thanks,
Andy
A ISO 20417:2021 Country of Manufacture Medical Device and FDA Regulations and Standards News 0
D ISO 26262 functional safety : how to get started Other ISO and International Standards and European Regulations 2
E Any template/ form of Monitoring and Measurement of Processes and product to ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 1
S IATF 16949 - Summary at a glance Clause wise - changes from ISO TS IATF 16949 - Automotive Quality Systems Standard 4
N ISO 22716 - GMP Training for GMP trainer Other ISO and International Standards and European Regulations 2
H ISO 13485-paragraphs for a SaaS SAMD needed or not? ISO 13485:2016 - Medical Device Quality Management Systems 2
M ISO 12944 Understanding the thickness guidlines Oil and Gas Industry Standards and Regulations 0
A Anxiety - ISO Re-registration Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 66
M Does the scope of ISO 9001:2015 applies to tenders, pricing and sales department of a medical devices distributor? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
P ISO 20400:2017 Sustainable Procurement Implementation Sustainability, Green Initiatives and Ecology 0
R ISO 27001 implementation IEC 27001 - Information Security Management Systems (ISMS) 3
D Can an ISO 9001 Certificate have Remote Locations? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
W What is okay to use as a reference material for ISO 17025? ISO 17025 related Discussions 2
R ISO 14971 not harmonized ISO 14971 - Medical Device Risk Management 4
A ISO 14001:2015 clause 4.4 ISO 14001:2015 Specific Discussions 2
A Internal audit plan and processes for ISO 14001:2015 ISO 14001:2015 Specific Discussions 3
Moncia Implementing ISO 50001 Sustainability, Green Initiatives and Ecology 17
D Question on using audit checklist ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 17
C ISO 80601-2-56 Laboratory accuracy Other Medical Device Related Standards 7
D ISO 9001 - 8.4.1 Evaluate All Suppliers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 66
M Looking for a copy of ISO 10651 Hospitals, Clinics & other Health Care Providers 6
M ISO 13485 and document control for programs ISO 13485:2016 - Medical Device Quality Management Systems 6
Sidney Vianna ISO 9001 News ISO 9001 Quality Check - spinning facts in LinkedIn ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
AllTheThings ISO-17025 accredited TEST lab performing internal calibrations (Yes: Here is how) ISO 17025 related Discussions 6
P Filled in F48/F49 for internal audit ISO 17025:2017 Internal Auditing 1
A ISO 9001 Internal Audits - No production right now due to furloughs Internal Auditing 5
D Question on Documented Calibration versus ISO 17025 Accredited Calibration ISO 13485:2016 - Medical Device Quality Management Systems 2
M Customer Property - ISO 13485:2016 Clause 7.5.10 ISO 13485:2016 - Medical Device Quality Management Systems 9
pbojsen ISO 13485 Requirements versus FDA product classification and GMP exemptions - Audits ISO 13485:2016 - Medical Device Quality Management Systems 3
D "certified" in ISO 19011, as well as IATF required? IATF 16949 - Automotive Quality Systems Standard 6
S ISO/IEC 15408 - Is this is Certifiable Standard? Other ISO and International Standards and European Regulations 2
D Lead time to schedule an ISO 13485 audit General Auditing Discussions 2
T Do we need an SOP for ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
K ISO 9001 Auditing in a Healthcare setting Process Audits and Layered Process Audits 15
S Does anyone have a checklist to prepare for ISO 13485, Stage I audit? ISO 13485:2016 - Medical Device Quality Management Systems 1
H QMS ISO 13485:2016 - ISO14971 IEC60304 etc ISO 13485:2016 - Medical Device Quality Management Systems 6
Y How can i integrate ISO 13845 into ISO 27001? ISO 13485:2016 - Medical Device Quality Management Systems 4
vickyva ISO 14155:2020 CIP CIR templates Other Medical Device Related Standards 0
C ISO 9001:2015 8.3.2. h) Design and Development Planning - What is required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Employee Handbook in ISO 9001:2015 Section 7 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
B Operational Procedures for ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 7
Q ISO 9001/IATF 16949 Audit Finding Question - Document Retention IATF 16949 - Automotive Quality Systems Standard 11
D ISO 14971 applicability in ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 7
G Trying to get a financially reasonable ISO Certification Body Registrars and Notified Bodies 8
L ISO 45001:2018 - Clause 5.4: Consultation and Participation of Workers Process Maps, Process Mapping and Turtle Diagrams 1
E ISO 13485 in Clinical Trial conduct: Applicable or No ISO 13485:2016 - Medical Device Quality Management Systems 2
G ISO 13485 Certification - Can we get the ISO 13485 certification prior to shipment of the device? ISO 13485:2016 - Medical Device Quality Management Systems 6
Richard Regalado Informational ISO/IEC DIS 27001:2021, to be published soon. IEC 27001 - Information Security Management Systems (ISMS) 0
Q Audit report template ISO 9001/14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
N Does anyone use SGS for ISO 13485 / CE certification Registrars and Notified Bodies 0
