Simple and effective way to maintain Training Matrix
QE1993
I work at a midsize company, around 110 employees.
I am running into major problems with Training. Namely, I'm not quite sure how I can easily and quickly manage what document, rev, and date everyone was trained to and compare that to what they are supposed to be trained to to determine any gaps.
I have set-up an excel matrix that "assigns" relevant procedures to each job description. (looks something like the attached).
I then set up an excel matrix that lists all our documents and every employee. The idea was that I would update that matrix with the date and document rev that the employee was trained to. (example attached).
Twice a year, I was planning on comparing the two matrices to see if I cuold find any gaps.
As you can see, this is incredibly time consuming and manual and is easily prone to mistakes. I've already started to neglect the Training matrix.
I am the only Quality Engineer that is working on the QMS on top of doing the daily QE tasks. I don't have a doc control staff (who I would ideally task with dealing with the training matrix), and I'm afraid I'm going to drown myself in maintaining training records.
I don't mean to come of as pretentious, but I don't know how else to make this point...it seems a little below my pay grade to be updating excel matrices all day.
There's got to be a simpler way.
We do use IQS - a QMS software - does anyone have an experience with this? The only way I've figured out how to maintain training here is still very time consuming (adding individual documents to each employee and deleting and updating them every time they are trained to a new rev.).
Any suggestions?
My company (a 501c3 charitable organization) has 400+ employees and in excess of 4,000 documents (procedures, work instructions and production specifications) and we document training via an excel matrix where training documentation forms are saved to a folder on our network and the matrix hyperlinks to the document. Fortunately, we have a dedicated employee doing nothing but updating the training matrix. Short of purchasing highly expensive software, this is the best option we have found to document training.
Kronos147
Food for thought, make training a mandatory step in the document change process.
To expand on that: you could make a corrective action to make this your new policy and move forward with your records as is and not do the GAP. (If the Risk is managed)
QE1993
Sorry, I'm not really following? Training is a mandatory step in high-risk document changes. I still need to manage who is trained to what. With almost 110 employees, I need to be able to look at something and right away know if they were trained to that document and to what rev...in case I missed them during a training for an update.
I have had to deal with this and have fought this (overly simplistic) approach. Training is to develop skills. Often changes are due to things which have zero impact on competency. It's a waste to force everything down the "training" process.
I think what Kronos is trying to say, is to make things a bit easier for you, start a CAPA on Training. Draw a line in the sand, if you will. Update your Document change control process to require training as part of the release of that document.
I would also add that, as we all know, many minor changes occur in documents so add an"is training required" yes/ no section to eliminate needless training.
Quality will be signing off, so they can review if training should have been performed and/ or ensure training records are present.
This will ensure training is done, however, unless you update the training matrix regularly or have someone helping you out with the spreadsheet, it will be time consuming every 6 months.:bonk:
If you can, have document control update the matrix with the trained employees. Then you can just perform your verification.
Good Luck!
QE1993
Good Luck!
Thanks for the input. I don't have a doc control staff, which is the problem. I don't have time to update matrices all day, so I was trying to figure out a quicker solution.
We have a CAPA on training open and the line has been drawn. I require training for all high risk document changes. That is all in place. I still need to maintain all of that - I still need to know what revision an individual was trained to in case they missed a training session. I'm not talking about a retrospective gap assessment, I"m talking about a gap assessment every 6 mos. moving forward to make sure all training is up to date.
Maybe I'm misinterpreting what you're saying. Are you saying not to have a matrix at all?
A training matrix is the easiest visual to use for sure, but, if you do not have the manpower to keep it up, then it is useless to you.
If you have a system (Document Change/ Engineering Change or the like) that you can add training requirements into as a requirement prior to closure, then it will be more manual, but it will handle the job. I would suggest having a matrix of job titles and required docs so you know who needs what. In the beginning, I would verify all of changes to make sure they were performed correctly (as part of your CAPA).
and later, instead of performing a biannual audit of the matrix. Pull a handful (or more depending on the quantity of the output) and audit/ verify that the correct people have been trained on the documents that you have reviewed. It won't be a 100% answer but it will keep you from a straight jacket (at least for that issue) :lol:.
QE1993
This is a great idea. Thanks!
I have a matrix of Job Descriptions and the documents that JD needs (it's attached in my original email), it's good to know I"m on the right track with that.
