Significant Aspects required by Auditor for Water and Energy
abhaygirish
#11
Re: Significant Aspect
If you cannot reduce actual water consumption, you can propose the metrics as, say, water consumption per piece of product or related to turnover or... just think about something reasonable.
Yes we calculated water consumption / kg but that also remain static one.
Actually I want put one more question ...
When mgt desire to launch any new poduct that time in validation itself we got clearcut idea ( about exact Quantity) about Hazardous waste. and same information we furnish to Pollution Contol Board .
Now my query is how auditor ( from Reputed cert.body ) can remark that production function to look for reduction in haz waste by taking objective.
Reards
Abhaygirish:confused:
Randy
#12
Here's a different take on your question...It's not any of the auditors business what you identify as significant or how you do so and the absolutley have no right telling you what is or is not significant....The auditors have gone way out of bounds and have crossed the line if what you are saying is in fact what happened. If an auditor on my team had said that there would be a severe closed door discussion with him/her and I would ask you to please excuse the comment.
#13
Randy is absolutely right in pointing out that the situation you presented is an example of an auditor acting like a "consultant" during the audit process; in the context of an ISO-14001 audit the auditor is not supposed to suggest improvements. Once I got a "minor" non-conformance from the Accreditation Witness Auditor (RvA) for suggesting an improvement option to an auditee.
#14
:agree:
I concur.. I could argue that both water and electricity are aspects, but the decision of whether they are significant, and what (if anything) is to be done with them is up to the company. The only other possible factor could be whether the usage of water or electricity somehow related to a legal or other requirement, but even then, that would not necessarily mean they were significant.
samsung
#15
But auditors are insisting that both are sig.aspect & we should take objective on it . kINDLY GUIDE
-Abhaygiish
This is possible only when you yourself have determined your aspect as being 'significant' based on your own criteria, else the auditor, as Randy very correctly said "It's not any of the auditors business what you identify as significant or how you do so and the absolutely have no right telling you what is or is not significant...."
Please revisit your aspect identification sheet and see how (on what criterion) you have determined the significance level of your aspects. Please tell more of the yardstick you used to rate the aspects.
Paul Simpson
#17
OK, Randy. We've disagreed on this in the past but I'll state my case again - exaggerated for effect!
If you operate a nuclear power plant and as a consequence generate radiation and nuclear waste you cannot state that these impacts are not significant.
This is blindingly obvious to the man / woman in the street so shouldn't escape the attention of a trained auditor. :notme:
I've been here. I audited a multi site automotive company making product with very little waste. Their real environmental impact was with the transport of these components around Europe and North Africa but it wasn't acknowledged ... guess what - nonconformity.
I accept it is not the auditor's position to define significance but if an organization has missed it then they should raise it as a finding.
All of the other stuff in my earlier post about 'you can only do what you can do' still applies!
samsung
#18
I'll revert with criteria for sig. & non sig.
The standard is very clear when it defines the requirements for identifying environment aspects.
1. that you need to identify the env. aspects of those activities that a) you can control and b) that you can influence
2. that you also need to determine how your legal requirements apply to the identified aspects (you cannot skip identifying an aspect if it's related to one of your legal requirements)
3. that the Significant environmental aspects are those which can have significant impacts on the environment.
4. that you shall take into account (consider) the significant aspects while setting objectives (it doesn't imply that you necessarily set an objective for each of the SA you determined)
Now, it's one thing for an aspect to be 'significant' (on whatever grounds) and quite another to be 'within or out of control'. So in your case, if the consumption of water and electricity is 'within control', i.e. within the specs (either defined by you or by any of the interested parties including a regulatory body), then an auditor has no business to ask why you haven't set an objective to control or reduce it. No need to set an objective since it's already 'in control' (if it's so, based on your budgetary/regulatory norms) and also if it's consistent with your environmental policy.
abhaygirish
#19
Thanx.... But still confusion is there.
Pls bare my queries...
If my process is validated .... Water is in control ... Energy is in control .. at R&D stage (validation ) poduct life cycle study conducted ... qty of waste defined (solid , liq. gas ) we already done EIA for inclusion of products in PCB' s Consent , still auditors are saying that " we should take improvement project/objective " to reduce haz waste qty , discharge of effluent "
REGARDS
ABHAY
Jen Kirley
Quality and Auditing Expert
#20
Fresh water and energy are becoming more important as resources all the time, and interestingly fresh water may overtake the criticality of energy within the next generation or two.
Some add improvements to effluents by using "gray water" (from bathroom sinks, for example) for landscaping. Some Middle Eastern municipalities are directing sea water for flushing commodes.
But these arrangements involve infrastructure changes, which may not be worthwhile to you. The auditor is asking that you consider all the aspects because so many forget about aspects in administrative functional areas. I agree the auditor is wrong to demand specifics, but I think it's okay to keep expanding the scope of what the program can address. As time goes by, technology changes and more options become available to us.
So you've done that. You examined your processes and decided you can't conserve anymore. Fine. Then the objective can be, for example, "to maintain current optimum consumption levels per employee/sales/etc."
