Re: SI 5 06 - ISO/TS 169494:2002 7.4.1.2 Supplier quality management system developme
I have not seen ISO 17021 - Section 9. Does it answer any of your questions?
Here would be my take on some of your questions:
A) I would say that 7.4.1.2 would have you performing audits to ISO/TS 16949. Remember that conformity to ISO 9001 is the first step. That is stated in both the Clause and the SI.
B) & C) The Audit System you create for the 2nd party audit would say what to do with the nonconformities and any time frame you establish.
D) I would say that the prioritization goes for all suppliers who are not 3rd party registered.
E) I would say that within the scope of ISO 9001 and ISO/TS 16949 that exceptions or exclusions would only be in Product Realization.
F) I wasn't going to tackle this one, but here is my take: the SI gives the option for a second party audit process. So unless specified by your customers, your suppliers do not have to be 3rd party registered to ISO 9001. You can establish and implement a Second Party Audit system instead. If the supplier is not a 'specially designated small supplier' then your audit system is to bring the supplier to conformity with TS. While you can determine which requirements can be made an exception or excluded for those 'specially designated small suppliers.'
Just my take on the matter,
Doug
It is clear from the SI that second party audits can be done on suppliers who have not got certified to ISO9001-2000. But there are some questions
a) Should the second party audits be done against ISO9001 or TS standard?
b) What happens to the non-conformities? Can we use same procedure as been followed for internal audits?
c) What is the time frame for closing these NC's?
d) Is prioritisation applicable for second party audits also?
e) For specialy designated small suppliers, what are the clauses or elements where waiver can be given?
f) Does this SI supercede or cancel the requirement of 7.4.1.2 where it says "unless otherwise specified by customer, suppliers of the organisation shall be third party registered to ISO9001-2000 by an accredited third party certification body".
Thanks,
Andy
Thanks,
Andy
Doug