H Simple Effective Internal Audit ISO 13485 Audit Check List needed Internal Auditing 3
D APQP (Advanced Product Quality Planning) - Seeking a simple, effective format Document Control Systems, Procedures, Forms and Templates 6
N Simple statistics questions on labor data Statistical Analysis Tools, Techniques and SPC 2
B Can someone help me explain P-Value with a simple word please? Capability, Accuracy and Stability - Processes, Machines, etc. 11
M Nice and simple invitation email to an audit kickoff meeting Internal Auditing 1
G Rework, Reprocess, or Correction - A simple blurred letter on the legible etching ISO 13485:2016 - Medical Device Quality Management Systems 4
C Looking for simple Software Validation IQ templates. Qualification and Validation (including 21 CFR Part 11) 4
Cats Clause Micrometer and Vernier Caliper simple calibration process General Measurement Device and Calibration Topics 8
I Tracking Protoype Changes; 8D or simple document revision? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Simple supplier evaluation qualification process form that includes Risk Assessment Document Control Systems, Procedures, Forms and Templates 2
L Simple Example for PFMEA / Control Plan Training Training - Internal, External, Online and Distance Learning 1
K Simple ISO 9001:2015 Overview Presentation wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
V Acceptance Criteria Gage R&R - Simple vs Complex Techniques Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
V Making a choice of Simple vs Comprehensiveness of Procedure/System of any Process Document Control Systems, Procedures, Forms and Templates 4
K Simple ISO 9001 Compliant Document Control Quality Manager and Management Related Issues 24
R Determining the feasibility/scope for FDA IQ/OQ against a very simple application US Food and Drug Administration (FDA) 2
R Root Cause for "Simple" External Audit Findings ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Marc What Airlines Really Charge (In 1 Simple Table) Travel - Hotels, Motels, Planes and Trains 6
E Simple Calibration Procedures for Surftest SJ-400 General Measurement Device and Calibration Topics 6
K Too Simple an Internal Audit Check Sheet? Internal Auditing 10
S Can you help with a simple SPC sheet to judge if inspection is Good / No Good ? Capability, Accuracy and Stability - Processes, Machines, etc. 8
T Microsoft Access Database to create a Simple Calibration Certificate General Measurement Device and Calibration Topics 6
S Destructive Attribute MSA for Simple Water Leak Check in Trailers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
V Best CAPA for slip in simple-yet-persistent oversight-review mechanism Nonconformance and Corrective Action 7
A Simple 125 piece part Capabilty Excel .xls sheet to calculate Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 3
R A simple electronic (software) document control question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A QSM documents for Simple Designs Quality Manager and Management Related Issues 12
M Looking for a simple procedure on section 7.5.2 for Validation of Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Proud Liberal Making a simple Sampling Plan by Variables Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
W Simple SPC Software recommendations Quality Assurance and Compliance Software Tools and Solutions 8
Z IEC 60601-1-2 for very simple Medical Device Accessory IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
P Monitoring Production Defects - Three simple questions Six Sigma 3
C Simple explanation of Uncertainty in Calibration Measurement Uncertainty (MU) 2
V External power supply with reinforced insulation as a simple secondary circuit? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
M Conducting Limited Internal Audits of QMS Elements - Simple question I hope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
K How to set up a simple Complaint and CAPA workflow Nonconformance and Corrective Action 9
V Simple Representation for Scope of DFMEA and PFMEA FMEA and Control Plans 4
Stijloor Simple Navigation Guide for the MSA 4th Edition Manual Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
S Simple Cartoons needed Coffee Break and Water Cooler Discussions 4
X FDA Approval Process - Simple Explanation requested US Food and Drug Administration (FDA) 4
K Definition Box Plot - Simple Explaination of what a Box Plot is Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
M Simple Field Pipeline Demagnetization Procedure needed Document Control Systems, Procedures, Forms and Templates 5
6 Simple Flow Diagram with CCPs for Processing of Raw Fish Food Safety - ISO 22000, HACCP (21 CFR 120) 1
V Can Anyone Give a Simple Explanation on ndc (number of distinct categories)? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
T Export "Simple Notification" required by the FDA under Section 802 of the Act Other US Medical Device Regulations 3
Ajit Basrur EAC, Simple Code and NACE Code ISO 13485:2016 - Medical Device Quality Management Systems 5
1 Simple Dock Audit Form Document Control Systems, Procedures, Forms and Templates 1
Colin Simple Home Remedies Funny Stuff - Jokes and Humour 6
J Simple Corrective Action Flow Chart example needed Problem Solving, Root Cause Fault and Failure Analysis 4
B Overall Process Capability - Simple question if you know how to answer it! Statistical Analysis Tools, Techniques and SPC 3
