Significant Characteristics (SC) to Control Plan
Johnnymo62
Haste Makes Waste
#32
Greetings. I work with industrial, automotive and military customers. We do capability studies of all dimensions at first run. If a dimension isn't capable we make it a Significant Characteristic and put appropriate controls in place. So, it is added to the FC/PFMEA/CP even if the drawing dosn't specify it to be a special characteristic.
I haven't found this requirement in anything but CSRs.
#33
If you do capability studies on all dimensions, you sure aren't working with something like castings, where there can be hundreds of dimensions. I think also that you might have the cart before the horse here. In general, dimensions don't become "significant" after discovering lack of capability in meeting the requirement. Special characteristics are almost always related to either safety or function in an assembly. In those cases, especially in automotive work, if you can't demonstrate capability you're looking at 100% inspection.
#34
True there are many characteristics that are so unimportant that they can be 100% out of spec and it would make no difference in fit, function or reliability.
#35
Another thing to consider is that when you add a feature/dimension to the control plan, it can trigger other requirements such as MSA.
toniriazor
#37
Hello Elsmar Team
I am dealing with one business unit that want our plant to perform capability study on wiring harness branch dimensions - that means all dimenstion from retainer to connectors, retainers to take outs, connector to take outs shown on the drawing and etc., which on a handmade product build on assembly boards will bring up huge variation in the process. While the data is variable I really think this study will bring 0 value add and will not help to improve the process since measurements normally vary quite a lot, although are in their LSL / USL. What do you think, does it even make sense to do that and has anyone ever performed such study ? Also I came across an information that capability study normally should be done on independent process variables (i.e., unaffected by other characteristics or operations) and in such case isn't it that all dimensions at the end would be affected by previous operations such as wire cutting, tube cutting, taping over the branches and etc. What do you think or that just doesn't make sense :) ?
the particular BU wants to capture this requirement in SCCAF as well in the form of an SC and for a characteristic rated as SC we should do the capability according customer requirements.
I kind of need a good advice how to approach this situation, because never been asked before to do that for wire branch/bundle dimensions as described above.
thanks in advance for your thoughts
#38
Aside from the fact that Cpk and Ppk indexes are useless a real capability study can be quite useful. While you might think that there is a "lot of variation" because it's a manual process but everything is always in spec, it would be beneficial to PROVE IT with the data - or discover that the manual process is not capable and you can improve it before Customers get failures. My crap detector goes up pretty fast when a supplier tries to tell me that a real capability study has no value. my advice is to do the study and then you will have the answer - debating science never works, but showing the data does.
I can't speak to the validity of these dimensions being critical characteristics...
#39
I agree with Bev's comments that you really need to understand the variations in the output of your process, and a capability study is the way to do this. Your question (quoted above) really points to the best way to control the process, which is to go upstream to the process inputs (wire cutting, tube cutting, etc.) and control those. Controlling the inputs is the best way to control the output.
#40
I don't know where you read about not doing capability studies on 'dependent variables' or outputs. that simply isn't true. at all. In fact capability studies are specifically designed for output characteristics (dependent variables). There are two reasons for this:
(1) the goal of any process is that the output characteristics meet the specification requirements. If you don't have a well characterized process (inputs to outputs) then you can have all of the inputs demonstrating 'capability' yet still making out of spec parts.
(2) there are a whole bunch inputs that might matter. there is a whole of work to perform capability studies on the inputs in comparison to the relatively few outputs. and then of course often the critical input parameter may not even be known (see 1).
IF the output is not capable then you start diagnosing which input(s) form the causal mechanism.