:2cents:
G Supplier Significant Environmental Aspects - Audit Finding ISO 14001:2015 Specific Discussions 21
S Format for Significant Environmental Aspects Study ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Auto Parts Warehousing Facility ISO 14001 Significant Aspects ISO 14001:2015 Specific Discussions 23
R ISO is certified to ISO 14001:2004 - What are their Significant Environmental Aspects ISO 14001:2015 Specific Discussions 2
S Static Significant Environmental Aspects (ISO 14001 Aspects and Impacts) ISO 14001:2015 Specific Discussions 5
A "Significant Environmental Aspects" Definition Miscellaneous Environmental Standards and EMS Related Discussions 2
O Communicate externally about significant environmental aspects - Clause 4.4.3 Miscellaneous Environmental Standards and EMS Related Discussions 6
A Initial condition for establishing significant environmental aspects Miscellaneous Environmental Standards and EMS Related Discussions 1
F The Number of Significant Environmental Aspects and Environmental Goals Miscellaneous Environmental Standards and EMS Related Discussions 5
L External Communication of Significant Environmental Aspects - Clause 4.4.3 Miscellaneous Environmental Standards and EMS Related Discussions 3
L Do we need to have a Significant Aspect? ISO 14001 Aspects and Impacts ISO 14001:2015 Specific Discussions 4
I Significant Aspects and Impacts for Manufacturing of Pharmaceutical Products Miscellaneous Environmental Standards and EMS Related Discussions 3
Y Significant environmental aspects for rubber printer roller production process Miscellaneous Environmental Standards and EMS Related Discussions 30
Sidney Vianna Informational Companies with No SIGNIFICANT Environmental Aspects - ISO 14001 ISO 14001:2015 Specific Discussions 127
K Discussion: Significant Aspects (Clause 4.3.1), Operational Controls (Clause 4.4.6) Miscellaneous Environmental Standards and EMS Related Discussions 8
U Power supply - Change From 160 to 300 Watts - Significant change? EU Medical Device Regulations 2
J Significant change related to design and intended use EU Medical Device Regulations 3
L Significant Production Run - How 300 was determined to be the minimum quantity APQP and PPAP 2
K Is a change that fixes a recalled device significant? Medical Device and FDA Regulations and Standards News 2
L Significant change notice for outsourced warehouse Medical Device and FDA Regulations and Standards News 2
qualprod The Perfect audit? External Audit causes a significant negative impact in a company General Auditing Discussions 9
Ed Panek Is Shelf Life Change a significant change? CE Marking CE Marking (Conformité Européene) / CB Scheme 7
K Interpretation of significant change - material change Canada Medical Device Regulations 3
R How long to wait for Notified Body Response - Potentially significant change to a medical device CE Marking (Conformité Européene) / CB Scheme 6
shimonv Non-significant notice of change to notified body EU Medical Device Regulations 4
C Suppliers re-classification from Critical to Significant or from Significant to Non-critical Supply Chain Security Management Systems 0
C Significant Organizational Changes - Documented Responsibilities Document Control Systems, Procedures, Forms and Templates 4
C EPA NPDES VISUAL ASSESSMENT - No Significant Storm Event ISO 14001:2015 Specific Discussions 0
M Notifying Registrar of Significant QMS changes ISO 13485:2016 - Medical Device Quality Management Systems 2
J Applying for 510K - What is a significant process change and what is not US Food and Drug Administration (FDA) 5
V Screening DOE with 7 Input factors and 4 responses - Significant factors Using Minitab Software 1
shimonv FDA released final guidance documents on what constitutes a significant change Other US Medical Device Regulations 2
R AS9100D Cl. 8.4.2 - Identify Raw Material as a Significant Operational Risk AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
G Sample Size, Significant Figures, Scale General Measurement Device and Calibration Topics 3
I Catch up 510(k) - Non-significant changes were made Other US Medical Device Regulations 1
M DOE: Significant factor or not Using Minitab Software 2
K Plastic Resin designated as Significant Characteristic Manufacturing and Related Processes 7
A Significant Figures and Rounding SOP Document Control Systems, Procedures, Forms and Templates 4
E FDA Significant Change Interpretation - Guidance Document EU Medical Device Regulations 2
somashekar Industry examples of Significant Beneficial Environmental Impacts Miscellaneous Environmental Standards and EMS Related Discussions 3
Q Reporting Significant Medical Device Changes to Argentina's ANMAT Other Medical Device Regulations World-Wide 3
R 4 Factors 3 Level DOE to determine which factors are significant Using Minitab Software 2
5 Number of 'significant digits' in measurements Inspection, Prints (Drawings), Testing, Sampling and Related Topics 31
S Managing a Significant Number of Outstanding Non-Conformities Nonconformance and Corrective Action 6
E Significant Change and Guidance Documents for Medical Devices Other Medical Device Regulations World-Wide 6
E What's the difference: AIAG-PPAP's "Significant Production Run" and "Run @ Rate"? APQP and PPAP 11
T Health Canada Class III/IV "Significant Change" guidance interpretation Canada Medical Device Regulations 2
D Best Minitab Tool to determine a Statistically Significant Trend Using Minitab Software 5
C Significant changes between EN80079-34 and EN 13980:2002 which it replaces Manufacturing and Related Processes 7
K I've had a significant win with Safety Policy Occupational Health & Safety Management Standards 12
