SI #7 8.4.2.1 Type and extent of control_supplemental
maggylu168
IATF added the below requirements in this clause. I am not quite sure about the meaning. Could someone guide me when and how to have such kind of controls? Why IATF added this new requirement through SI? Explicating through examples will be appreciated.
Where characteristics or components "pass through" the organization's quality management system without validation or controls, the organization shall ensure that the appropriate controls are in place at the point of manufacture.
Sebastian
Construction of front suspension top mount includes bearing.
Internal diameter of inner ring is (shall be) one of special characteristics, as it fits to piston rod of shock absorber.
Bearing is manufactured by external supplier therefore control over this characteristic is not covered by organizational control plan.
Organization is not going to perform receiving inspection through measurement of certain product characteristics of bearings received from supplier.
So part of organizational control process over external sources shall be activity, which shall ensure that e.g.:
- this characteristic was selected by supplier as special one,
- control over this characteristic is included in supplier control plan,
- capability is analyzed and monitored for this characteristic,
- alternative to measurement, methods of receiving inspection selected by organization include this characteristic, e.g. supplier certificate attached to each delivery presenting measurement results,
- one of focus points of organizational 2nd party audits performed in bearing supplier premises is control of this characteristic.
Alternative way is.
Organization includes this characteristic as one of final inspection items, then it seems that it does not applies, but..
Let see results of risk analysis for this component/supplier and watch future claim if there is no case related to this characteristic.
Because after all, organizational inspection does not ensure quality of received components.
Supplier (manufacturer) control does.
maggylu168
Alternative way is.
Thank you, Sebastian, for your clear explanation. It looks like such characteristics is connecting between customers' manufacturing process and organizations' components. As a second-tier supplier in automotive chain, it's not easier to know the customers' further assembly unless they want to share or identify this kind of characteristics. How come the clause asks organizations to define and control them? Usually the validation should be done and qualified during APQP process at customers' side; all organization can do is control the component itself on dimensions and functions.
BTW, what is so-called "pass through"? Does it mean no inspecting or testing? I am curious if this is talking about products like fireworks or airbags?
Sebastian
"Pass through" means, that organization has no intention to alter properties of product characteristic originated from its supplier process, during own manufacturing process until delivery to customer. I gave example of bearing inner diameter.
Cascading knowledge, related to manufactured product purpose, within supply chain is a one of biggest problem in automotive industry. Even within one organization it is hard, but all say about "lessons learned" and "protection of know how".
A IATF Sanctioned Interpretation No. 7 - Type and Extent of Control (supplemental) IATF 16949 - Automotive Quality Systems Standard 4
I AS9100 8.4.2 Type and Extent of Control - External provider test reports Manufacturing and Related Processes 24
B Documented process for type and extent of control IATF 16949 - Automotive Quality Systems Standard 6
S Complying with IATF 16949 Cl. 8.4.2.1 - Type and extent of control IATF 16949 - Automotive Quality Systems Standard 1
M TS 16949 Cause 7.4.1: Type of Control vs. Extent of Control (Definitions) IATF 16949 - Automotive Quality Systems Standard 5
R 820.50 (A) (2)Define the Type and Extent of Control to be exercised over Vendor Misc. Quality Assurance and Business Systems Related Topics 5
Sidney Vianna Outsourced Processes - Type and Extent of Control to be Applied - ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 40
E IATF 16949 Cl. 8.4.2.5 - Supplier Development Type and Extent IATF 16949 - Automotive Quality Systems Standard 2
Jane's Like-for-like critical raw material change qualification - type of testing/ number of lots required ISO 13485:2016 - Medical Device Quality Management Systems 1
N Infant radiant warmer - Heater Quartz Element type Other Medical Device Related Standards 0
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
K Validation of new machine (second machine of the same type) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
F Operator Manual and Type B Uncertainty Measurement Uncertainty (MU) 3
B F-type applied part - Separation from ALL(?) other parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
K F-TYPE APPLIED PART IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
F Determining what type of scrap to include in my internal PPM calculation Quality Manager and Management Related Issues 5
R In this type of Legal Manufacturer-CMO arrangement, what happens to the DHR? ISO 13485:2016 - Medical Device Quality Management Systems 1
J AQL for Effectiveness Check - What AQL tiers to use on this type of sampling? Nonconformance and Corrective Action 9
T Type BF or CF (Direct conductive contact with the heart) IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
G MSA Type 1 - Cg and Cgk ranges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P IVDD - IFU related requirements - Type of information/statement expected EU Medical Device Regulations 1
P Definition Business Type - Definition of what we do-Business Type Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
L Valid reasons to omit an "ear-tag" type label on a cable? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
P 2x MOOP for type B AP - Therapeutic device - Heater/cooler with pump IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
P DMF (Drug Master File) type V for Sterilization Processes for USFDA Submission Other US Medical Device Regulations 3
F IATF 16949 - Cl. 8.4.2.3 - Which type of suppliers could be exempt of ISO 9001 IATF 16949 - Automotive Quality Systems Standard 16
S Number of MOPP for Type BF Applied Part (Medical Device Electronics) IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M For a Type 1 Gage R&R I want to use 1 unit and measure it 30 times Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Test Specifications based on Vehicle Type Various Other Specifications, Standards, and related Requirements 0
N Recommendation of Supplier Program type Training Training - Internal, External, Online and Distance Learning 4
Q CE Mark Requirements for Components - Solenoid Actuator Type Devices CE Marking (Conformité Européene) / CB Scheme 3
W Using MPE (Mean Percentage Error) for Linearity and Type-1 study Measurement Uncertainty (MU) 1
P EASA STC (Supplemental Type Certificate) on a Pre-mod FAA STC Configuration EASA and JAA Aviation Standards and Requirements 1
R Supplier data record in adequate media type Supplier Quality Assurance and other Supplier Issues 11
A Type of evidence for Mandatory procedures 4.4.2 A ad 8.5.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Best Type of Grease for Vex Plastic Gears Manufacturing and Related Processes 5
C Document Numbering Matrix showing how to number all documents by type Document Control Systems, Procedures, Forms and Templates 2
insect warfare Cannot determine what type of medical device this product is.... 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S Family / Generic type of FMEA & Control Plan and Symbols FMEA and Control Plans 3
S Cost of DMF Type III preparation and submission Other US Medical Device Regulations 1
G Interpreting Type 1 MSA (Measurement Systems Analysis) Results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
S Is TGA approval required for a ARTG listed IVD for a sample type addition? Other Medical Device Regulations World-Wide 11
R Variables Data Type Analysis help Quality Tools, Improvement and Analysis 4
Crusader Service-Type Supplier Evaluation Exclusion? Supplier Quality Assurance and other Supplier Issues 12
K Document Control - Type-able Forms vs. Ink Quality Manager and Management Related Issues 10
F Looking for some type of training on Lean Manufacturing video or web training Lean in Manufacturing and Service Industries 7
P OBL (Own Brand Label) - Annex III ? EC Type Examination EU Medical Device Regulations 2