R Criteria for defining FMEA & Control Plan Critical and Significant Characteristics FMEA and Control Plans 10
D Significant & Critical Characteristics Control Plan - Automotive Metal Stampings FMEA and Control Plans 5
L Gage R&R studies and control plan for PPAP - Critical or Significant characteristics? APQP and PPAP 16
J Ford changing their acronym for Significant Characteristics from HIC to CTQ Customer and Company Specific Requirements 2
M Critical / Key / Significant Characteristics - Special Characteristics Classification FMEA and Control Plans 1
A SC: Significant Characteristics vs. Special Characteristics IATF 16949 - Automotive Quality Systems Standard 4
D AIAG Level 3 PPAP (100% dimensional measurement or just significant characteristics)? APQP and PPAP 2
M Critical or Significant Characteristics or Key Indicators Ranking FMEA and Control Plans 7
J APQP - List of SKPC's (significant key product characteristics) Required? APQP and PPAP 1
W Should we monitor all Significant part Characteristics with SPC? Low Volume CNC Statistical Analysis Tools, Techniques and SPC 15
U Power supply - Change From 160 to 300 Watts - Significant change? EU Medical Device Regulations 2
J Significant change related to design and intended use EU Medical Device Regulations 3
L Significant Production Run - How 300 was determined to be the minimum quantity APQP and PPAP 2
K Is a change that fixes a recalled device significant? Medical Device and FDA Regulations and Standards News 2
L Significant change notice for outsourced warehouse Medical Device and FDA Regulations and Standards News 2
qualprod The Perfect audit? External Audit causes a significant negative impact in a company General Auditing Discussions 9
Ed Panek Is Shelf Life Change a significant change? CE Marking CE Marking (Conformité Européene) / CB Scheme 7
K Interpretation of significant change - material change Canada Medical Device Regulations 3
R How long to wait for Notified Body Response - Potentially significant change to a medical device CE Marking (Conformité Européene) / CB Scheme 6
shimonv Non-significant notice of change to notified body EU Medical Device Regulations 4
C Suppliers re-classification from Critical to Significant or from Significant to Non-critical Supply Chain Security Management Systems 0
C Significant Organizational Changes - Documented Responsibilities Document Control Systems, Procedures, Forms and Templates 4
C EPA NPDES VISUAL ASSESSMENT - No Significant Storm Event ISO 14001:2015 Specific Discussions 0
M Notifying Registrar of Significant QMS changes ISO 13485:2016 - Medical Device Quality Management Systems 2
J Applying for 510K - What is a significant process change and what is not US Food and Drug Administration (FDA) 5
V Screening DOE with 7 Input factors and 4 responses - Significant factors Using Minitab Software 1
shimonv FDA released final guidance documents on what constitutes a significant change Other US Medical Device Regulations 2
R AS9100D Cl. 8.4.2 - Identify Raw Material as a Significant Operational Risk AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
G Sample Size, Significant Figures, Scale General Measurement Device and Calibration Topics 3
I Catch up 510(k) - Non-significant changes were made Other US Medical Device Regulations 1
M DOE: Significant factor or not Using Minitab Software 2
K Plastic Resin designated as Significant Characteristic Manufacturing and Related Processes 7
G Supplier Significant Environmental Aspects - Audit Finding ISO 14001:2015 Specific Discussions 21
A Significant Figures and Rounding SOP Document Control Systems, Procedures, Forms and Templates 4
E FDA Significant Change Interpretation - Guidance Document EU Medical Device Regulations 2
somashekar Industry examples of Significant Beneficial Environmental Impacts Miscellaneous Environmental Standards and EMS Related Discussions 3
Q Reporting Significant Medical Device Changes to Argentina's ANMAT Other Medical Device Regulations World-Wide 3
S Format for Significant Environmental Aspects Study ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Auto Parts Warehousing Facility ISO 14001 Significant Aspects ISO 14001:2015 Specific Discussions 23
R 4 Factors 3 Level DOE to determine which factors are significant Using Minitab Software 2
5 Number of 'significant digits' in measurements Inspection, Prints (Drawings), Testing, Sampling and Related Topics 31
R ISO is certified to ISO 14001:2004 - What are their Significant Environmental Aspects ISO 14001:2015 Specific Discussions 2
S Managing a Significant Number of Outstanding Non-Conformities Nonconformance and Corrective Action 6
E Significant Change and Guidance Documents for Medical Devices Other Medical Device Regulations World-Wide 6
E What's the difference: AIAG-PPAP's "Significant Production Run" and "Run @ Rate"? APQP and PPAP 11
T Health Canada Class III/IV "Significant Change" guidance interpretation Canada Medical Device Regulations 2
D Best Minitab Tool to determine a Statistically Significant Trend Using Minitab Software 5
C Significant changes between EN80079-34 and EN 13980:2002 which it replaces Manufacturing and Related Processes 7
K I've had a significant win with Safety Policy Occupational Health & Safety Management Standards 12
C How to Quantify Significant Change for a Shelf Life Stability Test Other Medical Device Related Standards 15
