Significant change related to design and intended use
MDCG 2020-3 notes: If a change is not a significant change in design or intended purpose under MDR Article 120(3), the implementation of such a change is therefore allowed during the transitional period. Acc. to section 3 the certificate should not be amended.
According to this sentence, non-significant change is only allowed before DOA(2021/5/26).
Can MDD complaint device make significant change after DOA and prior to 2024/5/26 ?
twanmul
Any device products certified under the relevant directive that continue to be manufactured utilising transitional arrangements as listed within Article 120 of Regulation 2017/745 or Article 110 of Regulation 2017/746 from the respective date of application cannot have any change to the design of that device.
This means, from the date of application, no changes can be made to the device design. If you want to make changes, then you will need conformity assessment as per the appropriate regulation.
So,
1. MDCG 2020-3 only apply prior to each DOA of regulations?
2. in addition to design change, is any other change allowed after DOA, such as manufacturing process change, administrative change and so on?
fialor
The text of MDCG 2020-03 does indicate that the changes considered non-significant can be made. This will invariably be down to the interpretation by your NB. I would recommend you ensure you know the guidance document inside out so that you have a productive discussion with your NB when required.
U Power supply - Change From 160 to 300 Watts - Significant change? EU Medical Device Regulations 2
K Is a change that fixes a recalled device significant? Medical Device and FDA Regulations and Standards News 2
L Significant change notice for outsourced warehouse Medical Device and FDA Regulations and Standards News 2
Ed Panek Is Shelf Life Change a significant change? CE Marking CE Marking (Conformité Européene) / CB Scheme 7
K Interpretation of significant change - material change Canada Medical Device Regulations 3
R How long to wait for Notified Body Response - Potentially significant change to a medical device CE Marking (Conformité Européene) / CB Scheme 6
shimonv Non-significant notice of change to notified body EU Medical Device Regulations 4
J Applying for 510K - What is a significant process change and what is not US Food and Drug Administration (FDA) 5
shimonv FDA released final guidance documents on what constitutes a significant change Other US Medical Device Regulations 2
E FDA Significant Change Interpretation - Guidance Document EU Medical Device Regulations 2
E Significant Change and Guidance Documents for Medical Devices Other Medical Device Regulations World-Wide 6
T Health Canada Class III/IV "Significant Change" guidance interpretation Canada Medical Device Regulations 2
C How to Quantify Significant Change for a Shelf Life Stability Test Other Medical Device Related Standards 15
B Example of Production Process Change having Significant Consequences AS9100C 7.5.1.2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
C Does a "Significant Change" apply to Class II Medical Devices? Canada Medical Device Regulations 8
O What is your interpretation of a Significant Method Change Manufacturing and Related Processes 7
E Differences between "Significant Change" determination - Canada vs. FDA Canada Medical Device Regulations 3
S Medical Device Subcontractor Significant Change EU Medical Device Regulations 9
Le Chiffre Is a written procedure required for handling significant change? ISO 13485:2016 - Medical Device Quality Management Systems 7
D What constitutes a "significant change" in software AND what does not Software Quality Assurance 7
J TL 9000 - Element 4.9 Significant Change TL 9000 Telecommunications Standard and QuEST 6
L Significant Production Run - How 300 was determined to be the minimum quantity APQP and PPAP 2
qualprod The Perfect audit? External Audit causes a significant negative impact in a company General Auditing Discussions 9
C Suppliers re-classification from Critical to Significant or from Significant to Non-critical Supply Chain Security Management Systems 0
C Significant Organizational Changes - Documented Responsibilities Document Control Systems, Procedures, Forms and Templates 4
C EPA NPDES VISUAL ASSESSMENT - No Significant Storm Event ISO 14001:2015 Specific Discussions 0
M Notifying Registrar of Significant QMS changes ISO 13485:2016 - Medical Device Quality Management Systems 2
V Screening DOE with 7 Input factors and 4 responses - Significant factors Using Minitab Software 1
R AS9100D Cl. 8.4.2 - Identify Raw Material as a Significant Operational Risk AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
G Sample Size, Significant Figures, Scale General Measurement Device and Calibration Topics 3
I Catch up 510(k) - Non-significant changes were made Other US Medical Device Regulations 1
M DOE: Significant factor or not Using Minitab Software 2
K Plastic Resin designated as Significant Characteristic Manufacturing and Related Processes 7
G Supplier Significant Environmental Aspects - Audit Finding ISO 14001:2015 Specific Discussions 21
A Significant Figures and Rounding SOP Document Control Systems, Procedures, Forms and Templates 4
somashekar Industry examples of Significant Beneficial Environmental Impacts Miscellaneous Environmental Standards and EMS Related Discussions 3
Q Reporting Significant Medical Device Changes to Argentina's ANMAT Other Medical Device Regulations World-Wide 3
S Format for Significant Environmental Aspects Study ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Auto Parts Warehousing Facility ISO 14001 Significant Aspects ISO 14001:2015 Specific Discussions 23
R 4 Factors 3 Level DOE to determine which factors are significant Using Minitab Software 2
5 Number of 'significant digits' in measurements Inspection, Prints (Drawings), Testing, Sampling and Related Topics 31
R ISO is certified to ISO 14001:2004 - What are their Significant Environmental Aspects ISO 14001:2015 Specific Discussions 2
S Managing a Significant Number of Outstanding Non-Conformities Nonconformance and Corrective Action 6
E What's the difference: AIAG-PPAP's "Significant Production Run" and "Run @ Rate"? APQP and PPAP 11
D Best Minitab Tool to determine a Statistically Significant Trend Using Minitab Software 5
C Significant changes between EN80079-34 and EN 13980:2002 which it replaces Manufacturing and Related Processes 7
K I've had a significant win with Safety Policy Occupational Health & Safety Management Standards 12
J Ford changing their acronym for Significant Characteristics from HIC to CTQ Customer and Company Specific Requirements 2
M Significant FDA Medical Device Marketing Shift... 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
R Definition Significant Event definition - 8.2.3.1 - Monitoring & Measurement of MFG Processes Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
